    Covering a 3D terrain model with a 2D image
    11 Posts 2 Posters 553 Views 2 Watching
    • O Offline
      olso5345
      Hello All,
      I have a 3D terrain model with surface in SU v8 created from 1 meter contours. I have a 2D jpeg of an image pasted to a plane floating right above the 3D terrain model. The 2D image is positioned and scaled just about right; above the 3D landscape beneath. I want to lay this jpeg on the surface so it hugs the contours. I have found a few suggestions on how to do this but I can't make it work. Any thoughts would would be greatly appreciated. I could upload the SU model - but it's a bit big (28MB). Is that too large to try to upload here?
      Thank you! Cheers, Jeff
      • cottyC Offline
        cotty
        28 MB is too big to upload it here directly. You can check if you can reduce the file size by purgin the model or you can upload it somewhere else (e.g. dropbox) and share the link.
        You have to change to "projected texture", sample that texture and apply it to your terrain surface.
        my SketchUp gallery
        • O Offline
          olso5345
          Hi Cotty,
          Thank you for your response! I tried the projected texture - I first selected the jpeg plane, clicked the "eye dropper" in the materials browser, sampled the jpeg plane, and then touched the landscape 3D beneath. It seems as though it painted the landscape with an average color of the jpeg above - it painted the whole landscape a muddy green - whereas the jpeg above (a landscape architectural rendering) was full of lots of colors....Any thoughts on what I did wrong?
          I'll see if I can get dropbox up and running to share a link...
          Best, Jeff
          • cottyC Offline
            cotty
            You can start with a screenshot that shows the problem...
            my SketchUp gallery
            • O Offline
              olso5345
              Screen Shot 2015-03-08 at 12.49.07 PM.pngCotty,
              Not sure if this screenshot will help - the 2d image is fairly close to the 3D model beneath, so a bit difficult to see the 3D landscape below.....
              • cottyC Offline
                cotty
                Make sure that your terrain edges are smooth so that you are able to paint all faces at once with a single click.
                my SketchUp gallery
                • O Offline
                  olso5345
                  Thanks Cotty,
                  I will try that. The 3D terrain is a component currently. Should I explode that before I paint it?
                  • cottyC Offline
                    cotty
                    You don't need to explode it, but you should edit it for texturing!
                    my SketchUp gallery
                    • O Offline
                      olso5345
                      Hello Cotty,
                      Here is a dropbox link to the SU file:
                      Dropbox - Error - Simplify your life
                      (www.dropbox.com)
                      Cheers,
                      Jeff
                      • cottyC Offline
                        cotty
                        I've edited the terrain component and applied the projected texture without any problem...
                        my SketchUp gallery
                        • O Offline
                          olso5345
                          Cotty,
                          Thank you!! You are a gentleman and a scholar! I was able to reproduce your excellent results. This has, with your help, suddenly become a great day. Cheers, Jeff
