    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 314.1k Views 172 Watching
    • KrisidiousK Offline
      Krisidious
      I don't know if I'm the author or not... I did a lot of testing and made some tuts for this plugin back in the day, but can't remember if I did this or if someone else gave it to me.
      Regardless, it's a great resource and I'll bring it out of SU and put in a better format.
      By: Kristoff Rand
        Krisidious
        Driven has pointed out to me that one of the textures on the file belongs to a "Gordon"... Anyone remember someone named Gordon?
        Well, Gordon... Wherever you are... We'll credit you with this resource.
        By: Kristoff Rand
          driven
          Search is a wonderful tool
          [anchor= goto=http://sketchucation.com/forums/viewtopic.php?f=323&t=36882&start=450#p460919:1fdzrjgt]Gordy_Z[/anchor:1fdzrjgt]
            [anchor= goto=http://sketchucation.com/forums/viewtopic.php?f=323&t=36882&start=450#p460919:26ycz78i]Gordy_Z[/anchor:26ycz78i]
            He's been inactive for the best part of two years ?
              Krisidious
              Because someone's name is Gordy they are the same Gordon we are looking for? Gordon is the name of the user on their computer... Don't know if it would be the user on the SCF board. Doesn't ring any bells for me. But, who knows... Could be him.
              I did a search on the 17-18 pages on this thread and didn't find any mention of a Gordon.
              By: Kristoff Rand
                Krisidious
                Rich, I sent all of those guide/experiments to you in a PM. You might want to hit them will spell check. and just use find/replace to change the directory for all the images.
                By: Kristoff Rand
                  chris87
                  Sketchup 8 pro error !!!
                    ... and what happens when you click on 'continue' ?
                    The sliders/ivyleaf icons depend on that lib...
                    That js error is from one of the standard jquery code libraries - it's relating to 'msie'.
                    What version of Internet Explorer do you have ?
                    Try updating it...
                      Krisidious
                      Here's the Gordon we were looking for. Thanks to Driven for hunting him down.
                      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=36882%26amp;start=450#p460919
                      By: Kristoff Rand
                        chris87
                        Try updating it...
                        IE9
                          But IE11 is current, although IE9 ought to be πŸ˜• OK
                            Krisidious
                            Ok, since we figured out who Gordon is and I saw his posts contributing to the community, I'm going to assume everything in my folder is up for grabs.
                            Now don't go installing this unless you know what you're doing. Let Tig, Rich, Oxer and Myself sort them out, clean them up and see how they should fit in. We'll offer them up in a combined pack afterwards.
                            Here it is.
                            http://www.sketchup-house-plans.com/Ivy-Leaves-Kris.zip
                            Here's what it contains.
                            By: Kristoff Rand
                              Thanks Kris πŸ˜„
                              Remember to use a SKP as a custom leaf you must name it 'ivyleaf_XXXXX.skp' and put it in the ..Plugins//LiveIvy/Textures subfolder.
                              The 'XXXXX' can be any text you want [e.g. 'Kris'] - I recommend using something logical - although you will see a thumbnail to click on !
                              I also recommend that you consider editing the SKPs to 'hide' some outer edges etc, which will improve the appearance of the 'leaves' etc ...
                                Krisidious
                                Roger that... I did the 1-10 on the old one but Rich came behind and redid them. So I wanted to touch base with all of you first.
                                Do you think we should keep the norms and bumps etc? I take it that's for render monkeys.
                                By: Kristoff Rand
                                  chris87
                                  I installed iE 11
                                  The same problem occurs !!!
                                    driven
                                    I see the same javascript error on my mac, but I believe it is harmless...
                                    what happens if you click to continue...
                                      chris87
                                      The panel is open but the tool doesn't function correctly
                                        Krisidious
                                        What exactly happens? give us a rundown of your steps and the results of them.
                                        By: Kristoff Rand
                                          Have the Ruby Console open as you use it.
                                          Any errors ?
                                          What doesn't function properly ?
                                          Unless you tell us how can we help !
                                          Once the dialog opens set the desired parameters, settings, leaf type[s] etc: then left-mouse click near the base of a wall face to start, keep clicking to add more branches, hold Ctrl [Cmd?] and click to add leaves, use Alt [Opt] and click to grow towards the cursor; hold Shift and click to make the ivy...
                                            chris87
                                            Any errors ?
                                            I am French and it is difficult to give technical explanations in English language :
                                            The plant doesn't create itself to the click of the mouse.
                                            No error in the Ruby console....
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 36
                                            • 37
                                            • 30 / 37
