    Sweet New Plugin from Garry Kernan is in the pipe.
    38 Posts 9 Posters 4.3k Views 9 Watching
    • KrisidiousK
      Krisidious
      By: Kristoff Rand
      • G
        Garry K
        I am adding a number of features to Door Maker Pro and will put out a Gold version very soon. I have a beta version currently in testing.
        I want to change some coding that deals with mullions and panels for cathedrals and arches. I also want to finish off the door jambs portion. Should be released in a couple of weeks.
        Here are some pictures of what it can do.
        Door with mullions
        Door Maker Gold
        Astragal
        Double Entry with side-lights
        • KrisidiousK
          Krisidious
          By: Kristoff Rand
          • PixeroP
            Pixero
            That looks very interesting.
            • KrisidiousK
              Krisidious
              Yeah it does... no more looking for the right door, just make the one you want on the fly.
              By: Kristoff Rand
              • jujuJ
                juju
                Excellent! Seems like something I've been looking around for.
                subscribes to topic
                • olisheaO
                  olishea
                  really cool plugin! would be nice if there was a pivoting hinge option (for very large doors).
                  oli
                  • G
                    Garry K
                    If you could post a sketchup file with a door and a pivoting hinge I'll take a look at it. It seems to me that you would have to make changes to the door jamb.
                    Setting the pivot to a non 0 value for the actual door is the easy part. These doors support Interact. However I haven't figured out how to get the second part of a bifold to slide and open in conjunction with the first part just rotating through around 75 degrees.
                    Opened
                    • jujuJ
                      juju
                      any chance of adding a door swing indication (when looking on plan view) that can go on a separate (user definable) layer?
                      • KrisidiousK
                        Krisidious
                        good idea juju...
                        By: Kristoff Rand
                          jtri
                          Rixson pivot hinges are commonly used in commercial construction. The head and floor need to be machined for the pivots and some times the jamb if a center hinge is required.http://www.rixson.com/pivottypes/
                          Great plug in!
                          • G
                            Garry K
                            I can put a direction symbol like an arc and an arrow for 2D plans.
                            You are suggesting to put the direction information on a user defined named layer.
                            Please provide an example of what you would like to see for a direction symbol
                            That pivot hinge looks interesting. Looks like the door will complete clear the casings and can open 180 degrees.
                            This pivot hinge allows a door to open both directions.
                            Pivot hinge
                            • KrisidiousK
                              Krisidious
                              I like the simple plan view for door swings, full 90 or 35/45 degrees. as for layers... it's going to be different for everyone. whatever is easy for you. I would think ANNO_DOOR would do. I don't know about other people, But I use a component system with a door symbol layer inside the door so i can turn on a symbol for the door schedule. a symbol would be nice if we're annotating.
                              http://www.un.org/esa/socdev/enable/designm/2-07-03.gif
                              By: Kristoff Rand
                              • olisheaO
                                olishea
                                [attachment=0:37jzhlne]<!-- ia0 -->both way pivot hinge.PNG<!-- ia0 -->[/attachment:37jzhlne]
                                Just thought it would be a nice addition to your plugin. People tend to use pivot hinges on very large external doors (>1000mm wide) although you do see them internally from time to time. I believe there is also another pivot hinge that just acts as an axle directly though the door, might be wrong but the type you have posted looks a bit more intricate than the ones I have seen, unless I have misunderstood the mechanism.
                                http://1.design-milk.com/images/2013/05/pivot-door-Graux-Baeyens-Architecten-600x900.jpg
                                oli
                                • G
                                  Garry K
                                  Looks good.
                                  A basic bifold door essentially uses a pivot hinge. The pivot is a small distance from one edge and on the center line. If a large door is to swing both ways then the pivot needs to on the center line. Doors that swing 1 way can have the pivot offset.
                                  It appears that the top jamb is not rabbeted and if the door swings 1 way you can have the side jambs rabbeted opposite to each other.
                                  If you have a door that swings both ways then side jambs are not rabbeted.
                                  • olisheaO
                                    olishea
                                    ah I see, thanks!
                                    oli
                                    • G
                                      Garry K
                                      OK - I've added a pivot point. This 1000 mm wide door has a pivot point at 300 mm
                                      It is on the center line. Should be good enough.
                                      pivot hinge
                                      • olisheaO
                                        olishea
                                        thanks! great addition, these doors are very much in fashion at the moment. looks to be a great plugin!
                                        oli
                                        • jujuJ
                                          juju
                                          I cant' wait to see the finished product!
                                          • G
                                            Garry K
                                            Testers found a few bugs that I am working through. I've also learned a bit and I believe that I will be able to handle opening and closing of bifolds.
                                            The dowel is just to show you where the pivot point is.
                                            Bifold with half jamb closed - using pivot point of 35 mm
                                            Bifold with half jamb opened - same pivot point
