    Frigate model
    27 Posts 13 Posters 4.7k Views 13 Watching
    • DanielD
      Daniel
      fantastic job, cotty.
      My avatar is an anachronism.
      • hellnbakH
        hellnbak
        @cotty said:
        @hellnbak said:
        Do you have a source for reference photos, or at least a more specific description to do some research on it?
        As far as I know it is called Frigate "Chapman 40"...
        Thanks.
        I found the PDF's but apparently he didn't take it any further than you did
        I was hoping for something that I could use to maybe finish the model, guess I'll have to do some more digging.
        • hellnbakH
          hellnbak
          Also found a site where you can download the files necessary to create the frame on a CNC machine
          http://www.john-tom.com/FrameKits.html
          it's the second model down
          For several years I programmed horizontal CNC mills, I loved those machines and always wanted to have a small one for myself. It's on my bucket list somewhere πŸ˜’
          • I
            imabzeous
            this is beautiful? which software you used for rendering
            • cottyC
              cotty
              Thank you, Daniel.
              Oh yes, I know what you mean...
              Thank you, I've used Indigo Renderer.
              my SketchUp gallery
              • Bryan KB
                Excellent model, but what happened to the fregate? πŸ˜‰ (just kidding)
                • cottyC
                  cotty
                  Thank you. Fregate was killed by Box πŸ˜‰
                  my SketchUp gallery
                  • ken28875K
                    ken28875
                    great model and render, Carsten! πŸ‘ πŸ‘
                    have a good weekend!
                    _KN
                    Follow Your Dreams.
                    • LA_RR_ArchitectL
                      LA_RR_Architect
                      A fascinating model.
                      I've struggled with wooden ship models in AutoCAD, which I suspect many of you know has a fairly unfriendy interface, but does have the ability to manage fairly complex splines in 3d space.
                      How do you create the complex curves needed with Sketchup?
                      Jim
                      • cottyC
                        cotty
                        I've used some plans like those showed by Hellnbak here, imported them (PDF -> Inkscalpe -> DXF-> SU) and improved the lines with Fredos Curviloft. After that, some pushpulls and moves and it was finished...
                        my SketchUp gallery
                        • BoxB
                          Have you used Fredo's Bezier Spline tools.
                          http://sketchucation.com/pluginstore?pln=BezierSpline
                          • hellnbakH
                            hellnbak
                            So that's what that does! Heck, I may have to give that a try πŸ˜›
                            • HornOxxH
                              HornOxx
                              Grossartig - sorry, GREAT !!!
                              πŸ˜„
                              never trust a skinny cook
                              • cottyC
                                cotty
                                Dank you πŸ˜‰
                                my SketchUp gallery
                                  What is Inkscalp: inkscape ? πŸ˜„
                                  Very cool model! 😎
                                  A cool list of boat building program! πŸ˜‰
                                  • hellnbakH
                                    hellnbak
                                    Just curious -
                                    I know nothing about ship construction, but wouldn't the ribs need to be tapered to allow for proper attachment of the hull planks?
                                    • LA_RR_ArchitectL
                                      LA_RR_Architect
                                      Yes, absolutely.
                                      However, the ribs typically are cut and erected square and hand reshaped prior to the attachment of the planking. Very often ships were planked (or "ceiled") inside as well so they would be tapered on both sides.
                                      Jim
