    Spiral help please
    72 Posts 11 Posters 6.1k Views 11 Watching
    • KathrynGK Offline
      KathrynG
      Orange Peel in stadium.jpgTop o' the morning, and another stupid question please.
      Having found the perfect tutorial on creating an "orange peel" wrap for my event renders, (see photo attached) by Kito Raupp https://www.youtube.com/watch?v=pNTetL3Udkc%26amp;list=UUqlqnVJT4qTJdJbnCU0y4QQ, and after having watched it at least ten times, and since there is no audio to the tutorial (Unless Herr Raupp speaks English there would have been a problem anyway since "Ich spreche kein Deutsch". Thank you Google translate πŸ˜„ ) I cannot for the life of me figure out what he did to get the copy of the original row of lines to match up when copied.
      His VCB is not visible in the tutorial, and the entire clip is very fast. Obviously he rotated it, but how and by how much just left me sitting here feeling mightily frustrated!
      Are there any kind souls out there who can put me out of my misery please?
      "With SketchUp - Rome could have been built in a day!"
      • BoxB Offline
        I'm not quite sure where you are having a problem, but perhaps some words to go with the picture would help.
        He has a circle as a group as a guide, he uses one segment outside that group and lifts one end of it on the blue axis, how high affects the angle of the spiral.
        He uses the center point to array the segment 23 times then simply uses ctrl and move to lift the whole array up on the blue axis to join the ends.
        Because the end has been lifted on the blue axis, rather than the segment being rotated, the ends will join.
        http://i155.photobucket.com/albums/s296/storeben/SU/Lift.gif
          Copy rotation Multiple = Copy move then type * x number here maybe * 24
          (for another nature of copy inside an interval you can type / x number)
          then
          Rectangular Selection from right to left!!! πŸ˜‰
          etc...
          When all the spirals are made
          Just double-clicked on any one segment! πŸ˜‰ = select all the spiral lines of one!
          If you follow step by step the first seconds of the video ( you can pause on pressing the white triangle! ) he makes no more of that he shows! πŸ˜„
          • KathrynGK Offline
            KathrynG
            Oh I got all of that. It was not the array that was the problem, it was that when I copied the array and moved it up on the blue axis it did not line up? Guess I'll try it again...
            • BoxB Offline
              As long as you lift on the blue and array to the correct endpoints it will line up.
              http://i155.photobucket.com/albums/s296/storeben/SU/End.gif
              • KathrynGK Offline
                KathrynG
                Thank you, I am going to give it another shot.
                • ntxdaveN Offline
                  ntxdave
                  I understand what is going on but I am not able to manipulate one segment like he is doing. What am I doing wrong?
                  I created a circle, then I used the Explode Curve command but when I try to rotate one of the segments it is still attached to the circle.
                  Press F1...thank me later
                  • ely862meE Offline
                    ely862me
                    The circle is drawn for reference. After you draw the circle, make it a group and right click/Lock . Then draw a line over only one segment. Pick an endpoint and move it up . Then rotate that line while holding CTRL to make a rotated copy of it. Enter 15 in the vcb and hit enter. Then type x23 in the vcb and hit enter. You will now have 24 starting helix segments. Now select all the segments and move while pressing CTRL them up until they reach the top of the other ones. Right away type x20 in the VCB and you have 24 helixes created .
                    https://www.screenr.com/PRkN
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                    • BoxB Offline
                      As I said above.
                      http://i155.photobucket.com/albums/s296/storeben/SU/Segment.gif
                      • KathrynGK Offline
                        KathrynG
                        Helix.movThank God for people with patience. 😲 I have managed to get this far. So far so good... but, and I am guessing it is just maybe that I am grabbing the array in the wrong place, when I move (Option for me on a Mac) the array, it is still not lining up? Sigh... (Pardon the drifting off the blue axis)
                        • BoxB Offline
                          Your array is wrong, the endpoints should be aligned.
                          When you make the array you should be moving the copy only one segment length.
                          • KathrynGK Offline
                            KathrynG
                            I'll get thisIf it kills me! - and probably you... Yes - looking at the clip again I can see what I should have done. I am an atrocious SU user though I try, and commit the terrible sin of eyeballing stuff too often and it shows. I did not take into consideration the 24 segments in the circle. Back to the drawing board and I cannot THANK YOU enough for your help and patience. I shan't disappear into the sunset without another thank you once I succeed, and succeed I will d--mn it! πŸ˜‰
                            And will return to let you know of my nomination to the SU Hall of Fame.
                            Cheers!
                            • BoxB Offline
                              By the way, you do know there are quite a few plugins that will draw helix's for you?
                              • KathrynGK Offline
                                KathrynG
                                Nooooo... actually because I am so dreadful and usually just shop the warehouse for models that I need, I did have some wonderful ruby scripts that I found on s'Mustard. When I switched from SU8 to SU14 however, none of them worked? Move to origin, hip roof, sphere etc. I looked though the list again yesterday hoping to find some updated versions to some of these ruby scripts, but without much luck. I keep telling myself that if I keep on depending on the warehouse for models that I need, that I will never get any better, but when a drawing needs to be finished and SU is only the first step and then on to Photoshop, and the clients are drumming their fingers, any time that I can save is immeasurable. Actually - before submitting this post, I went into my library to check, and even though I know I migrated them over, none of them are showing up in the folder. Curiouser and curiouser. It's a dreadful thing being a bear of little brain. πŸ˜„
                                • KathrynGK Offline
                                  KathrynG
                                  I DID IT! I DID IT! I DID IT! Glory Hallelujah!! It only took two days...
                                  Box (or is it Mr. Box?) you are a champion! This has always been my problem. I registered for SU classes twice at the nearby college, and on both occasions just like the war that no one attended, they were cancelled due to lack of interest. I have therefore had to resort to Youtube and Lynda.com and trial and error (errors costing me lots of trials...) to learn the little that I know. Having been nominated on several occasions for Math Moron of the year, that does not help. But thanks to people like yourself, who take the time out of your day to help the helpless, I shall prevail, and I never give up. THANK YOU SO MUCH. Now let's see if I can understand where he went from there. πŸ˜„
                                  • BoxB Offline
                                    Glad to see you are getting there.
                                    You should install the Sketchucation Plugin Store, it will make searching for managing and installing plugins easier.
                                    http://sketchucation.com/resources/plugin-store-download
                                    Plus there is the Extension warehouse for another easy way to manage your plugins.
                                    Both function from within Sketchup.
                                    • KathrynGK Offline
                                      KathrynG
                                      I actually have both installed and was browsing though them yesterday. And now that I have got as far as the "candy cane" stage of the model, and as soon as I can figure out what "In einzeltelle auflosen" (Google translate told me it meant "dissolve in retail hiring" πŸ˜† means, so that I can divide what is a solid face into the segments as he has them - I will be good to go!
                                      Not without a cup of tea,,,
                                      • gillesG Offline
                                        gilles
                                        The very fast way: screw1_5.rb
                                        Does not need face to work and accepts components not groups, you can select components and raw geometry at the same time.
                                        http://rhin.crai.archi.fr/rld/plugin_details.php?id=357
                                        Click its a GIF(t)…
                                        • KathrynGK Offline
                                          KathrynG
                                          Very interesting and I will definitely look into it. What I liked about Mr. Raupp's model was the ability to obtain so many "looks" with his spiral. I noticed this ruby said for Sketchup 4, but I am sure it must work in 14 for you to have recommended it. Merci.
                                          • gillesG Offline
                                            gilles
                                            I've just tested it with 2014 and works.
                                            • 1 / 4
