    Inverted funnel - what are the steps?
    4 Posts 2 Posters 1.0k Views 2 Watching
    • G
      Gebda
      I tried to roll the sphere around the vertical line, but I couldn't create the inverted funnel as shown at the picture. Could anybody help what are the basic steps to create the same model, which is represented at the picture?
      Thank you very much in advance.
      inverted funnel
        How about this?
        Profile centered on a circle.
        Select circle.
        Get the Follow Me tool.
        Click on the profile.
        • G
          Gebda
          Hi Dave R!
          I tried out your tips, and it absolutely works. πŸ˜„ Thank you very much for your quick answer. I would like to ask another big request. I tried to design lightning protection system with SketchUp. The result, which I would like to reach the so-called protected zone (please the enclosed picture). If I draw a normal building (rectangular floor area for example 40 m length, 20 m width and 20 m height), it's possible that could you write the basic steps (the best if you could show with print screens) how to design the lightning protection system's protection area for the building with Sketchup?
          I used Autocad before for this function (design the protection area), but I would like to use this designing at SketchUp as well.
          Thank you very much for your helpfulness in advance and I'm waiting your answer.
          Design LPS with SketchUp
            How do you determine the shapes of the curves? Are they catenaries? If so, you might use the Wire Tool plugin to draw them. Or you might use the Bezier Curve tool from Fredo's Bezier Spline set. Then use Curviloft or TIG's Extrude Edges by Rails to make the surfaces.
            I'm not able to provide screen shots at the moment so hopefully this will do.
