    MSPhysics 1.0.3 (16 October 2017)
    928 Posts 171 Posters 1.3m Views 172 Watching
      Anton_S
      I would suggest you to start from start from MSPhysics OVERVIEW documentation tab.
        PituPhysics
        Okay, thanks Anton, I will later study.
          Anton_S
          And the "mouse script" that is used to look around, turn wheels, and do other stuff can be rewritten to rely on AMS::Cursor functions. To monitor mouse clicks, you can use MSPhysics::Body events, like
          onLButtonDown { |x,y|
          MSPhysics::Body has plenty of events and functions. You can see them here: MSPhysics::Body
            PituPhysics
            What is the equivalent of these? These are always needed. I read this:
            https://d5adbec3e1f2ea2f548f4aa0f7818eb2a3bf09ec.googledrive.com/host/0B3qg8f4WrNdHfnRoazY0djJXRk5USVg4a0tkR0FKRF9sOVNqYTNyQktxbWctRzNaRHRjd2M/MSPhysics/Body.html#get_body_by_address-class_method
            From SPhysics;
            simulation.findBody("body_name")
            sp_tool_instance.findGroupNamed("body_name")
            Here?
            simulation.get_body_by_address(address)
            The "Game mode" damn good!! πŸ’š
              Anton_S
              I'll add body by name functions in next alpha release.
                PituPhysics
                Hello Anton. When I start the SketchUp, 12-13 minutes later crashes and come up the BugSplat.
                32 and 64 bit version as well. I tried the original "Sketchup Make" and the original starter .exe file.
                If do not start the simulation, you will too.
                I see that is available the "get_body_by_name".
                How do I hide or visible body or entities? "show_bodies(false)" every group will hide.
                  Anton_S
                  Hi, Pitu!
                  That crash is most likely coming from SDL2 or SDL2_mixer, libaries that allow you to play music and sounds in SU. I currently haven't figured out why the crash occurs but your report sure does tell I wasn't the only one experiencing that crash. I will try to zero-down and fix that bug before the upcoming release.
                  To hide a body, you simply get body, and then reference its entity by get_entity function. Here is an example:
                  onStart {
                    @target = simulation.get_body_by_name("target")
                    @target.get_entity.visible = false if @target
                  onEnd {
                    @target.get_entity.visible = true if @target
                  You can also hide current body by writing this.get_entity.visible = false.
                  • soloS Offline
                    Yup, after about 12 minutes SU crashes, even if not using MS Physics, if you remove from plugin folder the splats stop, must be a conflict someplace
                    • PixeroP Offline
                      Pixero
                      Me too. If I remove it, SU doesn't crash anymore.
                        PituPhysics
                        We hope, Anton will soon be solve the SDL2_mixer problem. This "MSPhysics" awesome. 100x better than SketchyP. Lots of new and useful features in it. And it is still under development.
                        What good will, when completed ?! 😲
                        • soloS Offline
                          I got so side tracked today, I was playing Jenga with MS Physics, so much fun.
                          • soloS Offline
                            I'd be happy to eliminate the sounds if that is causing issues
                              Anton_S
                              Thanks for confirming that crash guys. Solo, removing sounds would be a bad idea. Sounds, including the 3D sounds would be essential for future FPS games in SU.
                              • jujuJ Offline
                                juju
                                future games that last only 12 minutes is surely not viable? would it not make more sense to get the plugin to work properly first then sort out the problems?
                                  Anton_S
                                  I will fix that crash. That's why I said future. SketchyPhysics, too, uses SDL, but it uses an older version which seems to work without crashing. Maybe I just drop back to SDL1 and have sounds running from there.
                                    PituPhysics
                                    Hi Anton. Will be updates? Because if not, then we need to stay the SketchyP. It does not matter if there are no "joins". Only "BugSplat" problem should be corrected. But this would be much better because the source of "clean", and it works 64-bit as well. The "SketchyPhysics" therefore much fewer people used, however could be used the 32-bit version of SketchUp 2015...
                                      Anton_S
                                      Hi Pitu. I'm taking some break from programming as there are times when one gets bored and looses motivation in it. I do, however, plan to resume works during summer break. Best wishes, Anton.
                                      • F Offline
                                        faust07
                                        Hi Anton, please stay tuned to your good work, even if the feedback at the moment is relatively low. There are only a few people that can handle such complex tasks as confident as you. You made SketchyPhysics to run very stable, and MS-Physics is again a quantum leap. I'm very excited about it and I think many other people also. Thank you!
                                        • soloS Offline
                                          Thanks for everything so far mate, we will be here waiting for whenever you get the time and interest to continue.
                                          • cottyC Offline
                                            cotty
                                            Well-deserved break πŸ‘
                                            my SketchUp gallery
                                            • 46
                                            • 47
                                            • 7 / 47
