    [Plugin] MakeWindow v0.1
    17 Posts 11 Posters 25.6k Views 11 Watching
    • C
      caddict
      Hi Shaun
      I've been working with your window script. It is useful and quite flexible. A few questions/comments:
      I don't get the interior/exterior idea? how do i easily unite the interior and exterior parts? why not make the whole window as one entity?
      the window is created inside a section of wall. this could be useful but maybe not necessary...what's your thinking behind this?
      not sure what you mean by cladding...do you mean architrave? that surrounds the window? If I set clad width to zero, it gives a strange result...an unwanted face appears across the whole window
      If you haven't lost interest, it is a useful tool and it would be great with a little fine tuning.
      hope it's useful feedback
      steve
        Jim
        Where is $exStrings defined? I must have moved the file. I think a lot of people just copy it blindly, and it just works for most users.
          Jim
          Thanks Shaun.
          A couple questions:
          Why are you drawing a wall section along with the window?
          I don't see any difference in an interior and exterior window?
          Can you make it remember the previous values in the dialog?
          Here's a couple shots of the UI and the windows it generates.
          • N
            nsxdavid
            This plugin for making windows has been around for awhile, but thought I'd make an update or two.
            This version remembers dialog values between uses. Makes this much easier to experiment with.
            A couple notes:
            The only difference between an interior and an exterior version fo a window seems to be how it names the component and the materials it creates. I guess so you can paint them differently (which makes sense, I suppose). Because it remembers dialog values now, it's easier to create the opposite version.
            This works with SketchUp 7.1 without modification, by the way.
            -- David
            makewindow.rb
            • troyhomeT
              troyhome
              thanks!
              IOviz.com
              SU Pro 2024 PC
                3eighty
                A big thank you..Now maybe I can see my soul...
                  dkapotov
                  Hello.
                  This plugin doesn't work in SU2015
                    I just installed it from the RBZ in v2015 and it worked fine... [PC]
                    It appears under the Draw menu...
                    I would expect it to also work on MAC - the code is relatively simple and not OS-dependent ??
                    What issues are you having ?
                    How did you install it ?
                    Remember that it is ~5 years old, so there might better better solutions around by now...
                      dkapotov
                      I put it into Library > Application Support > SketchUp 2015 > SketchUp > Plugins
                      but with launching SU it show mistake
                        This Plugin is > 7 years old !
                        It's no longer supported, there are probably several better things available !
                        I've updated the PluginStore version to be cross-version compatible, by removing 'string' conversions across 'locales'...
                        http://sketchucation.com/pluginstore?pln=makewindow
                          dkapotov
                          Hi TIG.
                          I try to install this plugin. Installation process done normally, but after I cannot find link in Plugins menu and in Toolbars.
                          I installed it from Preferences window and Extensions part.
                          Win7 64 Pro
                          SU2015 Pro
                          • BoxB
                            It becomes very frustrating for people who answer questions when people don't read what they say.
