    Curved Staircases
    171 Posts 19 Posters 39.0k Views 19 Watching
      Garry K
      Walt - I'm sorry but I can't answer that question. I haven't heard anyone else having that problem. It may have something to do with http configurations on your specific machine.
      Maybe someone else can answer it. Perhaps start a new thread on this. Maybe the developer forum will catch some attention.
      As you can see - the code isn't doing a whole lot.
        mwm5053
        @ Garry you're right I installed 1.0.8 rbz on Mac Book Pro and works great with no hitches. Mac Pro (desktop) running SU 8 and Lion and Mac Book Pro (laptop) running SU 8 and Mavericks. 😉
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
          Garry K
          I now have language translation working. There is a folder called translations and currently there are 4 files in it.
          en.lang - English
          fr.lang - French
          ru.lang - Russian
          zh.lang - Chineses ( traditional )
          Near the top of the defaults.txt file there is a language= section where you can enter the 2 character language code. If you leave the language= blank the system will try to figure out the locale code.
          These language files are straight translations and as a result there might be some funny and or inappropriate translations.
          Anyone interested in helping out with any language translation can get a hold of me.
          French Stair Maker
          Russian Stair Maker
          Chinese Stair Maker
            Garry K
            A user with a windows 8 machine running SU 2013 has reported an error that I can't duplicate ( I don't have a windows 8 machine )
            puts "starting: dialog.execute_script( js_command )"
            this code doesn't run
            puts "finished: dialog.execute_script( js_command )"
            it errors out with this
            type: mismatch
            code: 0
            url: file:///C:/Users/Admin/AppData/Local/Temp/skp8C34.tmp
            Is there anyone else with a Windows 8 machine running 2013 who would be willing to try this code.
            ` require 'sketchup.rb'
            show_dialog
            def show_dialog()
            dlg = UI::WebDialog.new( "Stair Measurements", false, "DialogTest", 200, 150, 150, 150, true );
            dlg.add_action_callback( "ruby_callback" ) { |dialog, params|
            text = params.to_s
            	if( text == 'loaded' )
            		args =  'inside_stringer=Housed|Sawtooth|None' +
            				'&inside_stringer=1' +
            				'&inside_option=Has Heel|Has Foot|Both|None' +
            				'&inside_option=3' +
            				'&inside_thickness=60' +
            				'&inside_width=300' +
            				'&inside_rail=Guard Rail|Wall Rail|None' +
            				'&inside_rail=2' +
            				'&outside_stringer=Housed|Sawtooth|None' +
            				'&outside_stringer=0' +
            				'&outside_option=Has Heel|Has Foot|Both|None' +
            				'&outside_option=3' +
            				'&outside_thickness=60' +
            				'&outside_width=400' +
            				'&outside_rail=Guard Rail|Wall Rail|None' +
            				'&outside_rail=2' +
            				'&total_rise=2667' +
            				'&risers=15' +
            				'&riser_thickness=12.7' +
            				'&direction=Clockwise|Anti Clockwise' +
            				'&direction=1' +
            				'&stair_width=1000' +
            				'&radius=2400' +
            				'&degrees=90' +
            				'&floor_thickness=60' +
            				'&rail_style=Classic|Modern|Round|Square|Standard|Traditional' +
            				'&rail_style=4' +
            				'&tread_thickness=38' +
            				'&average_run=254' +
            				'&tread_bullnose=12.7' +
            				'&nosing=25.4' +
            				'&flare_amount=0' +
            				'&progressive_flare=20' +
            				'&flare_count=0'
            		js_command = "from_ruby( '" + args + "' )"
            		puts( js_command )
            	else
            		UI.messagebox( text )
            		puts( text )
            dialog.close();
              html = <<-HTML
            <!DOCTYPE html>
            <html>
            <style type="text/css">
            body { background-color: #F9EBD1}
            fieldset { float: left; background-color: #F9EBD1; border-color: black; margin: 3px;}
            fieldset p {display: table-row;
            font-family: Arial, Helvetica, sans-serif;
            font-size: 90%;
            color: black;
