    [Plugin] Add comments to your file
    104 Posts 20 Posters 20.6k Views 20 Watching
    • inteloideI Offline
      inteloide
      Glro,
      please have a look at options, you can choose if you want to click or double click to follow a link, with or without pressing on ctrl key at same time.
      Glad this function fits your wish !
      Inteloide
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
      • JClementsJ Offline
        JClements
        Any chance you could post an SU file which includes comment tabs with a link to a URL and a tab with a link to an image file so I can see how the field entries were made?
        Thanks.
          inteloide
          Thanks.
          Hello John,
          I was updating the help file when I found some issue the hyperlink system.
          To add a link, you should select the text click on link (infinity sign) icon and past the linkin the field URL (increase comment plugin window if required). But it looks like sometime hyperlink doesn't work : you cannot open the link...By removing options (ctrl key press, double click) it may work, but look not stable...That's maybe the issue you have.
          I need to have a look.
          HAS ANYBODY ELSE THE ISSUE ?
          For the image inserting, you have to click on "Picture" icon and past your link to the picture. Just press ok at bottom and your picture will appear. Again, you may need to increase plugin window size to be able to see the "OK" button.
          I will have a look to the hyperlink issue and I will upload last version of the help file.
          Inteloide
            inteloide
            Actually I just post the updated help file (look first post of this thread).
            When I close SU and restart, it looks like the link system worked correctly...not stable... 😕
              JClements
              Inteloide, could you paste some screen shoots where you link to a Google Web album photo and and another to a Google Map location? In both Google apps there is a link box where the link can be copied to the clip board. I am unsure if pasting from the pasteboard into Tab dialog field works as you planned or which field it should be pasted into.
                inteloide
                Well I don't have a Google web album...sorry
                For a Google map link, I cannot found the field to copy the locailzation, only in the browser web address field, something like : https://www.google.fr/maps/@48.8391153,2.3269406,17z
                You can copy and past this address into the link foeld of the plugin.
                Well, I think tomorrow I will be able to send you a tiny video to explain that.
                Inteloide
                  JClements
                  Hi I,
                  Check your personal messages for link info.
                  link to specific image
                  link to entire album
                  • chialiang168C Offline
                    chialiang168
                    Comments-icon_v2.3.5 Test report
                    An error occurred in IE10
                    https://dl.dropboxusercontent.com/u/108539326/æ˜Ÿé‡ŽçŻ‰ç¶Č頁/004-æ‡‰ç”šæ•™ćź€/002-sketchupæ•™ćź€/插件應甚/Comments(æ–‡ć­—èš»é‡‹)v2.3.5/朖片/Error.gif
                    Increase Chinese language file
                    Increase China-Taiwan language files
                    Dropbox - 404
                    (dl.dropboxusercontent.com)
                      inteloide
                      Hello,
                      thank you for translation : I added it to the plugin.
                      Please try attached version which should solve your issue, and let me know in order to officially post this version.
                      Improvements are :
                      2.3.7 Corrected : Avoid menu error
                      Optimized : Added chinese languages (thanks to chialiang168)
                      2.3.6:	Updated : 	version of ckeditor update to 4.4.5
                      		Added :		Change tab key behavior to add spaces (4)
                      		Corrected : enter key now make a simple return to line
                      Regards.
                      Inteloide
                      Version 2.3.7
                        chialiang168
                        https://dl.dropboxusercontent.com/u/108539326/001-Share/022.gif
                          inteloide
                          Lovely!
                            BMoffa
                            I would really like to use this plug-in, but it seems to not save or not load comments that I add. At first it lost comments from one of the two tabs I set up, then it lost everything.
                            I'm using version 2.3.5 in SketchUp 2015 Pro 64 bit (current build). I really hope you can fix this as I really like it.
                              inteloide
                              Hello,
                              Please download version 2.3.7 from the store or from the first post of this thread, and please tell me if solved your issue.
                              Best regards.
                              Inteloide
                                LĂȘ Việt Trường
                                Thank you for this usefull plugin!
                                  LĂȘ Việt Trường
                                  Hi there,
                                  Thanks for the ruby, but where it saves the comments? I lost some tab's comments and can not get it back
                                    inteloide
                                    Hello LĂȘ,
                                    Please download the latest update of BGSketchup Library from the store (version 2.3.1).
                                    It may solve your issue.
                                    To answer your question, comments are saved inside Model (let's say Inside skp file).
                                    If you loose some comment, you can send me your file (even if you delete everyhting inside) and I will try to recover it.
                                    Inteloide
                                      bharralure
                                      Bonjour Inteloide,
                                      J’utilise depuis quelques semaines votre plugin "Comments v2.3.7".
                                      Il fonctionne correctement sauf qu’à chaque lancement d’un modĂšle SketchUp comportant des commentaires enregistrĂ©s s’affiches les messages tels que les montres les captures d’écrans ci-aprĂšs :
                                      Est-il possible de solutionner ce problĂšme ?
                                      Merci.
                                        bharralure
                                        Bonjour Inteloide,
                                        Je viens de solutionner mon problĂšme en installant la version 2.3.2 de BG_Sketchup_Library (j'utilisais la version 2.0.7 sans avoir vu la mise Ă  jour...).
                                        Tout fonctionne.
                                          inteloide
                                          Bonjour,
                                          Il vous faut télécharger la derniÚre version de BGSketchup_Library (la version 2.3.2).
                                          Pour cela, vous pouvez allez, dans Sketchup, dans le menu Extension puis BGSketchup puis BGSketchup update manager.
                                          LĂ  vous tomberez sur l'interface qui vous permettra de mettre Ă  jour vos plugins.
                                          Sinon, vous pouvez passer par le PluginStore de SketchUcation.
                                          Cordialement
                                          Inteloide
                                          • greenskpG Offline
                                            greenskp
                                            Default installation is fine but an installation with a custom folder always ask me to install BGSketchup Library.
                                            I am using
                                            require_all('path\to\custom\folder')
                                            inside default plugins folder.
                                            • 3 / 6
