    Problems with a half-torus
    156 Posts 11 Posters 16.5k Views 11 Watching
    • BoxB Offline
      Have a go with Thomthom's new Solid Inspector, it will find them, highlight them and fix them for you.
      http://sketchucation.com/pluginstore?pln=tt_solid_inspector2
      • TeigT Offline
        Teig
        Thanks again Box, downloaded and installed. One thing that's bugging me, how much to donate for these plugins? I am grateful for them but have stalled on donating for this reason.
        The Solid inspector can't fix my item "Some errors could not be automatically fixed. Manually inspect and correct the errors, then run the tool again." Something about borders and mesh?
        And now my .skp file is too large to upload... πŸ˜•
        • BoxB Offline
          Donations are something different for everyone, "to each according to his need" is the old saying, whatever you feel comfortable with, nothing is too small or large.
          Have you purged your model, it may be bloated. Window/Model Info/Statistics Purge unused.
          • TeigT Offline
            Teig
            OK, I'll settle on something for a donation.
            I have purged it but it's not having it.
            The bad news now is my MBP has run out off power and I forgot to bring my charter in to work this morning, also all the servers are offline for the office computers so no more Sketchup for me for know, phone only 😞
            • TeigT Offline
              Teig
              Stuck again! πŸ˜•
              I seem to have an odd edge and I'm not sure how to get rid of it. Also strange faces inside the model. The file is too large for the SU forum here so I have loaded it to Drive, this is the link for it if anyone can help?
              Page Not Found
              Web word processing, presentations and spreadsheets
              (drive.google.com)
              • BoxB Offline
                You've got a few odd things going on in there.
                The first one, simple error, you triple clicked on the surface and made everything a group, problem is the inner tube isn't connected to the outer surface so it didn't get selected. So it's not part of the group.
                The second and more troublesome thing is somehow you have produce an overlap in your throat, and some extra faces.
                If you look inside near the drill holes you can see the double edges and twisted lines.
                I've given you a cleaned one for comparison.
                BellmouthSolid.zip
                • TeigT Offline
                  Teig
                  [attachment=2:2922mkxr]<!-- ia2 -->Innertube.JPG<!-- ia2 -->[/attachment:2922mkxr]
                  [attachment=1:2922mkxr]<!-- ia1 -->Inside.JPG<!-- ia1 -->[/attachment:2922mkxr]
                  So is the best way to select to group is to drag the select tool around the whole entity rather than triple click? Would that have selected everything?
                  Those troublesome things have been keeping me awake all night πŸ˜„ Did you just go inside and erase them Box? I don't know what or why that strange triangle of faces on the throat was there. πŸ‘Ώ
                  • BoxB Offline
                    Normally a triple click is good, just that in this case the inside tube is separate, so it sort of a case by case thing, depends what is you are selecting.
                    Yes I basically just remove all the overlapping geometry and lofted the gap. So it's not actually how you made it originally.
                    Looking at yours again I see you have drawn your profile in various sections, lots of different curves with varying sized segments and stuff. I have taken your profile and drawn a smoother set of curves roughly to fit to give you a less bumpy finish.
                    Also look at how many segments you want to use. In the actual throat you want a lot for smooth airflow, but the ring and the inner ring can have fewer segments and the outside of the throat under the ring can be a rough as you want.
                    In this quicky I have used 50 segments for the curve of the inner throat, 24circle for the rim and only 12 for the back. Then a 50s circle for the follow me.
                    I'm not suggesting you use it, just showing you some examples.
                    Quick throat.skp
                    • TeigT Offline
                      Teig
                      [attachment=0:8f6audq7]<!-- ia0 -->Throat.JPG<!-- ia0 -->[/attachment:8f6audq7]
                      So, would dragging the selector around the whole model have selected that inside tube?
                      Yes, I've been trying to get the throat super-smooth so have been using 100 segments as standard, never considered anything else for the other parts - I suppose using less segments would keep the file size down?
