    Changing Dimension Type
    3 Posts 2 Posters 453 Views 2 Watching
    • O
      Otis
      Hi all,
      I'm using Sketchup 2015 Pro. Typically I always use inches, but on a recent drawing I changed it to Feet/inches for the builder at his request.Now a few months have passed and it's time to do the job. For the life of me I can't remember how I changed the settings.I have the template set to inches, so I must have somehow only changed the way the dimension tool works.How can I return it to inches only?
      • Wo3DanW
        Wo3Dan
        Menu Window > Model Info > Units > change to inches.
        Your default template may be a different one from settings the file is saved with.
        Fresh ones start with the template you have set SU to. Then you can still change any settings you like. So you can change back to inches only as mentioned above.
        • O
          Otis
          Ah yes, that was it! Had it set to architectural, not fractional.
