    Rendering Multiple projects at the same time
    renderpluginsextensions
    2 Posts 2 Posters 1.4k Views 2 Watching
      aneeshcarvalho
      Hi guys, Can we render 2 or more projects in Vray at the same time? I am rendering a final image for one residential project and at the same time, I want to work on another Interior project doing several test renders. Is this possible with Vray 2.0?
      • andybotA
        andybot
        sure, it's possible if you're on the same computer. If you only have one license you can only use one computer at a time. You may also be able to set processor affinity so you reserve some cores of one session, and other cores for the other session. (since vray uses all available cores to render, it may be pretty slow to run two renderings at the same time.)
