Enlarge section details
Hello All,
Don't know if this is the correct forum for this question...
I'm drawing a simple roof section as shown in the attached file. As you can see, I've enlarged parts of the drawing to emphasise some details. I had to do this manually scaling up components, editing/deleting line sections, etc. Just wondering if there's a native way to do this in Sketchup. If not, is there some clever plugin that can achieve the same effect?
By the way, using Sketchup 2014 (Free).
Many Thanks,
Raymond.
Get the pro version of SketchUp and do it in LayOut. It would be ideal for that. Or use different image exports from SU and put them together in an image editor. If you're going to stick to doing it directly in SketchUp, it sounds like you've already worked out the solution.
