    Where can I find cutting Plugin Report?
    6 Posts 3 Posters 624 Views 3 Watching
      pimentapaulo
      This plugin exports and saves the components in xml. The video shows how the plugin.
      • massimoM Offline
        massimo Moderator
        This one?
        http://www.optimalprograms.com/help/cutting_optimization_pro_en/files/exporting_google_sketchup_models.htm
        Did a quick search with google.
          pimentapaulo
          I have this plugin the problem is that this plugin saves the file in .dbt .... and the cut file of the site is in .rbs. I can not edit to save in xml format ... anyone have a plugin that saves and exports components in .xml?
            goga63
            here (point 1) you can download the version of the plugin store the data in .xml
            http://cutting.com.ua/help/ru/files/exporting_google_sketchup_models.htm
              pimentapaulo
              Thank you friends, but I have the plugin cut.rbs it is encrypted and can not make changes. Olly Debugger tried to decrypt through this tutorial, (https://www.xaker.name/forvb/showthread.php?p=188241) but I found the source code file ... I want to export xml any files directly from SketchUp. It is because the tutorial is in Russian. the translation was not efficient for me. Thank you for your help.
                goga63
                will repeat, the plugin to which I gave the link stores the data in the format .xml .
                Not in the format .dbt
                P.S. you refer to a video made by me.