            height: 27px}
            fieldset input,
            fieldset select,
            fieldset label {display: table-cell; margin: 2px; width: 120px }
            fieldset label {text-align: right;}
            fieldset input,
            fieldset select {margin-left: 10px; background-color: wheat;}
            </style>
            <head>
            <meta http-equiv="MSThemeCompatible" content="Yes">
            <script>
            function do_click()
            var items = document.getElementsByTagName( '*' );
            var count = items.length;
            var text = "";
            for ( var i = 0; i < count; i++ )
            if ( items[i].type == "select-one" )
            value = items[i].options[items[i].selectedIndex].value;
            else if ( items[i].type == "text" )
            value = items[i].value;
            else if ( items[i].type == "checkbox" )
            value = items[i].checked.toString();
            else
            value = "";
              if ( value.length > 0 )
            	  if ( text.length > 0 )
            		 text += "&";
            	  text += ( items[i].id + "=" + value );
            ruby_call( text );
            function from_ruby( data )
            var element;
            var pair;
            var pairs = data.split( '&' );
            var count = pairs.length;
            	pair = pairs[i].split( '=' );
            	element = document.getElementById( pair[0] )
            	if ( element.type == "select-one" )
            		if ( pair[1].indexOf('|') == -1 )
            			element.selectedIndex = pair[1];
            		else
            			populate_drop_down( element, pair[1] );
            	else if ( element.type == "text" )
            		element.value = pair[1];
            	else if ( element.type == "checkbox" )
            		element.checked = pair[1] == '1';
            function populate_drop_down( element, data )
            var options = data.split( '|' );
            var count = options.length;
            var option;
            element.innerHTML = "";
            	option = document.createElement( "option" );
            	option.text = options[i];
            	element.add( option, null );
            function ruby_call( text )
            query = 'skp:ruby_callback@' + text;
            window.location.href = query;
            function on_load()
            ruby_call( 'loaded' );
            </script>
            </head>
            <body onload="on_load()">
            <form>
            <fieldset>
            <p><label>Inside Stringer:</label><select id="inside_stringer"></select></p>
            <p><label>Options:</label><select id="inside_option"></select></p>
            <p><label>Thickness:</label><input type="text" id="inside_thickness"</p>
            <p><label>Width:</label><input type="text" id="inside_width"</p>
            <p><label>Rail Options:</label><select id="inside_rail"></select></p>
            </fieldset>
            <fieldset>
            <p><label>Outside Stringer:</label><select id="outside_stringer"></select></p>
            <p><label>Options:</label><select id="outside_option"></select></p>
            <p><label>Thickness:</label><input type="text" id="outside_thickness"</p>
            <p><label>Width:</label><input type="text" id="outside_width"</p>
            <p><label>Rail Options:</label><select id="outside_rail"></select></p>
            </fieldset>
            <fieldset>
            <p><label>Stair Direction:</label><select id="direction"></select></p>
            <p><label>Stair Width:</label><input type="text" id="stair_width"</p>
            <p><label>Radius:</label><input type="text" id="radius"</p>
            <p><label>Degrees:</label><input type="text" id="degrees"</p>
            <p><label>Rail Style:</label><select id="rail_style"></select></p>
            <p><label>Open Risers:</label><input type="checkbox" id="open_riser"</p>
            <p><label>Total Rise:</label><input type="text" id="total_rise"</p>
            <p><label>Risers:</label><input type="text" id="risers"</p>
            <p><label>Riser Thickness:</label><input type="text" id="riser_thickness"</p>
            </fieldset>
            <fieldset>
            <p><label>Tread Thickness:</label><input type="text" id="tread_thickness"</p>
            <p><label>Average Run:</label><input type="text" id="average_run"</p>
            <p><label>Tread Bullnose:</label><input type="text" id="tread_bullnose"</p>
            <p><label>Nosing:</label><input type="text" id="nosing"</p>
