    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 294.3k Views 172 Watching
      chris87
      Sketchup 8 pro error !!!
      • TIGT Online
        ... and what happens when you click on 'continue' ?
        The sliders/ivyleaf icons depend on that lib...
        That js error is from one of the standard jquery code libraries - it's relating to 'msie'.
        What version of Internet Explorer do you have ?
        Try updating it...
        • KrisidiousK Offline
          Krisidious
          Here's the Gordon we were looking for. Thanks to Driven for hunting him down.
          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=36882%26amp;start=450#p460919
          By: Kristoff Rand
            chris87
            Try updating it...
            IE9
            • TIGT Online
              But IE11 is current, although IE9 ought to be πŸ˜• OK
                Krisidious
                Ok, since we figured out who Gordon is and I saw his posts contributing to the community, I'm going to assume everything in my folder is up for grabs.
                Now don't go installing this unless you know what you're doing. Let Tig, Rich, Oxer and Myself sort them out, clean them up and see how they should fit in. We'll offer them up in a combined pack afterwards.
                Here it is.
                http://www.sketchup-house-plans.com/Ivy-Leaves-Kris.zip
                Here's what it contains.
                By: Kristoff Rand
                • TIGT Online
                  Thanks Kris πŸ˜„
                  Remember to use a SKP as a custom leaf you must name it 'ivyleaf_XXXXX.skp' and put it in the ..Plugins//LiveIvy/Textures subfolder.
                  The 'XXXXX' can be any text you want [e.g. 'Kris'] - I recommend using something logical - although you will see a thumbnail to click on !
                  I also recommend that you consider editing the SKPs to 'hide' some outer edges etc, which will improve the appearance of the 'leaves' etc ...
                    Krisidious
                    Roger that... I did the 1-10 on the old one but Rich came behind and redid them. So I wanted to touch base with all of you first.
                    Do you think we should keep the norms and bumps etc? I take it that's for render monkeys.
                    By: Kristoff Rand
                      chris87
                      I installed iE 11
                      The same problem occurs !!!
                        driven
                        I see the same javascript error on my mac, but I believe it is harmless...
                        what happens if you click to continue...
                          chris87
                          The panel is open but the tool doesn't function correctly
                            Krisidious
                            What exactly happens? give us a rundown of your steps and the results of them.
                            By: Kristoff Rand
                            • TIGT Online
                              Have the Ruby Console open as you use it.
                              Any errors ?
                              What doesn't function properly ?
                              Unless you tell us how can we help !
                              Once the dialog opens set the desired parameters, settings, leaf type[s] etc: then left-mouse click near the base of a wall face to start, keep clicking to add more branches, hold Ctrl [Cmd?] and click to add leaves, use Alt [Opt] and click to grow towards the cursor; hold Shift and click to make the ivy...
                                chris87
                                Any errors ?
                                I am French and it is difficult to give technical explanations in English language :
                                The plant doesn't create itself to the click of the mouse.
                                No error in the Ruby console....
                                  Krisidious
                                  Normally, most people will see a very small pink line, not real geometry, but a placeholder for a line. Do you not see that either?
                                  By: Kristoff Rand
                                  • TIGT Online
                                    Can you try a clean reinstall of the tool, to be sure there are no legacy files.
                                    Open the Plugins folder and delete the LiveIvy.rb file and the entire LiveIvy subfolder.
                                    Now reinstall it from the downloaded RBZ or the SketchUcation PluginStore AutoInstall red-button.
                                    Restart SketchUp and try the tool again.
                                    What happens ?
                                    What is your OS ? PC or MAC ?
                                    Are you holding the modifier keys down while clicking ?
                                    Are you clicking on a wall face ??
                                      chris87
                                      What happens ?
                                      I reinstalled several times of course cleanly the plugin.
                                      At the first clic (without modifiers keys) a very small pink line appears but nothing happens to the others click
                                      however before suspecting a bad use....there was a display of a message of mistake of the program...no ?
                                      PC OS : Windows 7 32 bits SP3 - and Sketchup 8 Pro.
                                      • TIGT Online
                                        Please look at your default settings.
                                        These are the shipped set:
                                                        ;nodesize    => 3,
                                                        ;pattern     => 0.8,
                                                        ;probability => 0.97,
                                                        ;radius      => 0.8,
                                                        ;floatlength => 150,
                                                        ;detail      => 4,
                                                        ;spread      => 0
                                                    ;leaf     => {
                                                        ;pattern     => 1,
                                                        ;probability => 0.7,
                                                        ;size        => 5
                                                    ;gravity  => {
                                                        ;weight => 1,
                                                        ;vector => [0, 0, -1]
                                                    ;wind     => {
                                                        ;weight => 0.1
                                                    ;random   => {
                                                        ;weight => 0.3
                                                    ;adhesion =>{
                                                        ;max_adhesion_distance => 50,
                                                        ;weight                => 0.2
                                                    ;legacy   => {
                                                        ;weight => 0.8
                                        Not all ot them will have dialog headings...
                                        Please reset to those which do apply... and try again.
                                        Remember that it might want the inpy value as 0.2 NOT 0,2 !!!
                                          chris87
                                          >                 ;nodesize    => 3,
                                          >                 ;pattern     => 0.8,
                                          >                 ;radius      => 0.8,
                                          >                 ;detail      => 4,
                                          >                 ;spread      => 0
                                          >             ;leaf     => {
                                          >                 ;pattern     => 1,
                                          >                 ;size        => 5
                                          >             ;gravity  => {
                                          >                 ;weight => 1,
                                          >             ;wind     => {
                                          >                 ;weight => 0.1
                                          >             ;random   => {
                                          >                 ;weight => 0.3
                                          >             ;adhesion =>{
                                          >                 ;weight                => 0.2
                                          >             ;legacy   => {
                                          >                 ;weight => 0.8
                                          Thank you TIG, for your help...
                                          But this plugin doesn't function with my configuration...
                                          I uninstalled it.
                                          Thank you again to have looked for the solutions to the problem
                                          This last will be solved maybe at the time of a next update!
                                          Best regards.
                                          • TIGT Online
                                            Did you try those default settings ?
                                            Remember sizes are always entered in 'inches'...
                                            And the decimal-separator is a '.' NOT a ','
                                            If you get a small red line at the start it suggests it does start to work, but the settings are wrong...
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 36
                                            • 37
                                            • 19 / 37
