    Choosing a Graphics Card
    17 Posts 9 Posters 5.7k Views 9 Watching
    • GaieusG
      Here is a poor fellow with a new laptop and an Intel HD chipset with 128Mb RAM only ๐Ÿ˜ฎ
      http://www.google.com/support/forum/p/sketchup/thread?tid=4abe0fc92fd68ad9&hl=en
      Now he was sold this laptop and now he is surprised that he cannot even launch SU. The system requirements explicitly say that you need a dedicated, OpenGL compliant card with minimum 256 Mb but ideally minimum 512 Mb memory. You can get a decent card like that for around $ 100 nowadays. Spending around $ 1,000 on a computer but saving this $ 100 will end you up with a "Facebook machine".
      • sketch3d.deS
        sketch3d.de
        @mitcorb said:
        Many cards support DirectX and OpenGL, but to varying degrees, depending on the versions of each of these, and what portions of each they address.
        SU uses, as allmost all common 3D modelers (besides Autodesk & Alibre modelers), OpenGL currently in old revision 1.5. Therefore no need for a video card of the CAD series, e.g. nVidia Quadro FX or AMD/ATI Fire Pro.
        @mitcorb said:
        You can get a real headache looking at the data regarding shaders and such.
        in the context of output speed of display transformations (zoom/move/rotate etc.), the vertex throughput of the tesselation engine is most/solely important.
        the nVidia Geforce series has proven, at least in the past, to provide a faster and more stable OGL support , at least under Windows, than the ATI Radeon series.
        Norbert
        • AnssiA
          Anssi
          IMO, if you don't need blistering game performance, and you can afford it, using a Quadro doesn't hurt either. Lately we've seen some problems with the consumer Nvidia cards (mouse trails, for example) so their drivers aren't always what they should be.
          Anssi
          • dereiD
            derei
            I found this and I think it worth to be taken into consideration:
            SketchUp's performance relies heavily the graphics card driver and it's ability to support OpenGL 1.5 or higher. Historically, people have seen problems with Intel based cards with SketchUp. We don't recommend using these graphics cards with SketchUp at this time.
            From here: http://sketchup.google.com/support/bin/answer.py?hl=en&answer=36208&ctx=cb&src=cb&cbid=13fp8xnotzfsv&cbrank=1
            DESIGNER AND ARTIST DEREI.UK
            • sketch3d.deS
              sketch3d.de
              @anssi said:
              IMO, if you don't need blistering game performance...
              the horsepower of the GPU can be of course used for 3D modelers too.
              @anssi said:
              ...and you can afford it, using a Quadro doesn't hurt either.
              sure but regularly doesn't show any advantage for low-/mid-end modelers at the same time being much more expensive if the same hardware level, i.e. GPU, is desired.
              drivers are obviosuly more consumer orientated (games) but the next driver release might fix these issues already.. until then, switching off the fast feedback option should cure this annoyance.
              Norbert
              • utilerU
                utiler
                I haven't seen much here in the way of opinions of the latest system specs for use with SU [we're in the market for another computer so I thought I'd put it out there]
                Specs we're looking at are:
                i7-4790 3.6GHz CPU
                Corsair VS 650W PSU
                16GB Ram
                Leadtek Quadro K620 2GB GPU [been recommended this one as they've come down in price and are built for CAD / modelling apparently]
                Seagate 1TB HDD
                Samsung EVO 250GB SSD
                Windows 8.1 64Bit
                Be good to hear any opinions of whether we go to 32GB Ram, Quadro cards; are they really going to be better than a Ge Force GTX 970 or 980...?
                Thanks in advance fellas! ๐Ÿ‘ ๐Ÿ‘
                Just Curious...
                • jujuJ
                  juju
                  the workstation graphics cards are great, if your software can take advantage of it, generally this means there is a special driver for the software
                  if there is no special driver for the software, there will be no real benefit, in fact you could have better performance from a "gaming" graphics card using that software
                  I suggest visiting the workstation graphics card website and checking if there are any enhancements for the software you use, else I would l would be inclined to stick to a good "gaming" graphics card
                  just because it is built for CAD/CAM doesn't mean the software you use will run better/faster
                  • sketch3d.deS
                    sketch3d.de
                    no, especially the slow Quadro K620. Go for a GeForce GTX 750Ti (in the same price range) or better: GTX 960 -> GTX 970 -> GTX 980
                    16 GB work memory is more than enough for SU besides you have another memory cosuming app running as e.g. a renderer or image processor or video editing.
                    the 840 Evo has some speed issues with files not touched for a while, Samsung plans to fix this soon but with the 850 Pro you would be on the safe side.
                    Norbert
                    • utilerU
                      utiler
                      Thanks juju, the only software we use is SketchUp. No other CAD programs at all.
                      So I would expect that a good gaming card would be the way to go then?
                      Just Curious...
                      • utilerU
                        utiler
                        Norbert
                        Thanks Norbert, much appreciated!
                        Just Curious...
                        • sketch3d.deS
                          sketch3d.de
                          go for a MSI or Asus w/ a twin cooler.
