    Spiral help please
    72 Posts 11 Posters 3.7k Views 11 Watching
    • KathrynGK Offline
      KathrynG
      I DID IT! I DID IT! I DID IT! Glory Hallelujah!! It only took two days...
      Box (or is it Mr. Box?) you are a champion! This has always been my problem. I registered for SU classes twice at the nearby college, and on both occasions just like the war that no one attended, they were cancelled due to lack of interest. I have therefore had to resort to Youtube and Lynda.com and trial and error (errors costing me lots of trials...) to learn the little that I know. Having been nominated on several occasions for Math Moron of the year, that does not help. But thanks to people like yourself, who take the time out of your day to help the helpless, I shall prevail, and I never give up. THANK YOU SO MUCH. Now let's see if I can understand where he went from there. πŸ˜„
      "With SketchUp - Rome could have been built in a day!"
      • BoxB Offline
        Glad to see you are getting there.
        You should install the Sketchucation Plugin Store, it will make searching for managing and installing plugins easier.
        http://sketchucation.com/resources/plugin-store-download
        Plus there is the Extension warehouse for another easy way to manage your plugins.
        Both function from within Sketchup.
        • KathrynGK Offline
          KathrynG
          I actually have both installed and was browsing though them yesterday. And now that I have got as far as the "candy cane" stage of the model, and as soon as I can figure out what "In einzeltelle auflosen" (Google translate told me it meant "dissolve in retail hiring" πŸ˜† means, so that I can divide what is a solid face into the segments as he has them - I will be good to go!
          Not without a cup of tea,,,
          • gillesG Offline
            gilles
            The very fast way: screw1_5.rb
            Does not need face to work and accepts components not groups, you can select components and raw geometry at the same time.
            http://rhin.crai.archi.fr/rld/plugin_details.php?id=357
            Click its a GIF(t)…
            • KathrynGK Offline
              KathrynG
              Very interesting and I will definitely look into it. What I liked about Mr. Raupp's model was the ability to obtain so many "looks" with his spiral. I noticed this ruby said for Sketchup 4, but I am sure it must work in 14 for you to have recommended it. Merci.
              • gillesG Offline
                gilles
                I've just tested it with 2014 and works.
                • ntxdaveN Offline
                  ntxdave
                  @ely862me said:
                  The circle is drawn for reference. After you draw the circle, make it a group and right click/Lock . Then draw a line over only one segment. Pick an endpoint and move it up . Then rotate that line while holding CTRL to make a rotated copy of it. Enter 15 in the vcb and hit enter. Then type x23 in the vcb and hit enter. You will now have 24 starting helix segments. Now select all the segments and move while pressing CTRL them up until they reach the top of the other ones. Right away type x20 in the VCB and you have 24 helixes created .
                  https://www.screenr.com/PRkN
                  OK everyone - I am feeling very stupid. I have no problem creating the helix but how do you then combine the helix lines with the extruded circle to be able to manipulate things?
                  I see in both of the videos that after you create the helix you are then able to select any of the helix lines independently and delete them. I also saw in the original video that once the lines were "connected" to the face of the extruded circle so that he could create the "candy cane". Why am I not "getting it"? Creating the multiple helix was easy but combining them with the "cylinder" has stumped me.
                  Press F1...thank me later
                  • KathrynGK Offline
                    KathrynG
                    My exact question - but after having been such a pain all day I was too embarrassed to ask that question as well. Thank you for asking it for me. πŸ˜„
                    • KathrynGK Offline
                      KathrynG
                      gilles:
                      Installed and experimenting, but I am not understanding the 5 entities? It worked with the component, but of course that is not the look I am going for, the other one is, and when I follow what you did, I get nothing ?
                      • BoxB Offline
                        @ntxdave said:
                        I also saw in the original video that once the lines were "connected" to the face of the extruded circle so that he could create the "candy cane". Why am I not "getting it"? Creating the multiple helix was easy but**combining them with the "cylinder" has stumped me**.
                        They must be in the same context. Either explode the cylinder group or copy and paste them into the cylinder group.
