    Tgi3D SU Amorph - SU2014
    34 Posts 12 Posters 7.4k Views 12 Watching
    • KrisidiousK
      Krisidious
      If you're in a project I suggest going back to 2013 in sketchup, you can still use layout 2014 if you like.
      By: Kristoff Rand
        maleemk
        Layout ??????, they are totally different. What are you talking about, I am talking about TGI PhotoScan we have brought it separately.
        • KrisidiousK
          Krisidious
          The original thread was about having tgi3D run on SU2014. I suggested that if you are in the middle of a project you should revert to 2013 until it's done. The reason I brought up Layout was that you could still use Layout 2014 if you used SU2013 to build it.
          I'm sorry I didn't understand what you were meaning. I guess you were just using this thread to speak to the plugin representative about your own authorization issues? If so carry on...
          By: Kristoff Rand
            maleemk
            Well If the Authorization Server is not working, then I will not work in any SU be it ver. 2014 or 2013 or SU8
              jonb42
              If anyone from Tgi3D is reading this please check or fix the support email from your site - I've been trying to contact for a number of days... thanks!
              Jon
                muddpuddle
                Is Amorph still being worked on for SU2014? No updates that I've seen here on the forums or on the TGI3D website...
                Hope to see it updated some day soon.
                • micioneM
                  micione
                  It seems that they are not very interested in updating.
                  (The last visit of "gulcanocali" to this forum, dates back to April 21.
                  probably, he will read these posts in December ...).
                    muddpuddle
                    Sadly, there is finally an update for Amorph and SU2014. However, I have moved on to the 64-bit SU 2015...
                    Amorph for SU 2015??? I check the website once in a while just out of curiosity.
                      Why not keep the 2014 & 2015 ? πŸ˜‰
                      • sicksickisckS
                        sicksickisck
                        tgi3d 64 bit ?! anyone ?! it's neverending story hehe... tgi3d need some big refreshment 😎 πŸŽ‰
                        • sicksickisckS
                          sicksickisck
                          the new tgi3d born! [2015-07-17] 1.32 but don't work for me πŸ‘Š 😞
                          sketchup 2015
                          • KrisidiousK
                            Krisidious
                            Is it free now?
                            By: Kristoff Rand
                              There is a "training version" with a limited number of vertices! πŸ€“
                              Works fine for me in 2015! πŸ˜„
                              • Bob JamesB
                                Bob James
                                All of links to the tutorials are broken πŸ‘Ž
                                • sicksickisckS
                                  sicksickisck
                                  πŸ‘Š Pilou, do you have that free version of tgi3d? my version still don't work 😞 ; I have that amorph commercial ver ...RUBY SUX
                                  tutorials for tgi3d πŸ˜‰ https://www.youtube.com/results?search_query=tgi3d
                                    Yes! πŸ€“
                                    Maybe your problem comes from the Windows' Path Install!
                                    During the Install there is a button for change the Path Plugin!
                                    (not possibility for me to use it, maybe that was because I was not yet registered)
                                    In any case I don't use it and all was installed like a charm! πŸ€“
                                    And at the end you must registered even using the free version, because you have the interface but all icons are not clickable! πŸ€“
                                    Works fine for me! 😲
                                    http://www.tgi3d.com/index.php?Page=AmorphVideos%26amp;Type=Feature
                                    • sicksickisckS
                                      sicksickisck
                                      for me too ;in all versions of tgi3d πŸ˜•
                                      • sicksickisckS
                                        sicksickisck
                                        free version work for me hahaha.. commercial not at fukin all πŸ‘Ž
                                          muddpuddle
                                          I can't even get the free version to work. Every version fails to install.
                                          It works! Thank you Tgi3D πŸ˜›
                                          • sicksickisckS
                                            sicksickisck
                                            commercial version work for you?
