    Best method to create faces for complex shapes?
    32 Posts 8 Posters 3.6k Views 8 Watching
      Expired ?
      This Plugin is a Time-Limited Demo
      NO
      Time Limit is April 10, 2016 😉
      Soap Skin and Bubble and it crashed?
      I never see it crashed! 😄
      You have also Ferrari! (better but not animation inside)
      But seems for complex structures Fredo6 curviloft is more versatile!
      • pbacotP
        Still the main question: it depends on what you are making and what is the best way to layout the parameters of the shape. Curviloft is good for my needs (usually terrain sculpting) as well as Toposhaper or any plugin that creates a usable grid that can be shaped with Vertex tools or Artisan etc. And still I am always looking at different tools for different situations.
          AcesHigh
          @pilou said:
          Expired ?
          I am aware of that. The time limit was 15 april 2015.
          NO
          this is the new time-limit, it was updated yesterday.
          as you are probably aware, Soap Skin and Bubble has a time limit of 1 year for each new version, and the new version with the new extended 1 year time-limit is only released like 1 day prior to the time-limit expiring date of the previous version
          well, the website (extension warehouse) was offline for most of the morning here.
            AcesHigh
            neither TopoShaper nor Curviloft work for what I mentioned here, as far as I am aware. At least I tried both and TopoShaper doesn´t work properly and Curviloft doesn´t even create a surface, so maybe the problem is myself, not these two plugins.
            Anyway, I am attaching a skp file with a street grid. Above the street grid I extruded the border lines following the streets contours.
            Must find faces for those contours, so we can generate sidewalks, internal terrain, etc.
            I generated the meshes with Soap Skin & Bubble, than positioned them in the streets.
            But for tests, you can use the blocks border lines, then generate the meshes with TopoShaper or Curviloft or other method of preference, and please, share the methods here...
            cityblock tests.rar
            • pbacotP
              Just a side note wouldn't it be better to construct the sidewalks separately? Perhaps as an extrusion based on the street. What is the end result? Streets amd sidewalks with "dirt"?
              At first try it appears Toposhaper and Curviloft are not suited for this. Toposhaper doesn't keep to the edge of the street.
                AcesHigh
                you mean an extrusion with Join Push Pull? Nope... the sidewalks are 4m for this project, and at that width, the curves on the block corners overlap in a geometric mess.
                same thing if you try to do a follow_me or use the profile builder plugin.
                Nope. I will use the OFFSET function of ToolsOnSurface plugin... 15cm for curb and 3.85 meters for sidewalks.
                Then I use Joint Push Pull and extrude the curbs, sidewalks and internal terrains, 15 centimeters up (using vector joint push pull)
                exactly. There are tons of other similar uses I have for SoapSkinandBubble that I can´t think how I would use Toposhaper or Curviloft.
                ps: while playing with words on Google to find other plugins capable of the same thing, I found this
                https://www.youtube.com/watch?t=45%26amp;v=WxQjAL11IB4
                however, the mesh geometry seems to be quite random... not much suited to use with Sketchup terrain tools.
                • pbacotP
                  I wouldn't use follow me (or upright extruder that way). I would probably try to make a corner element with ramps etc. and duplicate it. Might do an extrusion on the "straight" runs. But good to know those tools are feasible the way you do it. I've never faced this particular scenario, though I've made-up streets for scenes where I didn't have the grades in the first place.
                  I've seen how TGI3D can make a quick patch, but haven't found the impetus to buy it in the end.
                  What I would like is something like Toposhaper that respected the boundaries while estimating contours, and had a grid based on horizontal dimensions meters etc.--always in respect to the origin--so that patched-in grids can be fit exactly horizontally. Then it is often easy to connect patches.
                    AcesHigh
                    that sounds reasonable... but ONLY if all the corners are alike... in real grid streets. If you have streets that are more organic, you would have to create one different corner element for each corner...
                    edit: actually, even in my example it wouldn´t work out I guess, because the streets aren´t flat, so corners have different inclinations...
