    Ruby code to retrive sketchup version of a model
    18 Posts 8 Posters 1.4k Views 8 Watching
      glro
      i found the code to retrieve the version of sketchup running on the computer, but i don't find anything to retrieve the version in which the model has been saved?
      is there anything?
      this would be useful to avoid processing a file that has not been saved in the current version of sketchup
      • TIGT Online
        You need to read the start of the SKP to get its version, before you try to open it or try to load it...
        This with get the SKP file's version - referenced as 'v' [string]
        vv=File.open(skp_path, 'rb'){|f| f.read }.unpack('m*').pack('m').gsub(/SketchUpModel/,'').to_i.to_s;if v=~/^1/;v=vv[0..1];else;v=vv[0];end
        It could be greatly improved, but it works - tested in v2014/v2015 !
          slbaumgartner
          I find it interesting that model#save includes an argument to tell SketchUp what format to use when saving a model, but like @glro I can find no method to determine either the format that was in effect when the file was opened nor the format used the last time it was saved. Obviously, the data needs to be in the correct form for the running version of SketchUp while in memory, but if it can be converted on load and save, shouldn't the API remember these things?
            glro
            I have to improve a lot to be able to understand such code...
            i'll try
            thank you for your quick answer
              driven
              @giro
              here's a slightly different version I use, with a bit of explanation...
                    # 'IO.read' reads the open model file's first '50' bytes
                    # which we 'unpack' from binary using 'm' however many times '*' until we get to the end
                    # we 'pack' these with 'm' to give a human readable string
                    # then we use ruby 'sub' to substitute using a Regular expression '/\D+/' any non Digits with a nothing ''
                    # of the remaining string, it's the first 2 digit we want to check '[0..1]'
                    ver = IO.read(Sketchup.active_model.path, 50).unpack('m*').pack('m').sub(/\D+/,'')[0..1]
                    # to check, we ask if the first '[0]' is a '1', if it is we use both, if not we only use it
                    ver[0].to_i == 1 ? ver ; ver = ver[0]
                    puts ver
              • TIGT Online
                I said it could be improved 😉
                  glro
                  Thank you both of you
                  my skills in ruby are very limited; using this code , i get in the ruby console:
                  "56" for a model made with SU8
                  "49" for a model made with SU13
                  it's exactly what i was looking for
                  i shall make a test and filter the skps to process according to the number i get
                  thanks again
                  @driven said:
                  @giro
                  >       puts ver
                  • TIGT Online
                    My way should return "8" or "13" ?
                    Not sure what's happening...
                      driven
                      @sam, why would it return the octal char?
                      mmm... so should mine return '8' or '13' in your case...
                      but break it down and post the result...
                      that should return the first 50bytes...
                      e.g. SketchUpModel151
                      if not try 100 for the bytes, maybe windows sees it differently?
                      • sdmitchS Offline
                        sdmitch
                        56 is the octal character value for "8" and 49 for "1". It is a function of V8 Ruby vs V14.
                        http://sdmitch.blogspot.com/
                        • sdmitchS Offline
                          sdmitch
                          As I added to my previous post, it is the difference between Ruby 1.8 and 2.0. If you run Sketchup8 and enter your code you will get 56 returned. If you change the last line to Puts ver.chr, you will get 8.
                          glro is running V8, so TIG's code should be
                          vv=File.open(skp_path, 'rb'){|f| f.read }.unpack('m*').pack('m').gsub(/SketchUpModel/,'').to_i.to_s;if vv=~/^1/;v=vv[0].chr+v[1].chr;else;v=vv[0].chr;end
                          and yours
                                ver[0].to_i == 1 ? ver ; ver = ver[0].chr
                                puts ver
                          • TIGT Online
                            As I said in my first posted code - it was only tested in Ruby2 [v2014/2015]...
                            As @sdmitch says you need to do it slightly differently in <=v2013 - the vv[0] is NOT the character as it would be with >=v2014, but the 'octal' code which needs translating with .chr...
