    [Plugin] Custom Toolbars Plugin
    121 Posts 43 Posters 80.8k Views 43 Watching
      Jim
      @box said:
      I'm a bit confused Jim, Make component is available in your toolset.
      Perhaps the question is what Key stroke is Make Component, the default for that is g.
      Heh, so it is. it's called "makeComponent" of all things.
      Unfortunately, it uses a send_action which does not appear to work in SketchUp 2014.
      • BoxB
        Works perfectly in my version of 2014.
          Jim
          Ah, it opens the dialog when loose geometry is selected. I had selected a Group. Thanks.
          • Bob JamesB
            Bob James
            Tried both 'standard' plugin location and additional location.
              Jim
              Hello Bob,
              1. You need to install TIG's Purge All plugin.
              2. I thought I trapped that error.
              Will look into it. Thanks for taking time to report.
                Jim
                Bob, I posted a new version this morning in the Plugin Store, but didn't have time to mention it. Did you find and try the update?
                You still need to install TIG's purge_all plugin for the custum button to work.
                • dereiD
                  derei
                  The "viewRedo" message for Sketchup.send_action, seems unimplemented in API and not present in standard Camera toolbar, but is available in Camera drop-down menu. May be just an omision from Trimble, or it was intended to not be available? Any reasons for that?
                  I remember a time when it was, and I had it on my Custom Toolbar.
                  DESIGNER AND ARTIST DEREI.UK
                  • Dan RathbunD
                    Dan Rathbun
                    Yes it was removed in SU2013 or SU2014 (can't remember which.)
                    SketchUp used to remember a whole bunch of camera views, and the "viewUndo:" button would go backwards in the stack. The "viewRedo:" button would go forward in the stack.
                    Now only the current and previous views are saved. The "viewUndo:" ("View Previous") button just switches between them.
                    I don't remember why they said the memory stack was removed. We didn't like the change at the time. Could be that in practice not many used the feature, ie only went one view back, etc. Or they were just simplifying the codebase.
                    Hmmm.. thinking more,... I think the change had to do with avoiding ViewObserver crashes or complexities.
                    I'm not here much anymore.
                    • dereiD
                      derei
                      I see, thanks for clearing it out. For me was a very good asset. It didn't remembered too many views. I think it was about 5. But it was helpful when experimenting with views, for rendering. Sometimes I just wanted to see if another view was better, but then, I decided to go back... Now I'll just have to stick to the current limitations.
                      • Dan RathbunD
                        Dan Rathbun
                        There might be some plugins... someone made a Camera Memory plugin I think.
                        • jgbJ
                          jgb
                          I am almost converted to SU-15 from SU-8.
                          I just realized that many of my SU-8 toolbars (especially "toggle/hidden") are not native SU but within Toolbars.rb.
                          How can I import the toolbars.rb set to SU-15?
                          I can't find the current file here.
                          jgb
                          • G
                            glro
                            http://sketchuptips.blogspot.com.es/2008/06/custom-toolbars-release-08-06-01.html[/anchor]
                            i don't remember well, but i use it in SU15, and it seems to me no changes were needed from SU8
                              driven
                              A few posts above and over a year ago...
                              You should get that version, and add updated additional plugins to it...
                              • jgbJ
                                jgb
                                Thanks for the replies.
                                Yesterday I just copied the toolbars .rb and Dir from SU-8 to SU-15. Worked no problem. ๐Ÿ‘
                                I just reinstalled via Extension Mgr the (perhaps) updated version and noticed my toolbars were exactly the same. Yes, I changed the file type from ZIP to RBZ. ๐Ÿ˜’
                                In the web page (noted above) one of the standard toolbars (Scenes) has an extra icon that my installed version does not. Did I do something wrong? ๐Ÿ˜•
                                Oh, and what are these other plugins to be added to it are you referring too?
                                jgb
                                  driven
                                  @jgb said:
                                  In the web page (noted above) one of the standard toolbars (Scenes) has an extra icon that my installed version does not. Did I do something wrong? :?
