Selection Box Does not appear when I click and drag the...
Good day! I am new to Sketchup 2015 and I am just shocked why no "temp" box appears when i click and drag the mouse pointer on objects. Is this new? I simply do not like this feature if yes. Please, someone enlighten me.
So to sum up my issue is about:
- selection box (with broken box not showing)
Also, if someone could please point me to a software that is free that makes .dxf exports from sketchup (which could only be surfaces, right?) be converted to solid. And I need these to be accessible in CAD. Thank you.
I am using,
- Sketchup 7
- Sketchup 2015 Trial
- Autocad 2013 LT
LT does not have 3D powers so I can't do much.
Please help
- Hon
The invisible selection box isn't a feature as you assume. It has to do with the OpenGL settings on your computer. Go to Window>Preferences>OpenGL and untick the box for Use Hardware acceleration. Click OK and then quit and restart SketchUp. Do you see the selection box after doing that?
