    [Plugin] Custom Toolbars Plugin
    121 Posts 43 Posters 76.4k Views 43 Watching
      Jim
      Ah, it opens the dialog when loose geometry is selected. I had selected a Group. Thanks.
      • Bob JamesB Offline
        Bob James
        Tried both 'standard' plugin location and additional location.
          Jim
          Hello Bob,
          1. You need to install TIG's Purge All plugin.
          2. I thought I trapped that error.
          Will look into it. Thanks for taking time to report.
            Jim
            Bob, I posted a new version this morning in the Plugin Store, but didn't have time to mention it. Did you find and try the update?
            You still need to install TIG's purge_all plugin for the custum button to work.
            • dereiD Offline
              derei
              The "viewRedo" message for Sketchup.send_action, seems unimplemented in API and not present in standard Camera toolbar, but is available in Camera drop-down menu. May be just an omision from Trimble, or it was intended to not be available? Any reasons for that?
              I remember a time when it was, and I had it on my Custom Toolbar.
              DESIGNER AND ARTIST DEREI.UK
              • Dan RathbunD Offline
                Dan Rathbun
                Yes it was removed in SU2013 or SU2014 (can't remember which.)
                SketchUp used to remember a whole bunch of camera views, and the "viewUndo:" button would go backwards in the stack. The "viewRedo:" button would go forward in the stack.
                Now only the current and previous views are saved. The "viewUndo:" ("View Previous") button just switches between them.
                I don't remember why they said the memory stack was removed. We didn't like the change at the time. Could be that in practice not many used the feature, ie only went one view back, etc. Or they were just simplifying the codebase.
                Hmmm.. thinking more,... I think the change had to do with avoiding ViewObserver crashes or complexities.
                I'm not here much anymore.
                • dereiD Offline
                  derei
                  I see, thanks for clearing it out. For me was a very good asset. It didn't remembered too many views. I think it was about 5. But it was helpful when experimenting with views, for rendering. Sometimes I just wanted to see if another view was better, but then, I decided to go back... Now I'll just have to stick to the current limitations.
                    Dan Rathbun
                    There might be some plugins... someone made a Camera Memory plugin I think.
                    • jgbJ Offline
                      jgb
                      I am almost converted to SU-15 from SU-8.
                      I just realized that many of my SU-8 toolbars (especially "toggle/hidden") are not native SU but within Toolbars.rb.
                      How can I import the toolbars.rb set to SU-15?
                      I can't find the current file here.
                      jgb
                        glro
                        http://sketchuptips.blogspot.com.es/2008/06/custom-toolbars-release-08-06-01.html[/anchor]
                        i don't remember well, but i use it in SU15, and it seems to me no changes were needed from SU8
                          driven
                          A few posts above and over a year ago...
                          You should get that version, and add updated additional plugins to it...
                          • jgbJ Offline
                            jgb
                            Thanks for the replies.
                            Yesterday I just copied the toolbars .rb and Dir from SU-8 to SU-15. Worked no problem. ๐Ÿ‘
                            I just reinstalled via Extension Mgr the (perhaps) updated version and noticed my toolbars were exactly the same. Yes, I changed the file type from ZIP to RBZ. ๐Ÿ˜’
                            In the web page (noted above) one of the standard toolbars (Scenes) has an extra icon that my installed version does not. Did I do something wrong? ๐Ÿ˜•
                            Oh, and what are these other plugins to be added to it are you referring too?
                            jgb
                              driven
                              @jgb said:
                              In the web page (noted above) one of the standard toolbars (Scenes) has an extra icon that my installed version does not. Did I do something wrong? :?
                              your probably missing the 'Bottom' view?
                              Possibly the code has change for it and you haven't actually updated or Jim left it out of the update...
                              The whole point of custom toolbars is it lets you add other plugins to the toolbar, if you have no extra's then doing nothing is fine...
                              • jgbJ Offline
                                jgb
                                When I get a chance I will compare the scripts of my SU-8 Toolbars to SU-15 and get back here with the findings.
                                jgb
                                • jgbJ Offline
                                  jgb
                                  I just compared the Toolbar files for SU-8 and SU-15.
