    Need help on using components to create steel structure
    23 Posts 7 Posters 3.2k Views 7 Watching
    • jeff hammondJ
      another idea roughly based around yours.. if you go this route, i think you'll get more usable space inside the volume?
      then balconies could extend out to the steel etc.. might be sweet. (or, the entire volume could extend out to the steel instead of the (close to) hexagonal shape shown here? more of a circular building or even a square could fit inside there )
      as far as using components goes (at least using sketchup definition of a component), this -or similar- is the route you'd have to go.. the outer structure consists of only a handful of pieces which then repeat a bunch of times..
        martynaaas
        Thanks for the effort but in terms of design, I'm not changing anything. As I mentioned in my original post, this was a small project (2 weeks) and now we're asked to draw a technical section of it. I know it could be improved a lot and there's pretty much no design in this structure but that's what I've got.
        Continueing topic about components, I kind of like your first try and was wondering did you draw that from scratch or can the same pattern (curved white lines) can be applied to any surface?
        I'm not looking to improve this in anyway, all I want is to somehow find an easy way of drawing double-curved elements that would follow surfaces of my building. Basically, turn the mass into steel structure.
        • jeff hammondJ
          from scratch.. with surfaces which are a lot more receptive to having an array applied to them..
          if you look at your surfaces, there are lines going every which way when in reality, those lines should be your underlying 'grid' to accept the components.
          hmm. yeah, i know i'm not going to be able to explain it properly but the easiest way is to start over with better surfaces.. subsequent operations on those surfaces will then be easy instead of how they are now, you're going to be fighting/hacking it the rest of the way through.
          idk.. search the extension depositories for 'lines2tubes' or similar.. then just draw some lines using your surfaces as some sort of guide then tube the lines.
            martynaaas
            Well, I'll try changing soap skin into those interactive surfaces tomorrow, see how it goes. Thanks for your effor anyways guys.
              martynaaas
              So I redrew one of the walls using curviloft and created this grid with more or less correct amount of segments. The question is, what is the quickest way of changing all those line into components? It will not let me turn it into components for some reason, and drawing pipes for each one of those will take forever. Any suggestions?
              http://i.imgur.com/64TJgx1.jpg
                driven
                that looks like a small enough file to post...
                did you try tubes2lines plugin on of the wireframe model?
                  martynaaas
                  Sketchup would just crash. I assume the previous curviloft plugin uses a lot of lines to create a face and sketchup runs out of memory to draw a cylinder around every one of them. I tried welding the lines, it didn't work either.
                  • BoxB
                    Is this the type of thing you are trying to achieve?
                    Rail.skp
                      martynaaas
                      [attachment=1:3ahf283s]<!-- ia1 -->Rails.JPG<!-- ia1 -->[/attachment:3ahf283s]
                      [attachment=0:3ahf283s]<!-- ia0 -->Latt.JPG<!-- ia0 -->[/attachment:3ahf283s]
                      Cant open file since it's saved in 2015 but from screenshots looks exactly what I was trying to achieve in the first place. Maybe I would just change the number of segments/lines going across but overall I like the result. Could you explain how you did it?
                      • BoxB
                        I took the major lines from your model and created a clean solid of the building.
                        Then I used Tig's Extrude Edges by Rails to Lattice (Part of Tig's Extrusion tools) to create the grid lines. Then I used Lines2tubes to create the net structure.
                        It up to you how many lines you delete from the lattice and what you do with them, but the main thing is to start with a clean structure that has smooth lines with matching segmentation.
                        By the way, a simple Purge of your 45mb model dropped it to around 20mb. You have loose hidden geometry all over the place and you have raw geometry on a layer other than layer0, never do that. I got lost trying to find my round in it, you even have geometry that is hidden that I couldn't even work out how to get it unhidden. To be honest it's a real mess.
                        So I've made you a quick one with some parts as an example and saved it as SU8.
                        Twist Tower SU8.skp
                          martynaaas
                          Thank you!
                          For the organisation of the file, I have to agree that it was pretty messy and mostly it's because of lack of time. It was done very quickly and I wasn't hoping to do anything else with it so I just left the way it was. I do have to agree that organised file makes your workflow much easier.
                          Thanks again, not only for giving the solution but also explaining the process and giving some tips. Didn't know you have such great community here πŸ˜„
                          EDIT: One quick question: how did you turn that messy structure into solid mass?
                          • BoxB
                            Laboriously! You were lucky it was too hot to go outside with a hangover today.
                            I exploded your model down to raw geometry removed all the loose junk floating about, got rid of all the layers and preloved components and moved everything to layer0. You must have had some clipping issues going on because you had bits of stuff a long way from the origin.
                            Once it was a coherent lump of geometry I picked out the major edges and pasted them into a new model. Once there I was able to repair the broken edges and remove the lonely vertices, eventually getting some consistent curves. Those curves I then smoothed, cleaned up and adjusted the segmentation with a combination of Curvizard and Polyline Segmentor and brute force.
                            When I finally had the proper structural edges I was able to use Extrude edges by rails to produce the faces cleanly. Once you have all the faces you explode them and group them and if done correctly you end up with a solid.
                            That solid then become the basis for the rest of your designwork and should never be edited directly. It is the master from which you can always go back to to get something. Make it a component and file it away and only use copies of it.
                              martynaaas
                              Wow, I'm pretty lucky indeed. I knew I'm not using SU to it's full potential but I never even thought of such workflow and will definetely follow this way. I did actually had terrible clipping issues which were unknwown for me and just had to be ignored to due short terms.
                              The way I came up with this design is just ridiculous when I think of it. I did it with Rotate and Scale, then used some soapskin to create lots of bugged faces which I then replaced with more unnecessary lines.
                              I'm thanking you for your rich insight not only on my problem but my general skills and ways of improving it. I never used this forum before and I already learned what seemed such a huge thing to do at first. Thank you guys for sharing your knowledge!
                              • BoxB
                                I'm glad we got you moving in the right direction.
                                • jeff hammondJ
                                  haha. nice
                                  • pbacotP
                                    Box, I got some files for you to fix up. Will PM soon....πŸ˜„
                                    • BoxB
                                      Sure, no problem, you have the sacks full to send along with the files I assume, I don't accept firstborns these days, too much trouble.
