    REQ: Checking if components (solids) intersect
    22 Posts 5 Posters 3.2k Views 5 Watching
    • G
      glro
      @bobvandevoort said:
      If I run the code normally I get the following output "Done. Ruby says: red"
      However the faces aren't red they just stay the original color.
      they are red, actually... but inside. Faces a reversed
        It's not Face.material = 'red'
        it'd be ent.material = 'red'
        • P
          pgarmyn
          @TIG
          In method def self.intersectALL()
          (ens.length-1).times{|i|
                   (ens.length-1).times{|j|
                      next if j<=i # in place of  ; next if j==i
                      if self.intersect?(ens[i], ens[j])
                         ss.add(ens[i])
                         ss.add(ens[j])
          next if j<=i ( in place of next if j==i )
          prevents double checking (slower) and double results.
          If intersect?(ens[1], ens[2]) has been tested, then we don't have to test intersect?(ens[2], ens[1])
          • G
            glro
            @pgarmyn said:
            @TIG
            >                ss.add(ens[i])
            >                ss.add(ens[j])
            >             end
            I don't know why, but neither TIG's version, nor yours, works on my computer
            this is how i changed the code:
            		model=Sketchup.active_model
            		ss=model.selection
            		ents=model.active_entities
            		ss.clear
            		gps=ents.grep(Sketchup;;Group)
            		ins=ents.grep(Sketchup;;ComponentInstance)
            		ens=gps+ins
            		ens.uniq!
            		ens.compact!
            		for i in (0..ens.length-1)
            			for j in ((i+1)..ens.length-1)
            				if TIG.intersect?(ens[i], ens[j])
            					ss.add(ens[i])
            					ss.add(ens[j])
                    puts "Any intersecting groups/component-instances are highlighted..."
            length-1 because it because i begins at 0...
            and the i+1 to avoid comparing i to itself
            is this version much slower than yours?
            • P
              pgarmyn
              @giro
              		ss=model.selection
              		ss.clear
              		ens=gps+ins
              		ens.uniq!
              		ens.compact!
              		for i in (0..ens.length-2)  ############changed from length-1 to length-2
              					ss.add(ens[i])
              					ss.add(ens[j])
              I think, in this case, the last TIG.intersect?(ens[i], ens[j]) is with i=length-2 and j=length-1
              Otherwise j = i+1 will become ens.length : for 5 elements (0 to 4) in ens, j will be 5.
              • G
                glro
                @pgarmyn said:
                @glro
                yes, i agree
                it works in both cases, but your version should be faster
                • B
                  Bobvandevoort
                  Thanks this solved it 😄
                  Btw there's a way to do it with the intersect_with function and rule out most of the touching elements.
                  Any 3d volume needs at least 4 faces, so do a face count for ges and see if it equals 4 or more.
                  I know there probably some odd situations where it would still only be touching but then you could check if the faces form a solid if it doesn't form a solid it's a touch (I think this should be a correct way to implement this).
                  Let me know your thought about this method 😉
                  (in any real 3d modeling you only need to find volumetric intersections and if you also want to find out of they are thouching we already have the method you previously described.
                  Everybody else thanks for the response and sorry for the delay on my side with responding, I have been away for 2 days.
                  • P
                    pgarmyn
                    @bobvandevoort
                    To rule out most of the elements :
                    You can exclude elements based on boundingbox values :
                    Elements a and b won't intersect
                    If a.bounds.max.x < b.bounds.min.x
                    If a.bounds.min.x > b.bounds.max.x
                    If ..... 4 other tests with .y and .z
                    I'm not shure if this will speed up your code. I can imagen that those tests are also done by the (faster) intersect method of the API
                    • G
                      glro
                      @pgarmyn said:
                      @giro
                      > 		ss=model.selection
                      > 		ss.clear
                      > 		ens=gps+ins
                      > 		ens.uniq!
                      > 		ens.compact!
                      > 					ss.add(ens[i])
                      > 					ss.add(ens[j])
                      > 				end
                      > 			end
                      > 		end
                      i tried to run this code in sketchup 15 64 bits, thinking it could run faster than is sketchup 8
                      All the contrary
                      it is much slower in sketchup 15 64 bits... (about 10 times...)
                      i am very disapointed
                      am i the only one to experience that?
                      • B
                        Bobvandevoort
                        This is my version of the srcipt for now that seems to work for all non nested component instances
                        module Bob
                        # Huge parts of this code were written by TIG this is a sligthly modified version
                        	def self.intersectBob?(e1=nil, e2=nil)
                        		mod = Sketchup.active_model # Open model
                        		ent = mod.entities # All entities in model
                        		instance1 = e1 #sel[0]
                        		instance2 = e2 #sel[1]
                        		ci_def = instance1.definition
                        		tr1 = instance1.transformation
                        		test1 = Sketchup.active_model.entities.add_instance ci_def, tr1
                        		ci_def2 = instance2.definition
                        		tr2 = instance2.transformation
                        		test2 = Sketchup.active_model.entities.add_instance ci_def2, tr2
                        		result = test1.intersect(test2)
                        		cnt = result.entities.count
                        		if  cnt > 0
                        			int=true
                        			result.definition.entities.each {|ent|
                        			if ent.is_a? Sketchup;;Face
                        				ent.material = 'red' #Sketchup;;Color.new(255, 0, 0)
                        			end}
                        		else
                        		int=false
                        	return int
                        	#def self.del()	#does not work like this typing Bob.del into the ruby console, meaning result has to be changed from local to global variable but I don't know how yet
                        	#result.erase!
                        	#end
                        		ss=model.selection
                        		ss.clear
                        		ens=gps+ins
                        		ens.uniq!
                        		ens.compact!
                        		(ens.length).times{|i|
                        			(ens.length).times{|j|
                        				next if j<=i
                        				if self.intersectBob?(ens[i], ens[j])
                        					ss.add(ens[i])
                        					ss.add(ens[j])
                        		puts "Any intersecting component-instances are highlighted..."
                        In this script I still need to fix the deleting function which later will have to be added to an observer class so as soon as another is clicked (or a button is pressed) the resulting intersection is deleted.
                        The more important function that still has to be added is that it does the check for all the nested components (and possibly groups).
                        @giro
                        I only have the 32 bits version so can't say
                        • 2 / 2
