    Sweet New Plugin from Garry Kernan is in the pipe.
    38 Posts 9 Posters 3.2k Views 9 Watching
    • olisheaO Offline
      olishea
      I wish I could put my hands through my screen and strangle you! 😄
      oli
      • KrisidiousK Offline
        Krisidious
        I tend to have that affect on people... 😡
        By: Kristoff Rand
        • pep75P Offline
          pep75
          ...it will open doors? Nice plugin!
          • jujuJ Offline
            juju
            this info is great and all, but without description and timeline it is just a passing comment
              Krisidious
              I don't have the authority to actually announce it. But, it's exciting and I'm probably pushing up the timeline by making this thread.
              By: Kristoff Rand
              • JQLJ Offline
                JQL
                You don't have neither the authority neither the moral ground to keep spilling that waste on this forum. Get away from here Kris! 😆
                www.casca.pt
                Visit us on facebook!
                  Krisidious
                  By: Kristoff Rand
                    Garry K
                    I am adding a number of features to Door Maker Pro and will put out a Gold version very soon. I have a beta version currently in testing.
                    I want to change some coding that deals with mullions and panels for cathedrals and arches. I also want to finish off the door jambs portion. Should be released in a couple of weeks.
                    Here are some pictures of what it can do.
                    Door with mullions
                    Door Maker Gold
                    Astragal
                    Double Entry with side-lights
                      Krisidious
                      By: Kristoff Rand
                      • PixeroP Offline
                        Pixero
                        That looks very interesting.
                          Krisidious
                          Yeah it does... no more looking for the right door, just make the one you want on the fly.
                          By: Kristoff Rand
                          • jujuJ Offline
                            juju
                            Excellent! Seems like something I've been looking around for.
                            subscribes to topic
                            • olisheaO Offline
                              olishea
                              really cool plugin! would be nice if there was a pivoting hinge option (for very large doors).
                              oli
                                Garry K
                                If you could post a sketchup file with a door and a pivoting hinge I'll take a look at it. It seems to me that you would have to make changes to the door jamb.
                                Setting the pivot to a non 0 value for the actual door is the easy part. These doors support Interact. However I haven't figured out how to get the second part of a bifold to slide and open in conjunction with the first part just rotating through around 75 degrees.
                                Opened
                                • jujuJ Offline
                                  juju
                                  any chance of adding a door swing indication (when looking on plan view) that can go on a separate (user definable) layer?
                                    Krisidious
                                    good idea juju...
                                    By: Kristoff Rand
                                      jtri
                                      Rixson pivot hinges are commonly used in commercial construction. The head and floor need to be machined for the pivots and some times the jamb if a center hinge is required.http://www.rixson.com/pivottypes/
                                      Great plug in!
                                        Garry K
                                        I can put a direction symbol like an arc and an arrow for 2D plans.
                                        You are suggesting to put the direction information on a user defined named layer.
                                        Please provide an example of what you would like to see for a direction symbol
                                        That pivot hinge looks interesting. Looks like the door will complete clear the casings and can open 180 degrees.
                                        This pivot hinge allows a door to open both directions.
                                        Pivot hinge
                                          Krisidious
                                          I like the simple plan view for door swings, full 90 or 35/45 degrees. as for layers... it's going to be different for everyone. whatever is easy for you. I would think ANNO_DOOR would do. I don't know about other people, But I use a component system with a door symbol layer inside the door so i can turn on a symbol for the door schedule. a symbol would be nice if we're annotating.
                                          By: Kristoff Rand
                                          • olisheaO Offline
                                            olishea
                                            [attachment=0:37jzhlne]<!-- ia0 -->both way pivot hinge.PNG<!-- ia0 -->[/attachment:37jzhlne]
                                            Just thought it would be a nice addition to your plugin. People tend to use pivot hinges on very large external doors (>1000mm wide) although you do see them internally from time to time. I believe there is also another pivot hinge that just acts as an axle directly though the door, might be wrong but the type you have posted looks a bit more intricate than the ones I have seen, unless I have misunderstood the mechanism.
                                            http://1.design-milk.com/images/2013/05/pivot-door-Graux-Baeyens-Architecten-600x900.jpg
                                            oli
                                            • 2 / 2
