    Unhide Groups
    2 Posts 2 Posters 224 Views 2 Watching
      d1018irons
      I have a group that shows up if I check "Hidden Geometry" under the view menu,but it but it stays hidden when I click on the "Unhide" - "All" command under the Edit Menu. Also, the group is not grayed-out in the outliner as it should be if it is hidden. Why isn't this group showing up on the screen? Is there another way to unhide it?
      • jeff hammondJ Offline
        a guess without seeing the .skp...
        the group isn't hidden.. the geometry inside the group is hidden.. when using 'unhide all', it will only affect the hidden geometry in the current level.
        click on the group in outliner.. edit the group via the Edit menu.. then unhide.
