    Curved Staircases
    171 Posts 19 Posters 62.5k Views 19 Watching
      jabbers
      I will second Kristoff's idea about flaring the strings also, also might be an idea to have a straightening of strings option as Garry said , say the first X no of steps, it would make it very handy, especially the wall/outside string.
      BTW ..if any one wants to 3d model the horse newel. i will machine it...min order 50 peices !!! .
      Regards BOB
      • G
        Garry K
        I've added a couple more stair configurations to StairMaker. An Open Riser choice and a Rail Style.
        The input box is getting pretty tall and there are more options to come. Once the input box gets to big I will have to either split it up into 2 or more input boxes or I can go with a web dialog box where I have way more control.
        Here is a the tall StairMaker input box and also a web dialog box. The web dialog box is my preferred way of doing things but there are advantages to each.
        web dialog box:
        1. It is easy to organize the inputs into various sections
        2. You can have check boxes and radio boxes
        3. Unfortunately there isn't an easy way to allow a mix of inputs - some metric and some imperial.
        4. At this stage I would only support decimal inputs for only metric or only imperial. No fractions
        Sketchup input box
        1. A lot less coding using the built in input box.
        2. You can mix inputs by using mm or "
        3. you can use fractions for imperial
        4. At some point the input box will become too large and will have to be broken into several inputs.
        What do you guys think? Do you like the web dialog or the built in Sketchup Input Box?
        I'd love to have a vote on this - but I don't know how to set that up.
        Built in Sketchup imput box
        Web dialog input box
          A little video will be very appetizing! ☀
          • F
            Futurepast
            I think the Sketchup input would do, just make drop downs of each category off the main screen Treads, Stringers, Railings, etc. 😄
            • G
              Garry K
              I have considered that as a possible solution; however, it would be beneficial to have all the configurations on one form - thus the web dialog.
              I have now built the parsing and conversion routines and have found a bug in Sketchup's conversion routines. This also affects Sketchup's input box when inputing fractional inches such as '2 1/2"' and using a model setup in millimeters.
              404 Not Found
              (sketchucation.com)
              I have a fix that works with the web dialog box.
              • G
                Garry K
                I've got the web dialog working with the Stair Maker. I have also solved a few of the cons of using it. Since I needed a web dialog anyway - this seems like the best route.
                You can use fractional inputs and you can use mixed inputs. Furthermore, I may be able to leave the web dialog box up while the stair is drawing. The advantage of this is you would be able to make changes and have the stair redraw itself ( remove the existing one and create a new one ) each time you click 'OK' providing that web dialog box hasn't closed. Once the web dialog box is closed then we could move on to a second curved stair without messing with the first one.
                Another advantage is that I can fairly easily add in an expression evaluator. I am use to this feature in various CAD systems. For instance - you can type in 1000 - 27.3 for width and it would replace what you type with 972.7
                The built in Sketchup input box has limitations that aren't there with a dialog box. It would be very easy to add in additional pages that could be used to store user defaults.
                completed web_dialog
                • charly2008C
                  charly2008
                  web dialog box
                  • KrisidiousK
                    Krisidious
                    I like the side by side too... the length was a little much.
                    By: Kristoff Rand
                    • G
                      Garry K
                      Thanks guys. Another neat thing about the web dialog is I can add a bit of mouse over help on some of the prompts and or input fields.
                      For instance a few of the prompts that need help are:
                      'Radius'
                      'Set to 0 and StairMaker will calculate based on degrees and Average Run'
                      'Degrees'
                      'Average Run'
                      'Average Run is ignored if both Radius and Degrees are set'
                      • G
                        Garry K
                        I have a StairMaker plugin that is ready to go. This is version 1.0.3.
                        You may go to my web site CabMaker32.com, register and download the plugin.
                        The plugin is a zip file - unzip it to your plugins folder. There should be 1 file added to the plugins folder GKWare_StairMaker_Ext.rb and a folder called GKWare.
                        Please edit file GKWare/StairMaker/defaults.txt.
                        You will need to put in your userid and password that you received via the register process.