                            For v8/2013 my version should then be:
                            vv=File.open(skp_path, 'rb'){|f| f.read }.unpack('m*').pack('m').gsub(/SketchUpModel/,'').to_i.to_s;if vv[0].chr=='1';v=vv[0].chr+vv[1].chr;else;v=vv[0].chr;end
                            Then 'v' is the version as '8', '13', '14 or '15'.
                            For Sup versions >2013 [with Ruby2] you must omit all of the .chr codes...
                              glro
                              so it is much more complex than what i thought i understood..
                              programming ruby for sketchup is a never ending game
                              thank you all for the details
                              • tt_suT Offline
                                tt_su
                                unpack("m*").pack("m") gobbles up some characters. Here's an old snippet I used in the past to sniff out the version number: (Works for Ruby 1.8 and 2.0)
                                <span class="syntaxdefault"><br />module&nbsp;Example<br /><br />&nbsp;&nbsp;def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read_skp_version</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Get&nbsp;the&nbsp;size&nbsp;of&nbsp;the&nbsp;file&nbsp;ID&nbsp;block;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">id_size&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">IO</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">unpack</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'C'</span><span class="syntaxkeyword">)[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]&nbsp;*&nbsp;</span><span class="syntaxdefault">2<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;=>&nbsp;28<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;Get&nbsp;the&nbsp;size&nbsp;of&nbsp;the&nbsp;file&nbsp;version&nbsp;block;<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">version_size&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">IO</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">4&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">id_size&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">unpack</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'C'</span><span class="syntaxkeyword">)[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]&nbsp;*&nbsp;</span><span class="syntaxdefault">2<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;=>&nbsp;20<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;Get&nbsp;the&nbsp;version&nbsp;block&nbsp;data.&nbsp;This&nbsp;will&nbsp;be&nbsp;UTF-16LE&nbsp;encoded.&nbsp;Since&nbsp;Ruby&nbsp;1.8<br />&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;doesn't&nbsp;have&nbsp;the&nbsp;encoding&nbsp;methods&nbsp;we&nbsp;hack&nbsp;it&nbsp;by&nbsp;zapping&nbsp;out&nbsp;all&nbsp;the&nbsp;zero&nbsp;bytes<br />&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;in&nbsp;the&nbsp;data&nbsp;string&nbsp;which&nbsp;will&nbsp;give&nbsp;us&nbsp;a&nbsp;regular&nbsp;ASCII&nbsp;string.&nbsp;This&nbsp;works<br />&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;because&nbsp;we&nbsp;know&nbsp;the&nbsp;version&nbsp;string&nbsp;is&nbsp;within&nbsp;the&nbsp;ASCII&nbsp;range.<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">version&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">IO</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">version_size</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">4&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">id_size&nbsp;</span><span class="syntaxkeyword">+&nbsp;</span><span class="syntaxdefault">4</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">gsub</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"\x00"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">""</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;=>&nbsp;{15.1.106}<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;#&nbsp;Extract&nbsp;the&nbsp;version&nbsp;components.<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">version</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">match</span><span class="syntaxkeyword">(/\{(\</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">+)\.(\</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">+)\.(\</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">+)\}/).</span><span class="syntaxdefault">captures</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_i&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;=>&nbsp;[15,&nbsp;1,&nbsp;106]<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br /><br />end&nbsp;</span><span class="syntaxcomment">#&nbsp;module<br /><br />#&nbsp;Example&nbsp;usage;<br /></span><span class="syntaxdefault">major</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">minor</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">revision&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Example</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read_skp_version</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
                                • Dan RathbunD Offline
                                  Dan Rathbun
                                  If the file has not yet been saved or the file does not exist, need a bailout.
                                  I'm not here much anymore.
                                  • sdmitchS Offline
                                    sdmitch
                                    Is the a .chr inverse? 65.chr returns A but what if I want the ascii code for a given character?
                                      Jim
                                      "A".ord
                                      Class: String (Ruby 2.0.0)
                                      Class : String - Ruby 2.0.0
                                      (ruby-doc.org)
                                      • sdmitchS Offline
                                        sdmitch
                                        @jim said:
                                        "A".ord
                                        (ruby-doc.org)
                                        Thanks for the info and especially the link.