                      City Gen Street generator by Thomthom ?
                        roland joseph
                        I do many streetscapes. I don't really understand the dialogue here. The example you provided is completed quickly with tools-on-surface. I see you already use TOS so now I'm really confused....Do you use TOS or soap skin?...hmmmm. Yes I'm totally lost now. Oh but wait! The title of the post is about making faces..... there is no face making required to complete the streets. Yikes!! I better leave 😆
                          roland joseph
                          sorry...forgot this image..
                          and this link to some rendered examples.
                          http://ibuildmodels.com/JMC/SF/streets_four_profiles.html
                            AcesHigh
                            not sure... it was discontinued 6 years ago... does it even works on non planar lines? (like lines created with ToS over a mesh?)
                            Roland Joseph, from your images, it seems you only work with VERY planar streetscapes.
                            you mean, getting a terrain and just drawing the streets over it? Hmmm... nope. It results in sideways sloped streets and plenty of totally irrealistic bumps on streets and sidewalks. ToS does not generates surface meshes or faces anyway.
                            I use Soap Skin to generate meshes from contours.
                            Be them contours like the ones I showed on my skp (as I mentioned, I had the STREETS but the city blocks were only HOLES between the streets. I used Soap Skin to generate those meshes that are the city blocks... already included in the file) or be for example terrain around a house, where I will draw a line around the house, walls, etc and generate the terrain.
                            http://i.imgur.com/9YARRkv.jpg
                            • BoxB
                              I'm not understanding what it is you want to do but I think you should be looking at sandbox tools.
                              You can create terrain from contours and then manipulate it, stamp it, drape it ....
                                Maybe a "quadrangular" mesh subdivision ?
                                • mogrenM
                                  mogren
                                  [attachment=0:3ali03kb]<!-- ia0 -->grid.jpg<!-- ia0 -->[/attachment:3ali03kb]
                                  Hi!
                                  Very fine rendering!
                                  What method do you use ?
                                  • K
                                    Kenny
                                    I agree with Box, the Sandbox tool should be fine for the example shown with the house.
                                    For creating roads on a terrain the following script is very useful:
                                    http://www.valiarchitects.com/subscription_scripts/instant-road-nui
                                    http://www.townscapesolutions.co.uk/
                                      roland joseph
                                      No...I live in Ontario. There is no flat ground in Ontario anywhere.....sorry Windsor is flat.
                                      No, you need to start with a relatively accurate mesh.
                                      The roads can be contoured and flattened as per drawings manually with a projected image as a guide before you start building road mesh.
                                      Just like building on the site. Once you have a road bed you can cut the roads in easily.
                                      This example would represent a more typical street contour in Ontario.... http://ibuildmodels.com/JMC2/beaverton/intersections.html
                                      All of it with TOS.
                                        roland joseph
                                        Lumion....very tough work flow....those images took between 3-4 seconds to render.. 😆
                                          AcesHigh
                                          They charge too much for a subscription based script, no matter how wonderful it is.
                                            AcesHigh
                                            All of it with TOS.
                                            now, this is a very nice example with realistic terrain.
                                            it would be awesome if you could show your workflow, from autocad drawings to the modelling of the streets and sidewalks, etc.
                                            as I gather...
                                            1 - you create a terrain from the elevation lines.
                                            2 - you project an IMAGE of the project (including cities, etc) over the terrain, so you can flatten some surfaces for roads, etc. Can you give some more details on this workflow? Do you use the standard SKP terrain tools or Artisan?
                                            3 - you use ToS to draw the streets, sidewalks, over the terrain, which is already painted with the image of the project, making it easy to paint it. (why you use ToS instead of DRAPING the DWG streets, etc?)
                                            4 - you extrude stuff up (or maybe down, if you do with the streets) with Joint Push Pull?
