    [Plugin] Component Comparison
    62 Posts 24 Posters 53.3k Views 24 Watching
    • W Offline
      wyatt
      Thom, that sounds like it would work great, and cut several steps from my current workflow.
        guaucorreo
        excuse me,
        this plugin can´t compare similar objects with DIFERENT scale ¿is there a plugin that make that?
        thanks
        • halroachH Offline
          halroach
          Hi Thomthom,
          This plugin is great!
          Very helpful when importing lame models from Autocad and 3DSMax.
          Just a little note.
          As I was searching for this thread to see if any changes have been made, specifically wondering if detecting scaled objects will be possible (like the post above this one) - I was having a hard time finding this thread in the forums. Partly because the search engine here isn't great, but also because the name of the thread and the name of the plugin files and commands are different. In sketchup it's "replace similar objects" and here it's called Component Comparison...
          FlexTools - Super Quick Windows, Doors, Slats...
            I've had no time at all to work on this. There's much more that needs doing before even attempting to detect scaled components.
              bhbarchitects
              Thanks thomthom really cool time saver.
              How did you get on with rendering in 3ds max?
              Matt
                Piasek231
                Why plugin does not work. The example in the link:
                Thank you for the clarification.
                Regards.
                • tt_suT Offline
                  tt_su
                  hm... hard to tell without the model. But this plugin is just an experiment, not a final product.
                  One thing I did notice in your video was that when you exploded one of the faces turned white. That seemed to indicate some geometry merging happening. If that is the case and the objects doesn't have the same number of faces and vertices it won't be able to find a match.
                    Piasek231
                    Thank for Your answer.
                    The *.skp file is downloaded from this post. Any way I using Sketchup in my work (design office), I have many components and nested components in my project. Will be nice to use plugin ( like Your plugin) to unfiy components to simplify my project . Do You know some alternatif plugin? With kind regards MP.
                    • V Offline
                      vtol
                      That is back from 2011 - is the development of this plugin dead now by end of 2014?
                      I used the plugin, which picked up quite some instances but by far not all, one apparent are the wheels in this case, which are of the same geometry but just rotated
                      Before
                      http://forums.sketchup.com/uploads/default/_optimized/21e/25c/cf3d4b304b_690x361.png
                      After
                      http://forums.sketchup.com/uploads/default/_optimized/f68/a8a/4bc351e027_690x354.png
                      • cottyC Offline
                        cotty
                        There are only 8 wheels, maybe you can replace them manually?
                        my SketchUp gallery
                        • V Offline
                          vtol
                          I most certainly can, but that is beside the point, aside that the plugin missed other components as well - which is to be expected reading the status at the top.
                          The point was that rotated instances are not mentioned yet as shortfall and whether the plugin's development has ceased - in which case I am not seeing the point of being listed, in spite of the limited abilities.
                          • cottyC Offline
                            cotty
                            Didn't it work for the screws?
                            Which comment do you think will be a greater incentive for plugin authors?
                            • Thank you for the great amount of time you put into this, even if it does not cover all cases yet.
                            • "I am not seeing the point of being listed, in spite of the limited abilities."
                            my SketchUp gallery
                            • BoxB Offline
                              Hmmm, yes, I'm not sure how solving 145 components for and missing a few means it is a failure and should be removed from any "lists".
                              • V Offline
                                vtol
                                145 components is not half of the remainder (not just a few). Whilst this ratio is appreciated, and I never unvalued the amount of effort/time spent for this alpha version, it should be legitimate to ask whether there is further development (intended) or not. And if not I reckon it to be legitimate to mark any such plugin as such, or else how is the user to know?
                                  The timestamp of last update gives a good idea of the activity for extensions. Now sure what a special mark would be useful for. I've not made any concious decision that I will never update it again - in fact, I really wish I would find time. But alas time is a rare commodity these days.
                                  Removing it would probably upset more people, as there are a good number of people who swear to this extension.
                                  One thing I'd like to point out to everyone is that all my free extensions is available on GitHub or Bitbucket - open for contribution if anyone wants to make a stab at improving. It's something I've been missing in the SketchUp extension community - collaboration.
                                  • Z Offline
                                    zangetsu
                                    Hello Thomthom I have a suggestion for this plugin and I am not sure if it is possible to intergrate it into this great plugin or if there's already a plugin in existance.
                                    What I've been thinking is that you have lets say a cube and you have about 40 different types of shapes throughout your model and be able to replace these 40 shapes with that cube in just a right click.
                                    For example Having selected the 40 objects and you right click and select say (replace by) and select the cube.
                                    If this makes any sense at all.
                                      Hmm... Component Replacer?
                                        This is yet existing 😄
                                        Random Component Replacement by Sdmitch 😉
                                        (Random of a same element = Copy ! 💚
                                        • F Offline
                                          faust07
                                          Could be Faces To Components by HDPV (S4U - Huynh Duong Phuong Vi)...
                                          • gudio83G Offline
                                            gudio83
                                            is it compatible with Sketchup 2015 x64?
                                            • 3 / 4
