    ๐Ÿ›ฃ๏ธ Road Profile Builder | Generate roads, curbs and pavements easily Download
    Is it possible to render with different styles options??
    renderpluginsextensions
    11 Posts 3 Posters 805 Views 3 Watching
      LARV
      Is it possible to render with different options in the styles menu?
      • andybotA Offline
        andybot
        You can always export a 2D image straight from Sketchup and overlay it on the rendered output. For example if you want to add linework. There's a few tutorials and tips about that if you search this forum.
        In other words - no - the styles have no effect on the vray rendering.
          LARV
          Ok, thanks
          • chonC Offline
            chon
            If you want to see edges in your VRay renders, you can also add toon materials (VRay materials) in your scenes. ๐Ÿ˜‰
              LARV
              Sounds cool. Where in Vray do I add that and where can I find the material?
              • chonC Offline
                chon
                @larv said:
                ...Where in Vray do I add that and where can I find the material?
                You open the VRay Material editor, right click on "Scene materials", then Create material/Toon.
                Enjoy ! ๐Ÿ˜‰
                  LARV
                  Enjoy ! ๐Ÿ˜‰
                  Thanks, but nothing happens. Even tried setting the line width to 300. Strange.
                  • chonC Offline
                    chon
                    After creating your toon material, did you apply it on objets of your scene ?
                      LARV
                      When I create the toon material in the scence materials, a material named "default material" will land under the last created material in the scence. It still doesnยดt make anything happen to that material when rendering and I donยดt know how to make it apply to other materials (since it always ends up in the last created only)
                      ๐Ÿ˜ข
                        LARV
                        OK I made it work. What I had to do also was add base material and then paint the model again with the new material created. Thanks.
                        • chonC Offline
                          chon
                          ๐Ÿ˜‰
