    Curved Staircases
    171 Posts 19 Posters 71.7k Views 19 Watching
    • pbacotP
      I'll give it a run (Mac). Let's see, where can it be DL'd?
        @Garry K
        Many thanks for the video! šŸ‘
        You must put it also on the first post! šŸ¤“
        Ps I just seen that you had another one page 2 šŸ˜„
        • jeff hammondJ
          it's at his site: http://cabmaker32.com
          you have to register which is an easy process without demanding too much info etc..
          it's a little weird in that once you download the plugin, you have to find a .txt file within the folders then edit your cabmaker32 user name & password into it.
          @GarryK- i'm trying this out on mac.
          i've dowloaded/installed the plugin and entered my login details in the .txt file..
          upon launching sketchup, there are no load errors and i get the toolbars as well as the Curved Stairs entry(s) in the plugin menu.
          upon clicking on an icon in the toolbar, i get this message:
          i'm online while attempting to use it.
          • O
            otb designworks
            Garry, your Kung Fu is good! Can't believe I managed to miss this thread.
            Thanks for the inspiring journey through your process.
            Just seeing that I should be running this through my mac to see how it works. Will let you know...
            Cheers, Chuck
            OTB Designworks is on Youtube
            • G
              Garry K
              Jeff,
              Thanks - I see that you downloaded it. I have no idea why you couldn't reach the web site.
              Perhaps try from your browser ( I know it won't work ) but you should still see a message if you can reach the web site.
              http://cabmaker32.com//stairmaker_service.php
              If you can reach you should get a JSON response saying invalid format.
              I'm puzzled. I am getting the same thing now. First a "http Error" and the second time I click the button it says "Cannot reach web service"
              I will try to dig in and see what is going on.
              OK - when I tried running it my defaults.txt file was pointing to my local test web site.
              I switched over to cabmaker32.com and it works - even when I am logged on to the sit.
              Garry
              • G
                Garry K
                I'll have to get back into this in the morning - I've been up 20 hrs straight and can't think.
                I am putting out both errors - obviously I should have said a bit more with the messages.
                if ( xmlHttp.readyState == 4 )
                if ( xmlHttp.status == 200 )
                	ruby_call( xmlHttp.responseText );
                else
                	ruby_call( 'error' );
                In the ruby_call I pass back the JSON message and then decode it.
                If it doesn't come back then a hash object doesn't get created.
                Then this bit of code gets hit.
                if ( ! defined?( @@hash_obj ) )
                	UI.messagebox( "Cannot reach web service" );
                	return;
                • jeff hammondJ
                  @garry k said:
                  Jeff,
                  from my browser with that link i get:
                  {"code":-11,"text":"invalid format","token":240583372}
                  i've done the following to the defaults.txt file
                  user information
                  userid=Jeff Hammond
                  password=(my 12digit PW)
                  host=http://cabmaker32.com/
                  default non length values for input box
                  debug_level=0
                  direction=Anti Clockwise
                  inside_option=None
                  outside_option=None
                  inside_stringer=Sawtooth
                  etcetc..
                  i assume that's correct, right?
                  i tried logging out of your site and i still get the same error message when using Stair Maker.. i can click on the Extrude Handrail icon and i get the message about needing a curve selected.. so i select a curve then click the icon and i get an error:
                  [EDIT] oops.. ruby error removed[/edit]
                  i won't be able to troubleshoot too much tonight but i'll try some things in the morning if you leave instructions.
                  • jeff hammondJ
                    šŸ˜†
                    get some rest!
                    • G
                      Garry K
                      Jeff,
                      1. You can reach my web site
                      2. The defaults.txt file looks fine
                      3. This is the code on line 792 where the error occurs for extrude handrail.
                      File.join( Sketchup.find_support_file( "" ), "Plugins", "GKWare", "StairMaker", "Handrail" )
                      StairMaker expects the folder Plugins/GKWare/StairMaker/Handrail
                      It then goes through the files to create a list of the 6 default handrails.