            <p><label>Flare Amount:</label><input type="text" id="flare_amount"</p>
            <p><label>Progressive Flare:</label><input type="text" id="progressive_flare"</p>
            <p><label>Flare Count:</label><input type="text" id="flare_count"</p>
            <p><label>Floor Thickness:</label><input type="text" id= "floor_thickness"</p>
            <p><label>Create Stair:</label><input type="button" onclick="do_click()" style="background: silver" value="Ok"></p>
            </fieldset>
            </form>
            </body>
            </html>
              HTML
              dlg.set_html html
              dlg.show
            if ( not file_loaded?( "dialog_test.rb" ) )
            UI.menu( "Plugins" ).add_item( "Web Dialog Test" ) { show_dialog() }
            file_loaded( "dialog_test.rb" )
              Garry K
              Version 1.0.11 06-Mar-2014
              1. Now SU 2014 compatible
              2. Added missing line to gkware_stairmaker_loader.rb. Utils.rbs was only loading if door maker was installed.
              3. Added Config folder to hold user configuration and temp files
              4. Make button images for add Handrail profile and glue edges
              5. Fixed bug in handrail scaling
              6. Auto Sizing of Web Dialog. For some reason – need to add room for scroll – even if it shouldn’t be needed
              7. Fixed bug where trial string keeps growing
              8. Handrail was not going into “Handrail” layer. Fixed
              9. Changed Stringer “Width” to “Depth” in web dialog, language files and in defaults.txt
              10. Made changes to defaults.txt for “imperial_stair_width”
                aconk25
                error in windows 8 64bit
                  mwm5053
                  You might want to add .rbz to post or transfer this to plugins forum it's hard to find the file embedded in the middle of topic I can't find maybe I missed it somewhere.
                  2011 iMac
                  V2 Twilight
                    Garry K
                    I've been busy learning about JQuery, Ajax, JSONP etc.
                    Here are 2 ruby scripts that I would like someone to try on OSX Lion, OSX Maverick and Windows 8.
                    The first script is called 'dialog_test_tabs.rb' and is set up with tabs. The tabs code came from user NewOne
                    http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=22662
                    This works nicely on my machine which is a Windows 7 machine. I have Internet Explorer 11 installed.
                    The second script is call dialog_test_5.rb and connects to a test web service on my web site. It just passes a very simple JSONP record {"firstname":"Jeff"} and is suppose to respond with 'Your name is Jeff Hansen'
                    Tabbed test dialog
                    Web service test script
                      pisosse
                      Well i'm on SU2014 and yosemite
                      First of all I still get the "HTTP error"
                      That is very well the reason I get these outputs of your test files.
                      Dialog 5 output
                      Dialog tab output
                        pisosse
                        Installed via the sketchucation plugin and all is good.. Just wonder what to do if stringers have different curvatures ?
                          Garry K
                          Do you have an example of what you mean by different curvatures?
                          My understanding so far is this.
                          Curved stringers do have different curvatures (radius), but they both have the same pivot point. The best I can do right now for irregular stairs is the 2D to 3D portion of the stair maker suite.
                            pisosse
                            Ahh.. ok thanks. Would I mean is that the stringers is curved but not in parallel. On stringer has a sharper curve than the other. Btw. the 2D to 3D feature sounds promising but the documentation in the help file is leaving me a little puzzled. Should I make 2 stringers as pollens and the select them an push the 2Do3D button or do I have to make a face? sorry this is totally obvious to other than stupid old me. Other than that it is a pretty solid piece of coding sir!
                              Garry K
                              I have a few videos on the 2D to 3D stairs.
                                pisosse
                                NICE.. thanks a lot!
                                • 5 / 9
