    Alpha transparency in back face
    27 Posts 4 Posters 6.0k Views 4 Watching
      soldatino
      @tig said:
      In code you can ensure a face's normal is towards the camera [get angles between the view direction and the face.normal], if >180 you are looking at the front !
      yes, I think that this is really a good idea.
      I thought for a control vector from the center of the object, but it is not a general rule, if the object has undercuts ... πŸ˜•
      instead your idea can not fail πŸ‘
      r3nDer tools
      • AdamBA Offline
        AdamB
        TIG, strictly this is only true for a parallel projection. Its broadly correct for perspective projection, but not for all cases.
        • AdamBA Offline
          AdamB
          @tig said:
          In code you can also paint the same material on every face's back as it is front.
          So for example iterating all faces to make sure any ones using a transparent material, then have the same material on both sides...
          faces.each{|face| face.back_material=face.material if face.material && face.material.alpha < 1.0 **&& !face.back_material** }
          The part at the end - && !face.back_material - only paints the back of a face if it is in already in the default material, BUT omitting it forces every face which has a transparent material to have that material on its front AND its back sides.
          And of course this ignores Group materials that override any face with the Default material. So you can't just check when face#[back_]material is nil 😒
            You are right about the angle check.
            I threw it out as a way of approaching something - NOT a fully fledged working tool/method...
            However, this could be further improved by not using the camera direction vector, but getting the vector between the eye and parts of the face [like bounds.center or vertices] AND the angle_between each of those and the face.normal ?***
            Didier Bur's 'Automatic Face Reverser' in the PluginStore works by using a pickray within a Tool t and inspects the visibility of every vertex in a face, casting the ray from the eye, until one is visible AND the normal is looking away from the camera [>=180.degrees], then you are looking at a visible bare back...
            Didier's file's code is 'packed' as a low level encryption, but by making a copy and changing the file suffix to .txt so it doesn't load, and editing the initial 'eval' to a 'puts', will then 'unpack' its contents and print it out in the Ruby Console when you use 'load' on it later...
            Note his tool only works on the active_entities or selected faces, and also has an option for multiple eye-point checking etc...
              soldatino
              Yes, but the summ of the perspective projections draw step by step the outer visible skin of each object, only if you are "into" the object the entire skin is reversed.
              I think that it is the right method to identify if the face is drawn properly...
              Thus, in case of doubt with transparency valued only on the back of the face, checking if the face was drawn wrong then I can understand why transparency is over just that way.
              And this is precisely the case of the glass of the truck that was giving me uncertainties.
              PS. inherited attributes are one other thing to consider, but if you take a look at my code you see that I have a map levels that store the parent attribute, and only if the face need it, I load that value
              r3nDer tools
              • AdamBA Offline
                AdamB
                I've made a simple model to help understanding.
                Open it and you'll see a single face, but its actually rhomboid with the "sides" facing toward the camera direction.
                You can't do a worldspace test to determine visibility in a non-orthonal projected space.
                EDIT: well thats not entirely true, but you need more than camera.direction.
                backface culling.skp
                  soldatino
                  maybe I did not understand, but if I could see the faces covered and their normals (which geometrically can do), normals vectors should be away and not to my point of view. Which would mean that I would be looking at the back of the faces .... but maybe I did not understand what you mean, later will study better, thanks!
                  r3nDer tools
                    soldatino
                    The simple to apply an OR between the sides seems to work well. Note that the windows of the truck were opaque even on SU, but now the lights are transparent, the same of SU.
                    I have to test it on various models, because my old version of the plugin to import in PovRay exchanged opacity values and I have to fix the little problem. SU uses the opacity value, and instead using PovRay I usually write the transparency. So I have to make complementary to 1. I did not realize at that time because with 50% of transparency (more or less) the results seem to be equal .... Then the next day I will update the plugin .... thanks πŸ‘
                    r3nDer tools
                      soldatino
                      My conclusions.
                      Generally the principle of OR between the two sides of a face works for transparency, because it is always quite reasonable that the apparent transparency is equal between the views from inside OR outside.
                      Instead, the problem is more serious for the color.
                      SU does not differentiate inside and ouside of each face and objects does not apply evenly the principle of the right hand.
                      Faces and back faces are not always oriented toward the outside the first and the second inward.
                      For this reason, when exporting is important to check the normal to choose the right color (if the colors are two) for export to the face.
                      The methods exist, it is only a matter of working on it, even if it is not simple.
                      http://en.wikipedia.org/wiki/Back-face_culling
                      In the image, the example, part of the truck (sketchup object found in the web) with the door designed with the order of the clock and also with the reverse order. (image of MeshLab after I imported some faces of the truck converted in STL format)
                      sorry for the bad English, I hope it is at least understandable
                      πŸ˜„
                      r3nDer tools
                        So you have finally realized that sloppy modeling leads to back-face issues. πŸ˜‰
                        That is why I developed http://sketchucation.com/pluginstore?pln=FixReversedFaceMaterials
                        View the model in Monochrome mode, so that you can see visible 'back-faces' in a distinctive color set in the Style.
                        There are several tools to flip [reverse] the face so its 'back' is then facing the correct way.
                        BUT these faces will then take their material with them, perhaps leaving a default [or other unexpected material] front face visible.
                        My tool reverses any [selected] face with a material on its 'back', AND then reuses its back-material onto its front, keeping any UV-mapping, and it then defaults the back material of the face too.
                        There are other tools which reverse faces, and swap the materials between the face's sides too [thomthom has one...]
                          soldatino
                          really, more than I have to figure out how to draw, I have the opposite problem, I certainly do not model these objects so sloppy, (and redundant, but that's another matter) because I'm used to working on a real CAD for a lifetime . It took me a long time to realize that SU uses safely the back face as a front face, pulling on the front his color back ..... so I will have to develop a filter that normalize the entire model. My problem is not learning how to draw, but how import those models that do not have a decent description of the points .... thanks πŸ˜„
                          I will check your code !
                          tar=cam.target
                          vec=eye.vector_to(tar)
                          if vec.angle_between(face.normal)>90.degrees .....
                          r3nDer tools
                            soldatino
                            Tig, I checked, but AdamB is right ...
                            The search for the "internal" and "external" of the object, this is the only way to evaluate the order of the vertices of the faces.
                            Instead, this code seems to be a solution.
                            It is a raw code ... it investigates only the skin of a compact object, devoid of undercuts ... but I will write the recursive routine. the ray must to come and to go in the solid, each IN must find his OUT in the space, and to end this way in the open space, switching the on - off ... otherwise the beam was started by a face looking at the inside of the object, and the normal of that face watch inside (what I have to correct) ...
                              if face.material==nil        #and face.back_material!=nil
                                  model = Sketchup.active_model
                                  vertx=mesh.polygon_at 1
                                  ray = [mesh.point_at(1), face.normal]
                                  item = model.raytest(ray, false)
                                  if item.to_s.length!=0  then
                                        # UI.messagebox(item.to_s.length.to_s)
                                        face.reverse!
                                        #  face.material=face.back_material
                                        # else
                                        #  UI.messagebox("ok")
                            PS: at this moment in the code the point is one random of the face vertexes, it would be better to define an interior point on the plane of the face, which is not disturbed by any adjacent faces at 90 degrees that can confuse
                            r3nDer tools
                            • 2 / 2
