    Drawing Sphere with ruby
    2 Posts 2 Posters 1.1k Views 2 Watching
      kmk111890
      Hello. I've ever downloaded a ruby creates box automatically on this site. With this ruby, I would like to develop coding to create sphere shape too. I guessed adding radius was all task but didn't work. please fix errors.
      ` require 'sketchup.rb'
      def create_sphere
      @radius = 0.feet if not @radius # along Green Y axis
      prompts = ["radius", "R", "G", "B"]
      values = [@radius, @R, @G, @B]
      results = inputbox prompts, values, "Sphere"
      return if not results
      @radius, @R, @G, @B,= results
      model = Sketchup.active_model
      model.start_operation "Sphere"
      ents = Sketchup.active_model.definition.add
      center = [0, 0, 0]
      radius = @radius
      circle = ents.entities.add_circle center, [0, 0, 1], radius
      circle_face = ents.add_face circle
      path = ents.add_circle center, [0, 1, 0], radius + 1
      circle_face.followme path
      ents.erase_entities path
      circle_face.material=Sketchup::Color.new(@R, @G, @B)
      circle_face.material.alpha = 0.3
      status=model.place_component(ents)
      Sketchup.active_model.active_entities.add_instance(ents, trans)
      model.commit_operation
      if( not file_loaded?("Sphere.rb") )
      utilities_menu = UI.menu("Plugins").add_submenu("Sphere")
      utilities_menu.add_item("Sphere") { create_sphere }
      file_loaded("Sphere.rb")`
        slbaumgartner
        See comments regarding various errors:
        def create_sphere
        model = Sketchup.active_model # why keep switching between model and
        Sketchup.active_model?
        compdef = Sketchup.active_model.definitions.add # needed 's'
        multiple places show confusion between an Entity and its Entities collection
        ents = compdef.entities
        center = [0, 0, 0]
        radius = @radius
        circle = ents.add_circle center, [0, 0, 1], radius
        assign these right away - the followme will destroy the original circle_face
        Color.new needs integers not strings
        circle_face.material=Sketchup::Color.new(@R.to_i, @G.to_i, @B.to_i)
        place_component activates the Tool to manually place a
        ComponentInstance via GUI
        add_instance explicitly places one via Ruby
        You probably don't want to do both?
        #status=model.place_component(compdef)
        need to create trans before you can use it! This creates an identity,
        which adds the instance at the model origin
        trans=Geom::Transformation.new
        Sketchup.active_model.active_entities.add_instance(compdef, trans)
        Also, you should isolate your code in a module so that the method does not go into the global namespace.
