    [Info] Ambient Occlusion -> Simple Rays
    66 Posts 22 Posters 80.4k Views 22 Watching
      Did you ever find any improvements that could be made?
      • Q Offline
        qpik
        I planned writing new method in C and calling it via Win32api... but I never find time and enough determination to do it. I wish somebody else did it instead πŸ˜„, someone who knows C, unlike me.
          I'm also an C ignorant... 😞
            KiraNL
            Any chance this ever might come out which works for round shapes?
            Love to use this as subtile shadows over the textures, sort of lighting baking.
              seikun
              how can i download the plug-in
                It's attached to the first post of the topic. But it is not yet tested on SU version 9 - so it may not work for you (unless you made a typo when registering in which case, could you correct it, please?).
                πŸ˜‰
                  tomasz
                  Hi Kuba,
                  Nice to see another Polish architect in action as a programmer. πŸ˜„
                  I am getting more and more comfortable with C++, but I do not expect to be able to help you within next few months.
                  I won't forget you effort and if I will find time, I will see whether I can help you with the raytest issue.
                  • Dan RathbunD Offline
                    Dan Rathbun
                    This "plugin" (using the term liberally,) has been NOMINATED for QUARANTINE.
                    see: [Candidate] Quarantine: Ambient Occlusion by qpik
                    I'm not here much anymore.
                      Dan Rathbun
                      NOTICE: Preliminary Overhaul of the SimpleRays plugin !
                      Developers' forum: [Plugin] Qpik::SimpleRays OVERHAUL
                      I did this overhaul so we can remove SimpleRays from the Quarantine List
                      Jakub, where are you ?
                      • Q Offline
                        qpik
                        I'm back πŸ˜„
                        • jiminy-billy-bobJ Offline
                          jiminy-billy-bob
                          http://i.imgur.com/Sd7uce4.jpg
                          • TomPendergrassT Offline
                            TomPendergrass
                            Hello SketchUcators!
                            I have a lot of interest in this topic. While modeling in Sketchup can be bliss, creating impressive visual displays without a full blown renderer is very difficult. Being a game developer hobbyist, this limitation keeps me in Blender for most of my game related art.
                            Anyways, I was curious about raytest and what it's quirks were. As was stated earlier in this thread, limiting the raytest's scanning distance could be the solution to faster raycasting. Unfortunately, the ruby API doesn't offer this option; I suppose all rays are infinite (or my theory is the raytests are to the bounds of the scene.)
                            I decided to do a test: I made a ruby method > raytest_repeating(ray, repeatCount) and cast a ray along the y axis 10,000 times. With no obstructions, it completed it's process on average around 0.15 seconds. Introducing two cubes in separate groups to intersect with, the same method took about 0.68 seconds on average. Here's the interesting part. I placed 2000 groups along the y axis and ran the same method again. This process took ~938 seconds to complete! Keeping the same cubes in the scene and moving all but two of them out of the ray path dropped the calculation back down to the 0.68 average!
                            In conclusion, raytest must be spending time on all objects the ray interesects, even though it only returns the closest object. It's no wonder your occlusion process drops to a crawl in dense scenes, since I assume you're casting hemispherical rays into 'infinite space', colliding with EVERYTHING along the way! I believe a possible solution to your problem is to find the faces that are in the range of a raytest (IE, nearby faces that actually effect the shading) and to dynamically hide the rest of your scene as needed. Since the raytest can ignore hidden objects, it should speed up the overall process considerably. I ran one final test with the 2000 cubes, hiding all but 2 of them. While the process was slower, 10,000 rays came back in 5.2 seconds, which is far better than 938!
                            I hope my findings can assist you on this wonderful creation of yours!
                            -Thomas Pendergrass
                            • Q Offline
                              qpik
                              Thanks, good to know that.
                              But what would be the method to define relevant shading objects, an object's area to sphere-at-the object-distance area ratio?
                                TomPendergrass
                                Hey qpik,
                                I know it's been a whole year, I didn't notice that you had posted back on the forum. You're right, you'd need to do a check of what is in your range, and hide everything else. I actually made a script for this way back when, but it remains to be purely experimental. What I did was accept a point in space and created a square bounding box, since bounding spheres aren't really a thing. From that I can iterate through the scene and hide any group that isn't touching my bounding box by using the .contains? method (.contains in versions before 2015 returned invalid results sometimes).
                                Assuming a dense scene is constructed of small groups, you could do this .contains check for every x amount of rays you cast and hide the irrelevant geometry. It's a patchy fix to a clunky raycast system, but it may fit all of your needs. If you're still interested in this topic, let me know and I'll dust off the old code and post it here.
                                • Q Offline
                                  qpik
                                  Tom,
                                  time flies and I read your post just now. I guess it depends how long does it take to hide/unhide objects in SketchUp.
                                  I just started working on a solution using Blender https://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=67569
                                  • 4 / 4