                                  They are identical.
                                  The Toolbar.rb is...
                                  *require "sketchup"
                                  require "extensions"
                                  path = File.join(File.dirname(FILE), "toolbars", "files", "loader.rb")
                                  ext = SketchupExtension.new("Custom Toolbars", path)
                                  ext.description = "Loads your custom Toolbars."
                                  ext.creator = "Jim Foltz jim.foltz@gmail.com"
                                  ext.copyright = "2008 Jim Foltz"
                                  ext.version = "2008-04-04"
                                  Sketchup.register_extension ext*
                                  Is there anything more recent?
                                  jgb
                                    driven
                                    ***** v1.5.2 - Mar 24, 2014
                                    Catch LoadErrors - New menu to "Show Errors"
                                    v1.5.0 - Mar 22, 2014
                                    Added commands PurgeAll, CloseActive, and CloseAllActive. Note: PurgeAll requires TIG's PurgeAll plugin to be installed.
                                    Added images for SU 2104
                                    List all Commands in Plugins > Custom Toolbars menu
                                    Internal reorganization
                                    Test on Windows, SU versions 8, 2013 & 2014
                                    v1.4.0 - Mar 16, 2014
                                    First release to PluginsStore***
                                    Yes, the one in the Plugin Store...
                                    • jgbJ Offline
                                      jgb
                                      My error was installing "toolbars" and not the newer renamed "jc-toolbars".
                                      I deleted the old toolbars and all is now well.
                                      Thank again. ๐Ÿ‘ ๐Ÿ‘
                                      jgb
                                      • jgbJ Offline
                                        jgb
                                        Other than the day I installed the toolbars, I haven't used SU-15 till yesterday.
                                        When it powered up I noticed 2 toolbars were missing of the 3 I use (the Scenes and the one with hide/unhide icon). I checked, and it was active in extensions, but the TB's themselve were not in the List Toolbars.
                                        I reinstalled but no change. Searching I found the JF-Toolbars menu with the "Show Errors"
                                        This is the output.....
                                        *cannot load such file -- purgeall.rb
                                        C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:119:in module_eval' C:/SketchUp 15/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                        (eval):2:in block (2 levels) in <module:CustomToolbars>' C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:119:in module_eval'
                                        C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:119:in block (2 levels) in <module:CustomToolbars>' C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:104:in foreach'
                                        C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:104:in block in <module:CustomToolbars>' C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:100:in each'
                                        C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb๐Ÿ’ฏin <module:CustomToolbars>' C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:51:in module:JF'
                                        C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:49:in <top (required)>' C:/SketchUp 15/Tools/extensions.rb:197:in require'
                                        C:/SketchUp 15/Tools/extensions.rb:197:in load' C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars.rb:33:in register_extension'
                                        C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars.rb:33:in <module:CustomToolbars>' C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars.rb:23:in module:JF'
                                        C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars.rb:22:in `<top (required)>'*
                                        I noted above that I need to load "Purgeall.rb" but it was not there when I first installed and it worked OK.
                                        Why would I need it when the problem occurs before any model is loaded? Only my template is up.
                                        Edited
                                        Just installed Purgeall but no change to toolbars. ๐Ÿ˜• Error message is gone. ๐Ÿ‘
                                        jgb
                                        • deaneauD Offline
                                          deaneau
                                          hello,
                                          how look a ruby-snipped to have a plugin with an icon?
                                          some developer have only plugins that's work in menue. ok i could add short-cuts for this, however sometimes i would have a toolbar with all my most used plugins together.
                                          • jgbJ Offline
                                            jgb
                                            Kinda wondering why no response to my last post. โ“ โ“
                                            I just deleted the toolbars dir and .rb and reinstalled.
                                            No errors.
                                            No toolbars.
                                            I looked at the Toolbars dir and the TB's I wanted were not there.
                                            I looked at my SU-8 TB dir and there they were.
                                            Copied both missing TB txt files over and now I have my TB's.... finally. โ˜€
                                            jgb
                                            • 6 / 7