                          He just selects surfaces or lines then move them! πŸ˜‰
                          When you select a surface by a Double Click = surface + perimeter
                          then select again this surface with Shift + Ctrl = you obtain just the perimeter! πŸ˜‰
                          • ely862meE Offline
                            ely862me
                            Instead of deleting the circle as I did in my last step, just use Push and pull and pull it up at the end of the helixes. Then keep as many helixes you want, Kitto kept 4 or 6 I believe. Then explode the group with the newly created cylinder and you will then have the helixes drawn over the cylinder .
                            Elisei (sketchupper)
                            Come and See EliseiDesign
                            • KathrynGK Offline
                              KathrynG
                              I was just about to write back to ntxdave, and tell him that I had found the answer, which was to just "select all" and then explode. Hope you are proud of me Box - I figured it out all by myself.
                              • ntxdaveN Offline
                                ntxdave
                                Boy - I need to quit posting and showing how much I am missing. First of all, when I get done creating the helix's they are a bunch of line segments, they are not connected. I tried what you and the others said but I am really missing something that should be obvious.
                                Here are the steps I have taken:
                                1. Created the circle
                                2. Made the circle a group and locket it
                                3. Drew a line the size of one segment and then rotated it upward
                                4. Copied the line 23 times creating the first "row" of the heix's
                                5. Copied the row of rotated lines 19 times to create the helix's
                                After these steps I have tried several things all of which seem to be contrary to what the rest of you are saying. I do not get a real set of helix's (i.e. according to the videos I should have 24 helix's). Instead I get 24 sets of line segments which "look like" helix's.
                                When I try the Select All and Explode, I get the bunch of line segments and I have my cylinder with it's 24 faces but I never seem to be able to combine them so that I can perform the coloring and other things shown in the videos.
                                This is making me feel really stupid since I have been using SU for over a year now and this seems like it should be pretty straight forward. This is making me not want to post again and show my ignorance. 😞 😠
                                • BoxB Offline
                                  @ntxdave said:
                                  [*]Drew a line the size of one segment and then rotated it upward
                                  Is it possible this is your error. You don't rotate the segment, you lift the endpoint.
                                  If you rotate it it wont connect to the next row of segments and you'll have all the individual segments floating about.
                                  Perhaps an image would help us see where you are going wrong.
                                  • ntxdaveN Offline
                                    ntxdave
                                    When I said rotated it I really meant lifted it.......by wording on my part. I think the first real issue is that the rows are not connecting.
                                    Here is what I wind up with...........
                                    Notice that I have a series of unconnected lines. I think that is probably the route of the problem. What the heck am I doing wrong. I am feeling dumber by the minute.......
                                      driven
                                      @ntxdave said:
                                      ... This is making me not want to post again and show my ignorance. 😞 :x
                                      box has reposted while I wrote, but carry on regardless....
                                      first up Kito Raupp is a genius with the native tools...
                                      when i first tried copying his techniques it all went tits up...
                                      so, the trick for me getting my head around whats happing was to start with a cylinder...
                                      group that, and turn on hidden geometry...
                                      draw a line across any face >> rotate that line...
                                      move those new lines up...
                                      have fun and keep asking...
                                      • BoxB Offline
                                        That's how it should be, they are segments and you need to weld them if you want them to be one curve. That doesn't stop them forming the face between them on the cylinder.
                                        Pull the cylinder up to meet the top and explode it, them click between two of the spiral lines and it should select one whole helix face.
                                        Edit: watch carefully after I have pulled the cylinder up, you can see me click on the segments.
                                        • ntxdaveN Offline
                                          ntxdave
                                          Well, I made some progress but still not quite there..........
                                          As you can see, I got the darn thing to let me color the stripes however, I had to color each stripe independently. I then could not select one color of stipe and use the scale tool to move it to create the slots like in the video. I think that it is all still related to the fact that I do not have the lines to form the helix's.
                                          • BoxB Offline
                                            Go back a couple of steps then.
                                            After you have copied the array upwards, delete all but one up the spirals, select all of the segments and weld them into one curve. Now array that and pull your cylinder etc etc etc
                                            • 2 / 4
