    Adding attributes help
    29 Posts 8 Posters 2.8k Views 8 Watching
      lothcat
      @kwalkerman said:
      in your latest example, you would read the attribute as follows:
      face.get_attribute("agw_attributes", "location)
      That was crashing my plugin. So I changed it to value1 = model.get_attribute("agw_attributes", "location") - and it's returning a blank.
      There is no reason this line of code wouldn't work, right? So my attributes really aren't being applied after all?
        When you use set_attribute(...) it applies it to the specified entity AND it's only attached to that entity [or later copies of it].
        Your earlier code attached the attribute to a face... so when you run model.get_attribute(...) it quite rightly returns nil because you haven't attached that attribute to the model ??
        You can attached an attribute to a model BUT your code is attaching it to a face.
        You need to find some faces and then iterate through them and use face.get_attribute(...) on each in turn and get their attributes ???
        • Dan RathbunD Offline
          Dan Rathbun
          @lothcat said:
          @dan rathbun said:
          If you are on Sketchup 8, you should be seeing errors generated in the console.
          You DO have the console open when your debugging.. right?
          Of course I do, but no errors. However, I'm using Sketchup 7, so that might be why.
          IF your on Sketchup 7.x (7.1M2) Free, there is no reason why you should not update to Sketchup 8.0M1 Free (as it costs you nothing.) The lastest MR of ver 8 has many fixes (including for the 'infamous' shadow bug,) that you will wish to take advantage of.
          In addition, there are quite a few API fixes.
          But one of the most important from the standpoint of Ruby coding, is that ver 8+ ships with a Ruby v1.8.6-p287 interpreter. All ver 7 Sketchup releases ship with the old obsolete initial release of Ruby v1.8.0(-p0) that has bugs in it, and many missing methods.
          At the very least.. you can update the ver 7 interpreter DLL (if your on PC,) to the same version and patchlevel as is distro'd with Sketchup 8.x; read instructions in this post:
          Ruby Interpreter DLLs (Win32).
          I'm not here much anymore.
            lothcat
            You're right, that was stupid. I have it fixed now. Thanks!
              lothcat
              OK, so, now that I have that figured out, I'd like to know if there's a way to tell if a face is vertical or horizontal. It seems like face.plane would do that, but I've found frustratingly little about how plane works.
              I'm not sure of the board etiquette. Should I post this question as a new topic, or is this OK?
                If it stops here no new topic needed... but if you want to talk about faces some more make a new topic...
                Rather than face.plane try face.normal - that's the vector perpendicular to a face.
                So if face.normal==Z_AXIS [or [0,0,1]] it's facing vertically up or face.normal==Z_AXIS.reverse [or [0,0,-1]] if facing straight down.
                To test it a face is 'vertical' try if face.normal.z==0 - that is true as the normal has no element in the vertical [z].
                With a bit of thought you can contrive other tests - e.g. if face.normal.y.abs != 1 is true if the normal doesn't face exactly in either of the Y/green axes direction - i.e. it faces in any direction except directly to the front or back...
                  lothcat
                  Thank you!
                  • eneroth3E Offline
                    eneroth3
                    @dan rathbun said:
                    No don't do that [make a hash into an array], you lose your keys!
                    Make your hashes into strings with hashstr = hash.inspect()
                    Save the hashstr into the dictionary.
                    To read, get the hashstr from the dictionary.
                    Then hash = eval(hashstr) to convert it back.
                    I really wouldn't save a ruby string as an attribute and later eval it. It opens up for code injection and lets people run whatever malicious code they want on someone else's computer just by sending them a model made to take advantage of this vulnerability and wait for the moment where eval is called.
                    My website: http://julia-christina-eneroth.se/
                    • tt_suT Offline
                      tt_su
                      +1 eval = evil
                        driven
                        'he's good bad', but he ain't evil!
                        I tend to agree with this**[anchor= goto=http://www.infoq.com/articles/eval-options-in-ruby:2ingvk9h]article[/anchor:2ingvk9h]**...
                        eval has it's uses, that's why it's there...
                        • eneroth3E Offline
                          eneroth3
                          I tend to agree with this**[anchor= goto=http://www.infoq.com/articles/eval-options-in-ruby:13hbt2pf]article[/anchor:13hbt2pf]**...
                          There are cases where it's fine to use. I use it myself in my attribute editor plugin for instance to let people assign things such as 1.m or Sketchup.active_model.selection.first.length to an attribute. However executing code saved in a model opens up for people to forge an evil model that causes the code to be executed without the user knowing about it.
                          Also arrays are allowed and can be used instead of hashes when it comes to just serializing data.
                            slbaumgartner
                            I agree with Julia. Using eval is a bit like owning a pet tiger: you have to be careful what you put in the cage with it!
                            • tt_suT Offline
                              tt_su
                              Yea, like you wouldn't feed raw user data to your database, you don't want to feed user data to eval. (I consider anything read in from the system or file to be "user data"). Validate and sanitize - this is the stuff you want to find a library that has solved all the edge cases for you.
                              • 2 / 2