                                  your probably missing the 'Bottom' view?
                                  Possibly the code has change for it and you haven't actually updated or Jim left it out of the update...
                                  The whole point of custom toolbars is it lets you add other plugins to the toolbar, if you have no extra's then doing nothing is fine...
                                  • jgbJ
                                    jgb
                                    When I get a chance I will compare the scripts of my SU-8 Toolbars to SU-15 and get back here with the findings.
                                    jgb
                                    • jgbJ
                                      jgb
                                      I just compared the Toolbar files for SU-8 and SU-15.
                                      They are identical.
                                      The Toolbar.rb is...
                                      *require "sketchup"
                                      require "extensions"
                                      path = File.join(File.dirname(FILE), "toolbars", "files", "loader.rb")
                                      ext = SketchupExtension.new("Custom Toolbars", path)
                                      ext.description = "Loads your custom Toolbars."
                                      ext.creator = "Jim Foltz jim.foltz@gmail.com"
                                      ext.copyright = "2008 Jim Foltz"
                                      ext.version = "2008-04-04"
                                      Sketchup.register_extension ext*
                                      Is there anything more recent?
                                      jgb
                                        driven
                                        ***** v1.5.2 - Mar 24, 2014
                                        Catch LoadErrors - New menu to "Show Errors"
                                        v1.5.0 - Mar 22, 2014
                                        Added commands PurgeAll, CloseActive, and CloseAllActive. Note: PurgeAll requires TIG's PurgeAll plugin to be installed.
                                        Added images for SU 2104
                                        List all Commands in Plugins > Custom Toolbars menu
                                        Internal reorganization
                                        Test on Windows, SU versions 8, 2013 & 2014
                                        v1.4.0 - Mar 16, 2014
                                        First release to PluginsStore***
                                        Yes, the one in the Plugin Store...
                                        • jgbJ
                                          jgb
                                          My error was installing "toolbars" and not the newer renamed "jc-toolbars".
                                          I deleted the old toolbars and all is now well.
                                          Thank again. ๐Ÿ‘ ๐Ÿ‘
                                          jgb
                                          • jgbJ
                                            jgb
                                            Other than the day I installed the toolbars, I haven't used SU-15 till yesterday.
                                            When it powered up I noticed 2 toolbars were missing of the 3 I use (the Scenes and the one with hide/unhide icon). I checked, and it was active in extensions, but the TB's themselve were not in the List Toolbars.
                                            I reinstalled but no change. Searching I found the JF-Toolbars menu with the "Show Errors"
                                            This is the output.....
                                            *cannot load such file -- purgeall.rb
                                            C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:119:in module_eval' C:/SketchUp 15/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                            (eval):2:in block (2 levels) in <module:CustomToolbars>' C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:119:in module_eval'
                                            C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:119:in block (2 levels) in <module:CustomToolbars>' C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:104:in foreach'
                                            C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:104:in block in <module:CustomToolbars>' C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:100:in each'
                                            C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb๐Ÿ’ฏin <module:CustomToolbars>' C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:51:in module:JF'
                                            C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars/files/loader.rb:49:in <top (required)>' C:/SketchUp 15/Tools/extensions.rb:197:in require'
                                            C:/SketchUp 15/Tools/extensions.rb:197:in load' C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars.rb:33:in register_extension'
                                            C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars.rb:33:in <module:CustomToolbars>' C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars.rb:23:in module:JF'
                                            C:/Users/jgb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jf_custom_toolbars.rb:22:in `<top (required)>'*
                                            I noted above that I need to load "Purgeall.rb" but it was not there when I first installed and it worked OK.
                                            Why would I need it when the problem occurs before any model is loaded? Only my template is up.
                                            Edited
                                            Just installed Purgeall but no change to toolbars. ๐Ÿ˜• Error message is gone. ๐Ÿ‘
                                            jgb
                                            • 6 / 7
