    From evermotion to sketchup
    8 Posts 3 Posters 1.7k Views 3 Watching
    • T
      tr000tyl
      Hello there.
      I am new in here ๐Ÿ˜„
      Does anyone know how can I import models prepared by evermotion team to sketchup with all textures?
      Is there any possibility?
      Also is there any plugin for sketchup like multiscatter or forestpro (3ds max)?
      Regards
      Bart
      • KrisidiousK
        Krisidious
        Evermotion models are very high poly... will probably not do well in SketchUp. If you want to use them, you'll need to open them in max and export in a format used by sketchup such as .3DS or .OBJ.
        By: Kristoff Rand
        • T
          tr000tyl
          I have a Sketchup 2015 Pro 62 bit version and there is no possibility to import OBJ ๐Ÿ˜ž
          Also I can't export in .3ds because model has too many faces.
          Is there any other solution?
          I've tried to import model as a vray proxy - everything is ok but sketchup miss materials ๐Ÿ˜ž
          Also I tried to use collada format - but I have message in sketchup: "import filed" ๐Ÿ˜ž
          • KrisidiousK
            Krisidious
            There's an Obj importer plugin.
            404 Not Found
            (sketchucation.com)
            By: Kristoff Rand
            • T
              tr000tyl
              I tried to export simple teapot with 4 segments from max to sketchup as a OBJ format.
              But when I imported the OBJ file the teapot has a missing faces.
              • yorik1984Y
                yorik1984
                http://www.simlab-soft.com/3d-plugins/SketchUp-from-3DS-main.aspx
                • T
                  tr000tyl
                  Ok Thanks
                  I used this plugin and exported 3d model.
                  When I open exported model it doesn't show all materials. Why?
                  I think the best and the fastest solution for the high poly models is using the proxy.
                  But proxy doesn't have vray materials ๐Ÿ˜ž
                  One more time - I want to import 3d model from 3ds max to sketchup with all vray materials with all maps like bump, opacity, diffuse etc. (from vray for 3ds max). Is it possible?
                  • yorik1984Y
                    yorik1984
                    http://www.scriptspot.com/3ds-max/scripts/vray-material-to-standard-material
                    I use for SU this method to convert model from evermotion
                    http://blog.turbosquid.com/2013/08/29/converting-max-vray-materials-to-standard-materials/
