    Translation, French / English
    7 Posts 5 Posters 698 Views 5 Watching
    • TNTDAVIDT Offline
      TNTDAVID
      Hello,
      I is currently developing a new plugin for creating PVC windows, wood and aluminum.
      I need to translate my Plugin in English, some technical words are not found in my lexicon 😞
      So I create this topic to ask for help with the friendliest of you.
      This topic will be a reference for all those who wish to apply for assistance for difficult word translations.
      First word I want to translate is: " Soubassement de fenêtre "
      http://www.menuiserie-le-maur28.com/images/fenetres-volets/fenetres-pvc/fenetres-pvc6.jpg
      What exact word, for define this element in a windows ?
      I certainly would other technical words to translate.
      If I find help, I would come here for my questions 👍
      Thank you in advance.
      Best Regards
      David Barros
      [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
      • F Offline
        fred.dy
        en Français on appelle aussi ," jet d'eau " alors peut-être "water jet"
        • TNTDAVIDT Offline
          TNTDAVID
          The closest word I have found is : "Bottom Panel"
          I'm not sure it matches the most accurate translation, but I have no choice.
          Thank you anyway.
          Best Regards
          David Barros
          • Bryan KB Offline
            Google Translate says literally, "basement window"
            • TNTDAVIDT Offline
              TNTDAVID
              In technical terms, we can not do to google translation confidence. 👊
              • V Offline
                VJsku
                'Bottom Panel' describes it adequately for me.
                  It is either a 'solid-pane', or a 'panel' or a 'solid-panel' or an 'infill-panel' or a 'spandrel-panel' or just a 'spandrel'.
                  A pane is usually 'glass', but it may be obscure or a solid material too.
                  The latter 'spandrel' terms are the most 'architectural' terms - at least in the UK.
                  Its modern construction usage is not the same as its original meaning - referring to the triangular part of a wall above a stone arch - it was expanded last century to include any solid parts forming fenestration, and even the open parts in the sides of framed bridges...
                  Comme "panneau d'allège" ?
                  The prefix 'bottom' is only needed to clarify its location, or differentiate it from other panes/panels in the same frame..
                  A 'spandrel' like that can be located within multiple holed frame - at the bottom, at the top, or anywhere in between...
                  A 'spandrel' is more usually in a fixed frame.
                  If a similar infill is used in a hinged door or an opening window sash it is more likely to be referred to as a 'panel'.