                        • G
                          Garry K
                          Pilou Here is the video that you requested.
                          • G
                            Garry K
                            I am interested in finding individuals who would like to test this plugin.
                            Specifically I'd like to know if it even works with Mac.
                            Is anyone experiencing any problems with the plugin.
                            Does anyone have any suggestions?
                            • KrisidiousK
                              Krisidious
                              I'm on PC but no issues here.
                              By: Kristoff Rand
                              • pbacotP
                                I'll give it a run (Mac). Let's see, where can it be DL'd?
                                  @Garry K
                                  Many thanks for the video! 👍
                                  You must put it also on the first post! 🤓
                                  Ps I just seen that you had another one page 2 😄
                                  • jeff hammondJ
                                    it's at his site: http://cabmaker32.com
                                    you have to register which is an easy process without demanding too much info etc..
                                    it's a little weird in that once you download the plugin, you have to find a .txt file within the folders then edit your cabmaker32 user name & password into it.
                                    @GarryK- i'm trying this out on mac.
                                    i've dowloaded/installed the plugin and entered my login details in the .txt file..
                                    upon launching sketchup, there are no load errors and i get the toolbars as well as the Curved Stairs entry(s) in the plugin menu.
                                    upon clicking on an icon in the toolbar, i get this message:
                                    i'm online while attempting to use it.
                                    • O
                                      otb designworks
                                      Garry, your Kung Fu is good! Can't believe I managed to miss this thread.
                                      Thanks for the inspiring journey through your process.
                                      Just seeing that I should be running this through my mac to see how it works. Will let you know...
                                      Cheers, Chuck
                                      OTB Designworks is on Youtube
                                      • G
                                        Garry K
                                        Jeff,
                                        Thanks - I see that you downloaded it. I have no idea why you couldn't reach the web site.
                                        Perhaps try from your browser ( I know it won't work ) but you should still see a message if you can reach the web site.
                                        http://cabmaker32.com//stairmaker_service.php
                                        If you can reach you should get a JSON response saying invalid format.
                                        I'm puzzled. I am getting the same thing now. First a "http Error" and the second time I click the button it says "Cannot reach web service"
                                        I will try to dig in and see what is going on.
                                        OK - when I tried running it my defaults.txt file was pointing to my local test web site.
                                        I switched over to cabmaker32.com and it works - even when I am logged on to the sit.
                                        Garry
                                        • G
                                          Garry K
                                          I'll have to get back into this in the morning - I've been up 20 hrs straight and can't think.
                                          I am putting out both errors - obviously I should have said a bit more with the messages.
                                          if ( xmlHttp.readyState == 4 )
                                          if ( xmlHttp.status == 200 )
                                          	ruby_call( xmlHttp.responseText );
                                          else
                                          	ruby_call( 'error' );
                                          In the ruby_call I pass back the JSON message and then decode it.
                                          If it doesn't come back then a hash object doesn't get created.
                                          Then this bit of code gets hit.
                                          if ( ! defined?( @@hash_obj ) )
                                          	UI.messagebox( "Cannot reach web service" );
                                          	return;
                                          • jeff hammondJ
                                            @garry k said:
                                            Jeff,
                                            from my browser with that link i get:
                                            {"code":-11,"text":"invalid format","token":240583372}
                                            i've done the following to the defaults.txt file
                                            user information
                                            userid=Jeff Hammond
                                            password=(my 12digit PW)
                                            host=http://cabmaker32.com/
                                            default non length values for input box
                                            debug_level=0
                                            direction=Anti Clockwise
                                            inside_option=None
                                            outside_option=None
                                            inside_stringer=Sawtooth
                                            etcetc..
                                            i assume that's correct, right?
                                            i tried logging out of your site and i still get the same error message when using Stair Maker.. i can click on the Extrude Handrail icon and i get the message about needing a curve selected.. so i select a curve then click the icon and i get an error:
                                            [EDIT] oops.. ruby error removed[/edit]
                                            i won't be able to troubleshoot too much tonight but i'll try some things in the morning if you leave instructions.
                                            • 5 / 9
