    [Plugin] Boolean helper update 08122011
    77 Posts 15 Posters 47.8k Views 15 Watching
      Well if it did work every time you erased something you'd get the messagebox...
      The EntitesObserver is known to be buggy... if we did get it to work and erased an entity within it it'd probably crash anyway - so my snippet probably wasn't the best idea πŸ˜’
      How about using a selectionObserver...onBulkChange() - you select the things and then erase them and the selection changes... and then looking at model.entities if no [1] and [0] meets test erase it ...
      http://code.google.com/apis/sketchup/docs/ourdoc/selectionobserver.html
      • liquid98L
        liquid98
        I updated the booleanhelper plugin! Please see the first post of this topic.
        Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
          driven
          hi,
          I believe I just exposed a bug, doing another testhttp://forums.sketchucation.com/viewtopic.php?f=180&t=38858&p=354541#p354541
          when I have 'auto paint tool' Mac preference set, your twee tekst and LEEEEEG message boxes pop up every time I select or delete something even though I wasn't using your tool.
          appears to be "Sketchup::SelectionObserver" related.
          I'd rather use this then that, but I'd like the option of both...
          cheers
          • liquid98L
            liquid98
            Hi John,
            Just download and install latest version -see first post of this topic.
            Good luck!
              driven
              cheers,
              I'll let you know if I have any issues,,,
              • C
                CT4
                Thank you Thank you Thank you. I model small parts for RC aircraft and run into so many problems when I try and lathe them or intersect them. This fixes all of the problems.
                • liquid98L
                  liquid98
                  It's always nice to hear that my script helped you out! Apparently it works also on a Mac; never tested it πŸŽ‰ πŸŽ‰
                  • cottyC
                    cotty
                    Thank you for this helpful plugin!
                    my SketchUp gallery
                    • sboupS
                      sboup
                      @liquid98 said:
                      This is my modest contribution to the community:
                      Booleanhelper
                      The Boooleanhelper plug-in lets you quickly scale up and down your model.
                      This is especially useful for those people who use Sketchup for 3d printing.
                      Performing boolean operations or lathe operations on small models (mm size) is problematic in Sketchup, because Sketchup doesn't handle small faces very well.
                      By scaling up the model these problems disappear. After all operations are done
                      you can scale down your model to its original dimensions.
                      Also useful to close small holes in your model.
                      Your opinions and suggestions are welcome!
                      Features:
                      • Visual feedback on scale-factor.
                      • Scale down at once.
                      • It is possible to save your work, and scale down later. (feedback not yet provided)
                      • Auto zoom extents.
                      Installation:
                      Open the zipfile and copy booleanhelper.rb and the folder called Booleanhelper into the SU plugins directory.
                      Have fun!!
                      If you have problems with unsolicited messageboxes, please download the latest version below:
                      Wonderfull. Thanks β˜€
                        Aggertroll
                        I love this script - does exactly what it is supposed to (on my Mac) and lets me design small parts for 3D print in a larger scale. Very helpful - thanks!
                        I have one small comment/request: I am using Fredo6's "!Additional.Pluginfolders" plugin to sync my plugins via dropbox across my different machines - great help by the way. I noticed that the icon in the toolbar will not show for the Boolean helper if that plugin resides in my plugin folder on dropbox; it must be looking for the icon in the standard plugin folder. Is there a way to fix that? As in "Get the image from the folder Booleanhelper in the same folder that this script is in" - if that makes sense?
                        There are of course simple ways to fix this - install Booleanhelper on all machines - but the fix would remove a glitch when using a custom plugin folder. Thank you for your efforts!
                          driven
                          @aggertroll said:
                          There are of course simple ways to fix this...
                          change line 296 in a plain text editor, and re-save...
                                  plugins = Sketchup.find_support_file("Plugins")
                          to
                                plugins = File.dirname(__FILE__)
                            Aggertroll
                            John: Thanks a bunch. Works!
                            • B
                              Boff
                              Hi, I don't know if this plugin is still being worked on but I'm unable to scale down a model after saving it.
                              The message I get is "Scale up your model first, and then use the 'Scale down at once' button"
                              Using SU2016 if that makes a difference.
                              • 4 / 4
