    [Plugin] Set North in Free version
    22 Posts 11 Posters 27.0k Views 11 Watching
    • irwanwrI Offline
      irwanwr
      πŸ˜† sorry people. i was wondering.
      since in the SketchUp 8 Free version it seems that the "set north angle" doesn't work.
      unless i missed something there.
      that's why i've been wandering around the Plugin Index. looking for something to replace that Pro feature for the Free version.
      it's quite tiring now, to set latitude and longitude manually every time and then realising that you need to rotate the whole model to adjust the position for the correct illustration.
      any info or hint? thank you.
      [ed] thank you, andy. πŸ‘ no, i didn't see that. it's a link with not much of description what it was πŸ˜› .. but, that's look like it. funny though i visited Jim's site for his cline before πŸ˜„
      erm... but Jim said there;
      • This plug-in was made for SketchUp version 6 Free because it lacked the dialog (which Pro had) to change these settings. This has become obsolete since SU 7.
      what's that supposed to mean? i am planning to use only SU 8 now.
        I do not know about Didier's plugin (never used) but yes, Jim's plugin works in SU 8 free, too.
        • irwanwrI Offline
          irwanwr
          @jim said:
          I need to advertise more.
          Plugin: Model Location
          * This plug-in was made for SketchUp version 6 Free because it lacked the dialog (which Pro had) to change these settings. This has become ...
          (sketchuptips.blogspot.com)
          now, i understand what was that supposed to mean
          Jim should've make that Model Location instead πŸ˜†
          thank you andybot, Thomas, and Csaba πŸ˜„
          • andybotA Offline
            andybot
            In SU7 free, you could set the north direction (like the plugin does,) which Google then took away in the SU8 free version... it's only available in SU8 pro
            • irwanwrI Offline
              irwanwr
              hi everyone,
              i am back. Didier's and Jim's plugin both works well in SketchUp 8! πŸ˜„
              with Didier's "Set North" i can change the north angle orientation. and
              with Jim's "Model Location" i got the full feature of geolocation
              sorry for rushing around and replying without even checking what others have to say up there. especially Jim's and Fletch's post.
              you people couldn't stop to amaze me yet with this forum πŸ˜„
              i regret those days -erm.. years- without SketchUp 6 and this forum πŸ˜›
              SketchUp 8.0.4811 currently.
                Didier has agreed that I might update some of his scripts in the PluginStore.
                This is an oldie but it now compatible with all SUp versions [useful in Free/Make where there is no Geolocation...] http://sketchucation.com/pluginstore?pln=gs6_north
                  ssw
                  I am using SU 8 free. I am trying to install a plugin that allows me to change north.
                  Tried Jim's plugin (http://sketchuptips.blogspot.com/2008/01/plugin-model-location.html), but it requires inputbox.rb which is not available on jim's site.
                  I get a message "works on free version only" when I tried Didier's plugin
                  Any help greatly appreciated
                    I you install the latest version of Didier's tool it does NOT give a message box with that message !
                    Please get the RBZ that contains the latest version from the Download link button in the recent post [or even the first post] - it's in the SCF PluginStore !
                    The old RB file in the first post IS out of date [as it says]...
                    The new version works in all SketchUp versions...
                      robinpecha
                      Hi, great tool, but...
                      Im using last version available in PlayOnLinux tool which is Google Sketchup 8.0.15158 free.
                      After installation plugin works.
                      But from first restart of application it allways show:
                      "Error Loading File gs6_north.rb
                      undefined method `file_loaded?' for DBUR:Module"
                      I must erase plugin manualy. And each time I wont set north, Im installing plugin, setting and then erasing.
                        @robin
                        Thanks for the bug-report.
                        Here's an updated version. http://sketchucation.com/pluginstore?pln=gs6_north
                        That load error is now corrected.
                        It only occurred if you had no plugins loading beforehand which might have required 'sketchup.rb' - needed for the 'file_loaded' methods...
                        It was a simple oversight by Didier, which I hadn't noticed when I changed it for him to make it compatible with all SketchUp 'free/make' versions... πŸ˜’
                          robinpecha
                          It works, it works!
                          Great.
                          • 2 / 2
