    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Layout dimensions to model axis in isometric
    layout
    9 Posts 5 Posters 2.0k Views 5 Watching
    • GMthompsonG Offline
      GMthompson
      Layout at times kills me when trying to dimension a isometric
      It would be a great advantage to be able to set a dimensions angle to snap across a reference line or parallel to the model as sketchup can
      Perhaps i am missing something any suggestions?
      https://lh6.googleusercontent.com/-31i6E29Yv2s/VHOzlAaKmiI/AAAAAAAABwE/1YY4gWL4rok/w993-h664-no/clip%2Bdimension.JPG
      vs
      https://lh5.googleusercontent.com/-uCwEIPVjq60/VHSGpuS4DaI/AAAAAAAABx0/lwL-ORe_L1Q/w1185-h765-no/lo%2Bsnipping.JPG
      you can learn something everyday by paying attention
      • yorik1984Y Offline
        yorik1984
        Use dimensions in the SU model.
        • KrisidiousK Offline
          Krisidious
          Agreed... Isometric dimensioning is needed.
          By: Kristoff Rand
          • FrederikF Offline
            Frederik
            Does anyone have a solution to this...?
            I'd like to have a isometric grid in LO - but how to...?
            Cheers
            Kim Frederik
              I would like to be able to create dimensions in LO that fit the perspective of the SU viewport. I've made a feature request on that and chatted in person with several members of the LO team about this subject. I hope we'll see it soon. In the meantime, I developed a work around which I've shown here in the forum before. Although it isn't quite as easy as having the Dimension tool deal with it automatically, it makes the dimensions look much better then the current options. I'll see if I can find a link to the thread if there's interest.
              • FrederikF Offline
                Frederik
                Thanks, Dave...! ๐Ÿ‘
                Cheers
                Kim Frederik
                  After I wrote my previous post I tried searching for it but didn't find it. I'll just make up a new one when I get home from the day job.
                    Frederik, I made up a new example for you. I'm showing dimensions with the camera set to Perspective but the same sort of thing applies toIso and Parallel Projection. I understand it isn't the perfect solution but it beats using the existing Dimension tool in LayOut and you still have full control over all aspects of the dimensions unlike using the Dimension tool in SU.
                    The upper left shows the viewport rendered in Raster . I inserted some guidelines that I could trace with the Line tool in LayOut. Add a few arrow heads and the dimensions as text boxes with white background. Render in Vector as shown at lower right and Bob's yer uncle. If you want to continue in Raster mode or you want to use Hybrid, delete the guides in SU when you're finished with them and update the reference in LO and you're good to go.
                    I have it on good authority that the issue of dimensioning isometric and perspective views is on the list of features to add. Let's cross our fingers and hope it comes soon. In the meantime, at least there's an option.
                    • FrederikF Offline
                      Frederik
                      Thank you SO MUCH, Dave...! ๐Ÿ‘ ๐Ÿ˜„
                      I will give it a try...
                      I sure hope that we will see an option to get a isometric grid in LO in the future...
                      I seem to have more and more requests for this...
                      Cheers
                      Kim Frederik
