    Sweet New Plugin from Garry Kernan is in the pipe.
    38 Posts 9 Posters 3.9k Views 9 Watching
    • KrisidiousK Offline
      Krisidious
      I don't have the authority to actually announce it. But, it's exciting and I'm probably pushing up the timeline by making this thread.
      By: Kristoff Rand
      • JQLJ Offline
        JQL
        You don't have neither the authority neither the moral ground to keep spilling that waste on this forum. Get away from here Kris! 😆
        www.casca.pt
        Visit us on facebook!
          Krisidious
          By: Kristoff Rand
            Garry K
            I am adding a number of features to Door Maker Pro and will put out a Gold version very soon. I have a beta version currently in testing.
            I want to change some coding that deals with mullions and panels for cathedrals and arches. I also want to finish off the door jambs portion. Should be released in a couple of weeks.
            Here are some pictures of what it can do.
            Door with mullions
            Door Maker Gold
            Astragal
            Double Entry with side-lights
              Krisidious
              By: Kristoff Rand
              • PixeroP Offline
                Pixero
                That looks very interesting.
                  Krisidious
                  Yeah it does... no more looking for the right door, just make the one you want on the fly.
                  By: Kristoff Rand
                  • jujuJ Offline
                    juju
                    Excellent! Seems like something I've been looking around for.
                    subscribes to topic
                    • olisheaO Offline
                      olishea
                      really cool plugin! would be nice if there was a pivoting hinge option (for very large doors).
                      oli
                        Garry K
                        If you could post a sketchup file with a door and a pivoting hinge I'll take a look at it. It seems to me that you would have to make changes to the door jamb.
                        Setting the pivot to a non 0 value for the actual door is the easy part. These doors support Interact. However I haven't figured out how to get the second part of a bifold to slide and open in conjunction with the first part just rotating through around 75 degrees.
                        Opened
                        • jujuJ Offline
                          juju
                          any chance of adding a door swing indication (when looking on plan view) that can go on a separate (user definable) layer?
                            Krisidious
                            good idea juju...
                            By: Kristoff Rand
                              jtri
                              Rixson pivot hinges are commonly used in commercial construction. The head and floor need to be machined for the pivots and some times the jamb if a center hinge is required.http://www.rixson.com/pivottypes/
                              Great plug in!
                                Garry K
                                I can put a direction symbol like an arc and an arrow for 2D plans.
                                You are suggesting to put the direction information on a user defined named layer.
                                Please provide an example of what you would like to see for a direction symbol
                                That pivot hinge looks interesting. Looks like the door will complete clear the casings and can open 180 degrees.
                                This pivot hinge allows a door to open both directions.
                                Pivot hinge
                                  Krisidious
                                  I like the simple plan view for door swings, full 90 or 35/45 degrees. as for layers... it's going to be different for everyone. whatever is easy for you. I would think ANNO_DOOR would do. I don't know about other people, But I use a component system with a door symbol layer inside the door so i can turn on a symbol for the door schedule. a symbol would be nice if we're annotating.
                                  By: Kristoff Rand
                                  • olisheaO Offline
                                    olishea
                                    [attachment=0:37jzhlne]<!-- ia0 -->both way pivot hinge.PNG<!-- ia0 -->[/attachment:37jzhlne]
                                    Just thought it would be a nice addition to your plugin. People tend to use pivot hinges on very large external doors (>1000mm wide) although you do see them internally from time to time. I believe there is also another pivot hinge that just acts as an axle directly though the door, might be wrong but the type you have posted looks a bit more intricate than the ones I have seen, unless I have misunderstood the mechanism.
                                    http://1.design-milk.com/images/2013/05/pivot-door-Graux-Baeyens-Architecten-600x900.jpg
                                    oli
                                      Garry K
                                      Looks good.
                                      A basic bifold door essentially uses a pivot hinge. The pivot is a small distance from one edge and on the center line. If a large door is to swing both ways then the pivot needs to on the center line. Doors that swing 1 way can have the pivot offset.
                                      It appears that the top jamb is not rabbeted and if the door swings 1 way you can have the side jambs rabbeted opposite to each other.
                                      If you have a door that swings both ways then side jambs are not rabbeted.
                                      • olisheaO Offline
                                        olishea
                                        ah I see, thanks!
                                        oli
                                          Garry K
                                          OK - I've added a pivot point. This 1000 mm wide door has a pivot point at 300 mm
                                          It is on the center line. Should be good enough.
                                          pivot hinge
                                          • olisheaO Offline
                                            olishea
                                            thanks! great addition, these doors are very much in fashion at the moment. looks to be a great plugin!
                                            oli
