    Export selection as jpg?
    6 Posts 3 Posters 516 Views 3 Watching
    • john2J Offline
      john2
      Is there a plugin that enables me to export a selection as jpg image?
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
      • sdmitchS Offline
        sdmitch
        This should do it.
        mod = Sketchup.active_model
        ent = mod.active_entities
        sel = mod.selection
        vue = mod.active_view
        ent.each{|e| sel.toggle e}
        tmp = sel.to_a;sel.clear
        tmp.each{|e| e.hidden=true}
        vue.zoom_extents
        vue.write_image "test.jpg"
        tmp.each{|e| e.hidden=false}
        vue.zoom_extents
        http://sdmitch.blogspot.com/
        • john2J Offline
          john2
          Plugin ruby file.. How can I make from this?
          Sent from my IQ 446 using Tapatalk
            You don't need to.
            Just copy+paste all of those lines in one go, into the Ruby Console + <enter>
            On MACs or PCs using at least v2014 multi-line entries are allowed.
            • sdmitchS Offline
              sdmitch
              As simply as wrapping it in a def and end statement and copying it to the Plugins folder. Hiding/un-hiding can be a little slow.
              module SDM
               def self.expsel2jpg
                sel = mod.selection
                @name ||= "expsel2.jpg"
                inp=UI.inputbox(["Image Name;"],[@name],"Export Selection to jpg")
                if inp
                 @name=inp[0];@name += ".jpg" if File.extname(@name)==""
                 Sketchup.set_status_text "Toggling the selection";vue.refresh
                 Sketchup.set_status_text "Hiding non-selected";vue.refresh
                 vue.zoom_extents
                 vue.write_image @name
                 Sketchup.set_status_text "Un-hiding non-selected";vue.refresh
                 vue.zoom_extents
              UI.menu("Plugins").add_item("Export Selection to jpg"){SDM.expsel2jpg}
                Not forgetting... that the file you add into the Plugins folder, must be called something like " SDM-expsel2jpg**.rb**" - in order for it to auto-load as SketchUp starts... AND also, equally importantly, it must be encoded as " UTF-8_without_BOM".
                On a PC - Notepad.exe will NOT do this - it will be encoded as ANSI, this will break SketchUp >v8 !
                But if you have a free tool installed like Notepad++.exe - then that will either encode its as you need [depending on the app's settings], OR you can at least change the file's encoding to suit using menu items.
                On a Mac, TextEdit/ TextWrangler should pre-encode the file as you need...