                      Yes, I drew it as best I could think how to, complete with lots of scratching of the head and "argh, must put this away and come back later before my brain explodes" moments πŸ˜„
                      • BoxB Offline
                        Yes
                        and
                        yes
                        My profile is simply 2 circles and 2 arcs with a couple of straight lines.
                        Takes longer to type than to draw.
                        • TeigT Offline
                          Teig
                          Thanks again Box, I'll see if I can do it like you say, it might be the other way round for me though - longer to draw than to type πŸ˜„ I'm really struggling with drawing two components and then lining them up exactly so I'll have to do a bit more learning in that area.
                          • BoxB Offline
                            But it's really just one piece, extend your profile and then make the cut outs.
                            This is very rough but it should show you what I mean.
                            • TeigT Offline
                              Teig
                              I've no idea how you do those gifs but that is very helpful. The holes do have to be pretty precise so I'd have to measure them in. I'll have another go later.
                              One thing strikes me in that gif, when you use the Follow Me tool do you only need to indicate a circle, any size of circle? Or does that circle have to be my 45mm radius?
                              • BoxB Offline
                                Any circle will do, the radius is immaterial, but the center of the circle must be at the correct distance from your profile to be the right size, and the number of segments needs to be what you want.
                                The circle is simply creating a rotation point and segment count for follow me.
                                You'll notice the circle is still there after the follow, it is below not touching anything, so I could use it again to add another ring around the first one.
                                • BoxB Offline
                                  In fact you could then scale that circle into the oval that you want and it will be centered on the throat. pop your holes in it and pull it up to intersect with the throat and remove the unwanted bits.
                                  • pbacotP Offline
                                    Following. The point about the circle: keep one circle for your reference below everything. Copy it if you must but don't have the follow-me circle touching the model, and don't throw it out until you are absolutely done modeling. I suspected intersecting with that circle was a problem on your latest try.
                                    Also you guys are showing a torus floating inside the shape. Don't you have to get rid of that? Or will it print as a void?
                                    • cottyC Offline
                                      cotty
                                      @teig said:
                                      And the scale tool. Sorry for sounding stupid but if I scale it by a 1000x what do I sale by to get back to my dimensions?
                                      Thanks.
                                      In fact, I made a component and scaled up a copy of that component. If you look at the image carefully, you can see the 1000 times smaller original component at the origin πŸ˜‰
                                      With this technique (lets call it DaveRs technique), you can delete the big one and stay with the parallel modified small original without the need to scale down again.
                                      my SketchUp gallery
                                      • TeigT Offline
                                        Teig
                                        So how will I set the radius of the throat at 23.2mm?
                                        Sorry? Do you mean the radius of the 'lead' circle has to be the correct outside radius, i.e. 45mm in this case?
                                        I understand the principles of the 'DaveR technique', I'll practice it.
                                        • TeigT Offline
                                          Teig
                                          Up until this version with the 'internal torus' I have been running the Follow Me from a model-touching circle of the radius I wanted, it was a big moment when I had that idea and it worked, up until your statement above I have been assuming that was the ticket to success.
                                          I assume the inner torus will be printed albeit with support structures which (the idea is) will be lighter than printing it in solid plastic. Then again, I know nothing! πŸ˜›
                                          • pbacotP Offline
                                            Me too, Teig--I am learning about printing only from forums like this...
                                            Sometimes followme is best when the profile is right on the path shape. In the case of a circle (flat in the X-Y plane), it doesn't matter. The point is, you don't want the circle intersecting with your complex model, and the circle as a guide may continue to be helpful.
                                            I think Box means that the distance from the CENTER of the guide circle must be correct to where you have located the followme profile (in the x-y) plane. It doesn't matter what the radius of the guide circle is, unless you were using it as part of the model. The number of segments is important, and depends on the number of segments you want in the model.
                                            • 5 / 8
