    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
      Does this present version is working for the 2015?
      • P
        PituPhysics
        I do not work in SU 15, if only "static" groups in the model. =(
          Anton_S
          What do you mean it doesn't work in 2015? It should work just as fine in all SU versions, including the 64bit. Did you download AMS Library as a requirement for MSPhysics?
          • P
            PituPhysics
            Yes, I downloaded the AMS. I use a 64-bit Windows but the SU 32-bit, because the SP 3.5.
            This could be the problem? Install the 64-bit Sketchup? I try this. I hope it will be good. πŸ˜•
              Anton_S
              Can you tell me what exactly isn't working because it should work on 32/64 bit SU versions just fine. Do you get any errors when you start SU?
                Anton_S
                Notice, this is 0.2.0 alpha. There are many features that are work in progress and not done yet. The joint tab is one of them.
                I'm still skeptical why it didn't work on 32bit. I'll have to see it on my brothers laptop and see what was going on there.
                • P
                  PituPhysics
                  I installed the 64-bit SketchUp. Now it works. πŸ˜ƒ This awesome!!!
                  However, I do not understand the "Joint" box.
                  There are no Joints. How to use it?
                  Dropbox - Error - Simplify your life
                  (www.dropbox.com)
                  • P
                    PituPhysics
                    I Mean. The scripts will work the same way as in the SP? I see the "Timer" other kind:
                    timer=AMS;;C.start_timer(1000, false){
                      AMS;;C.stop_timer(timer)
                    ... and the "mouse script" will also be available.
                    But the "Geom :: Transformation" -new, -rotation, -scaling stay the same?
                      Anton_S
                      No, scripts are different. The whole API is different. See documentation links under "Body Script" tab. MSPhysics is not related to SP. Its a different project.
                      The timer is part of AMS Library API. And I advice you to use Timer from Timer module and not from πŸ˜„
                      timer = AMS;;Timer.start(1000, false) {
                        AMS;;Timer.stop(timer)
                      Mouse control functions are available as well. See AMS::Cursor
                      Geom classes are part of SU API. They ALWAYS stay the same and are available without any plugins installed.
                        Anton_S
                        I would suggest you to start from start from MSPhysics OVERVIEW documentation tab.
                        • P
                          PituPhysics
                          Okay, thanks Anton, I will later study.
                            Anton_S
                            And the "mouse script" that is used to look around, turn wheels, and do other stuff can be rewritten to rely on AMS::Cursor functions. To monitor mouse clicks, you can use MSPhysics::Body events, like
                            onLButtonDown { |x,y|
                            MSPhysics::Body has plenty of events and functions. You can see them here: MSPhysics::Body
                            • P
                              PituPhysics
                              What is the equivalent of these? These are always needed. I read this:
                              https://d5adbec3e1f2ea2f548f4aa0f7818eb2a3bf09ec.googledrive.com/host/0B3qg8f4WrNdHfnRoazY0djJXRk5USVg4a0tkR0FKRF9sOVNqYTNyQktxbWctRzNaRHRjd2M/MSPhysics/Body.html#get_body_by_address-class_method
                              From SPhysics;
                              simulation.findBody("body_name")
                              sp_tool_instance.findGroupNamed("body_name")
                              Here?
                              simulation.get_body_by_address(address)
                              The "Game mode" damn good!! πŸ’š
                                Anton_S
                                I'll add body by name functions in next alpha release.
                                • P
                                  PituPhysics
                                  Hello Anton. When I start the SketchUp, 12-13 minutes later crashes and come up the BugSplat.
                                  32 and 64 bit version as well. I tried the original "Sketchup Make" and the original starter .exe file.
                                  If do not start the simulation, you will too.
                                  I see that is available the "get_body_by_name".
                                  How do I hide or visible body or entities? "show_bodies(false)" every group will hide.
                                    Anton_S
                                    Hi, Pitu!
                                    That crash is most likely coming from SDL2 or SDL2_mixer, libaries that allow you to play music and sounds in SU. I currently haven't figured out why the crash occurs but your report sure does tell I wasn't the only one experiencing that crash. I will try to zero-down and fix that bug before the upcoming release.
                                    To hide a body, you simply get body, and then reference its entity by get_entity function. Here is an example:
                                    onStart {
                                      @target = simulation.get_body_by_name("target")
                                      @target.get_entity.visible = false if @target
                                    onEnd {
                                      @target.get_entity.visible = true if @target
                                    You can also hide current body by writing this.get_entity.visible = false.
                                    • soloS
                                      Yup, after about 12 minutes SU crashes, even if not using MS Physics, if you remove from plugin folder the splats stop, must be a conflict someplace
                                      • PixeroP
                                        Pixero
                                        Me too. If I remove it, SU doesn't crash anymore.
                                        • P
                                          PituPhysics
                                          We hope, Anton will soon be solve the SDL2_mixer problem. This "MSPhysics" awesome. 100x better than SketchyP. Lots of new and useful features in it. And it is still under development.
                                          What good will, when completed ?! 😲
                                          • soloS
                                            I got so side tracked today, I was playing Jenga with MS Physics, so much fun.
                                            • 46
                                            • 47
                                            • 6 / 47
