Printing blue green background sketches w white background
Hello all
I am trying to print some sketches without background (ie white, w black lines for object and dims). I did a search here and on youtube and could not find answer in about 20 mins -maybe wrong key words. Any help appreciated. BTW, since i started out just making sketches without setting a template, all the sketches i've done to date have the green/blue background. Am i correct that setting a template w/ one of the white background will completely avoid this in future?
Thanks again
Chip
Yes, these settings are stored in a template.
Danke sehr Cotty!
Chip
@cotty said:
[attachment=0:kxic21m0]<!-- ia0 -->style_background.jpg<!-- ia0 -->[/attachment:kxic21m0]
One of the first things you should do with SketchUp is pee in the corners. Make it your own. Create your own template. I always use a white background when drawing. I set up the style as shown in the screen shot for my default style and because I need to work in fractional inches, I set units that way. Then I saved a blank file as my default template.