                      Could you run these lines of code in the Web Console
                      puts Sketchup.find_support_file( "" )
                      puts File.join( Sketchup.find_support_file( "" ), "Plugins", "GKWare", "StairMaker", "Handrail" )
                      • G
                        Garry K
                        I have just read an article by Thomas and now realize that I am currently not supporting plugins installed in shared location. I will change this, test and get back to you.
                        • G
                          Garry K
                          I've fixed the path issue and uploaded a new version to my website.
                          The new version has an rbz extension and has increased the version.
                          Even if your old version worked - it won't now.
                          Please download a new version.
                          • jeff hammondJ
                            ok.. so you've made some progress šŸ˜‰
                            i can now activate the plugin without the previous error message.
                            once i'm in it though, there are a few problems with the window size/placement etc but that's not too important right now.. i can't use any of the drop down menus:
                            i can enter text/number in the text fields.. i can also check/uncheck the 'open risers' box.. and i can push the OK button but nothing is generated as i assume the drop downs should have some settings applied?
                            i get this in the ruby console:
                            [EDIT] no errors are being reported in the ruby console [/edit]
                            not sure but you may be trying to re-invent the wheel if you single handedly troubleshoot the sketchup web dialogs on mac.. thomthom, or TIG, or Fredo have already figured this stuff out and it might be best to contact one of them for some advice/tips.. ?
                            • G
                              Garry K
                              We aren't too far away. However - data from the defaults.txt file is suppose to populate the controls with defaults.
                              That isn't happening.
                              Perhaps try the extrude handrail. This one is a Sketchup input box as opposed to the web dialog. Let's see if there are 6 handrail profiles in the drop down list? That should help tell me if the problem is in reading the values or in popluating the web dialog.
                              • jeff hammondJ
                                yep.. handrail works.. here's a 'traditional'
                                • G
                                  Garry K
                                  Jeff Thanks a ton. You've been very helpful.
                                  I'm going to build a shell that just populates the web dialog box with values. It will be easier to debug. Then I will see if thomthom, or TIG can help out.
                                  • G
                                    Garry K
                                    I re read all of thomthom's documentation on web dialogs. It turns out that Safari doesn't support the onload event. I've changed how I am doing things. I'm hopeful that I've got it figured out.
                                    Please download a current version and try it out on the mac - thanks.
                                    • jeff hammondJ
                                      hmm.. same thing as last time..
                                      i'm not sure if there's something i can check to be positive i'm using the latest test version but in this case, i assume since i had to re-edit the txt file, all went well on the installation side of things.
                                      • G
                                        Garry K
                                        Thanks,
                                        You can check the version in the Extensions area under Preferences. However - I did not change the version number this time. It is 1.0.3
                                        Next time we try I will make a point of increasing the build number.
                                        I will need to dig into this.
                                        BTW are you running Sketchup 2014?
                                        I haven't tested my plugin with that version - I didn't even know that it was out yet.
                                        • G
                                          Garry K
                                          Jeff,
                                          What version of SU are you running?
                                          What I find interesting and frustrating is that I thought I solved this a month ago. Driven ran my test code on his mac and it seemed to work fine.
                                          There is a dialog_test.rb file part way down this thread
                                          404 Not Found
                                          (sketchucation.com)
                                          perhaps you can try it and see if you 1) get a populated web dialog and 2) get an SU message box with you click "OK"
                                          • jeff hammondJ
                                            @garry k said:
                                            Jeff,
                                            404 Not Found
                                            (sketchucation.com)
                                            i'm doing all the testing on SketchUp Make 2013 and OSX 10.9.1 (mavericks)
                                            (some of the earlier ruby errors (which i've edited out of the thread) were being reported in a weird version of sketchup i have but i switched to trying in in SuMake.)
                                            when using the web dialog test via the link you provided, all seems to work fine (again, sizing/layout issues with the actual window but the functionality of the dialog appears to work well-- drop downs, text fields, buttons, check boxes.. no problems).. plus there are default setting already entered in the text fields etc when doing the test.
                                            message box upon clicking 'OK' in the test:
                                            With your input, this post could be even better šŸ’—
                                            • 5 / 9
