    MSPhysics 1.0.3 (16 October 2017)
    929 Posts 172 Posters 1.3m Views 173 Watching
    • PixeroP Offline
      Pixero
      Me too. If I remove it, SU doesn't crash anymore.
        PituPhysics
        We hope, Anton will soon be solve the SDL2_mixer problem. This "MSPhysics" awesome. 100x better than SketchyP. Lots of new and useful features in it. And it is still under development.
        What good will, when completed ?! 😲
        • soloS Offline
          I got so side tracked today, I was playing Jenga with MS Physics, so much fun.
          • soloS Offline
            I'd be happy to eliminate the sounds if that is causing issues
              Anton_S
              Thanks for confirming that crash guys. Solo, removing sounds would be a bad idea. Sounds, including the 3D sounds would be essential for future FPS games in SU.
              • jujuJ Offline
                juju
                future games that last only 12 minutes is surely not viable? would it not make more sense to get the plugin to work properly first then sort out the problems?
                  Anton_S
                  I will fix that crash. That's why I said future. SketchyPhysics, too, uses SDL, but it uses an older version which seems to work without crashing. Maybe I just drop back to SDL1 and have sounds running from there.
                    PituPhysics
                    Hi Anton. Will be updates? Because if not, then we need to stay the SketchyP. It does not matter if there are no "joins". Only "BugSplat" problem should be corrected. But this would be much better because the source of "clean", and it works 64-bit as well. The "SketchyPhysics" therefore much fewer people used, however could be used the 32-bit version of SketchUp 2015...
                      Anton_S
                      Hi Pitu. I'm taking some break from programming as there are times when one gets bored and looses motivation in it. I do, however, plan to resume works during summer break. Best wishes, Anton.
                      • F Offline
                        faust07
                        Hi Anton, please stay tuned to your good work, even if the feedback at the moment is relatively low. There are only a few people that can handle such complex tasks as confident as you. You made SketchyPhysics to run very stable, and MS-Physics is again a quantum leap. I'm very excited about it and I think many other people also. Thank you!
                        • soloS Offline
                          Thanks for everything so far mate, we will be here waiting for whenever you get the time and interest to continue.
                          • cottyC Offline
                            cotty
                            Well-deserved break 👍
                            my SketchUp gallery
                            • tt_suT Offline
                              tt_su
                              Take care Anton - make sure you don't get burned out.
                                craigwise3000
                                Hello I am having trouble installing arm_Lib. I assume this is the controls and joints plugin. I have the UI plugin MSPhysics 0.2.1 plugin, and I have msvcrt-ruby200.dll as I assumed this was higher than msvcrt-ruby18.dll. I have Sketchup Pro 2014. Any thoughts on how to fix this?
                                  jayjay36well
                                  This is awesome! top! top! Top!
                                  congratulations to the developer!! keep it up!
                                    Jakeypoos
                                    Hi Anton. Can MSPhysics do wind? I've made some trees and would like to have them move in the breeze while animating using Thea render.
                                      AcesHigh
                                      Anton, i checked your YouTube channel and your newest uploaded videos are all using SketchyPhysics, not MS physics
                                      Does that mean MS will be discontinued?
                                      Btw,i never knew SketchyPhysics could do partcle simulation like in that rocket video!!!
                                      • BillMackB Offline
                                        BillMack
                                        I'm having trouble getting MSPhysics to work. I'm using SketchUp Make 2015, not Pro. Is this plugin intended and working for SU Pro only?
                                        I'm running MS Windows 7 Pro 64bit. I downloaded and extracted MSPhysics 0.2.1 and AMS Library 2.2.0 to the plugins folder. I downloaded and extracted msvcrt-ruby18.dll to the main SU program folder.
                                        When I create a cube and click the play button on the MSP toolbar, a few seconds later I get a bugsplat.
                                        I remember when SketchyPhysics worked in earlier versions of SU, you made a ground plane and then you could build and manipulate objects on it. Does MSP require a ground plane? Do I need to assign MSP attributes to objects? Also, I don't see the advanced toolbars like the demo video shows. What am I missing?
                                        Any help would be appreciated.
                                        Thanks.
                                          Anton_S
                                          BillMack,
                                          You don't need msvcrt-ruby18.dll for SU2014 or later. It is only required for SU2013 and prior. In fact, for the next MSPhysics release, upgrading Ruby version would no longer be required.
                                          I currently don't know why you get a bugsplat. I plane or assigning MSPhysics attributes isn't required. Everything should work well, but since you get a bugsplat, a sample model would be appreciated.
                                          The reason you don't see various 'advanced' icons in your toolbar is because I have moved them to simulation UI, just to save space. Open simulation UI, and check various checkbox options. You can control these advanced options even while simulation is running.
                                          And as I wrote in earlier posts, MSPhysics is still a work in progress and many features haven't been added yet. As well, the current version bugsplats every 13 minutes of using SketchUp due to the new music & sound library which is probably bugged. I reverted to an old music & sound library and everything seems to work fine now, but I'm planning to add more features before releasing MSPhysics as the next alpha release.
                                          Hope that helps,
                                          Anton
                                          • BillMackB Offline
                                            BillMack
                                            I make a basic model with a plane and a cube or sphere. SU always crashes when I hit play button on MSP.
                                            basic model
                                            I uploaded a picture here and a basic model to Jumpshare: http://jmp.sh/3nmjYeH
                                            • 46
                                            • 47
                                            • 7 / 47
