    Double Line From Single Line
    8 Posts 5 Posters 681 Views 5 Watching
    • H Offline
      harnstein
      Hey,
      is there a way to get a double line from a single line, e.g. for window seperation?
      If you have only some divided faces you could use offset or multi-face offset.
      I'd like to have two lines (maybe set distance in advance) generated from one line which if possible which overlapping part is cut off at the next intersection and the former line is removed...
      still sketchin'
      • ely862meE Offline
        ely862me
        There was a same question sometime ago, and the answer is no, there is nothing like that yet, in the plugins list.
        Elisei (sketchupper)
        Come and See EliseiDesign
        • BoxB Offline
          Didier's Double line tool will do it for you.
          http://sketchucation.com/pluginstore?pln=dline2
          • H Offline
            harnstein
            Thanks, I'll check that.
            Came across Didiers double line tool during research but thought it would be something like a wall tool.. Should have looked closer!
            still sketchin'
              In some case TIG 2D Tools can help you! 😉
              Copy first the segment by + CTRL
              Then Call the Plug et voilà! 🤓
              • JQLJ Offline
                JQL
                Is this what you want? I use it daily and assigned it Shift+D as a shortcut. For me it's the plugin that made me the jump from 2D design with CAD to Sketchup...
                Edgetools2 Divide Faces by Thomthom
                Edgetools 2 Inspect tool, by the way, it's also a fundamental plugin for SectionCutFace inspection and 2D DWG/DXF import.
                I hope this helps and best regards,
                João
                www.casca.pt
                Visit us on facebook!
                  Damned, forgotten this ultra powerful one! 😳 💚
                  • JQLJ Offline
                    JQL
                    I know... it's just I use it as often as pushpull if not even more...
                    www.casca.pt
