    SketchyPhysics 3.5.6 (26 January 2015)
    208 Posts 49 Posters 297.9k Views 49 Watching
      jbgood
      Hope some one can help I have SU 14 pro and just downloaded SketchyPhysics 3.5.5 (October 25 2014) but there does not seem to be any way to install it help anyone please
      JBgood
      • cottyC Offline
        cotty
        @jbgood said:
        JBgood
        There are several ways to install plugins in 2014, which one did you choose?
        my SketchUp gallery
          Anton_S
          @jbgood said:
          JBgood
          You may also refer to this post, I'll add it part of main description:
          http://sketchucation.com/forums/viewtopic.php?f=61%26amp;t=58936%26amp;start=30#p540351
            deskpilot
            May I jump in on this thread gents. I've recently purchased a new pc,loaded SU2014Make and SP3.5.5.. Kept getting that annoying warning about a bad install so I went back a step and loaded an earlier version, 3.1. Now, full install seems OK but the plugin is permanently disabled. Try as I might, I can't get it to do anything but say it will be disabled next time I fire up my pc. Any answers please. If I have to go into DOS or similar, please explain all steps.
              Anton_S
              Hello,
              It would be nice if you provide me some more details.
              • What warning message do you get?
              • What operating system are you using?
                Regardless of that, I don't think SketchyPhysics 3.1 will work in SU2013 or above. Keeping it in the 2014 plugins folder is useless. I suggest you to go to C:\Users\YOUR_NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins, and erase all sketchy physics versions from the folder. Then, download the SP3.5.5 if you hanven't so, and extract content into the plugins folder. It should look like this:
                *...\Plugins*
              • SketchyPhysics3
              • SketchyPhysics.rb
              Hope this helps or provide some details if you can't get it working.
                deskpilot
                OK, done as you suggested but now I'm back to:
                Loading error
                Error Loading File sketchyphysics.rb
                Error: #<LoadError: cannot load such file -- SketchyPhysics3/ClassExtensions.rb>
                C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/sketchyphysics.rb:19:in load' C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/sketchyphysics.rb:19:in LoadSketchyPhysics3'
                C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/sketchyphysics.rb:61:in doLoad' C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/sketchyphysics.rb:137:in <top (required)>'
                Would appreciate next step
                Cheers, Doug aka Deskpilot
                PS, running Windows 7 Home on a 64 bit systems
                  Anton_S
                  That file is from old sketchyphysics version. It seems you didn't delete sketchyphysics.rb from the plugins folder as i suggested in previous post.
                    deskpilot
                    Sorry to bother you again Anton but try as I might, I'm still not getting SP to work. All looks good when I view my files. All sub folder appear to be there but in SU, there's no sign off it.
                    Is this correct?
                    C:\Program Files (x86)\SketchUp\SketchUp 2014\Plugins\SketchyPhysics3
                    In the SP3 folders, there's every thing I would expect.
                    Where else should there be folders or files that I can check?
                    BTW, I completely uninstalled/deleted everything and started again with a fresh download.
                      Anton_S
                      @deskpilot said:
                      Is this correct?
                      Ah, I see your problem. SketchUp 2014 has its plugins folder in different location. SU2014 and above have their plugins folder in AppData, while prior version have their plugins folder in Program Files. Delete the plugins folder you created in C:\Program Files (x86)\SketchUp\SketchUp 2014, and use the correct path, C:\Users\YOUR_NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins.
                      The easy way to get to AppData is to write and send %appdata% in your windows explorer address bar, and from there you could navigate to your plugins folder.
                      The final path should look like this:
                      *C:\Users\YOUR_NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins*
                      SketchyPhysics3
                      SketchyPhysics.rb
                      I'd suggest you to erase all the prior sketchy physics version if you installed any. You don't need them to get the latest version working.
                      Here is the similar post to consider if I didn't make it clear: http://sketchucation.com/forums/viewtopic.php?f=61%26amp;t=59782#p544700
                      Hope you can get it working, I will add installation instructions to the main post.
                      • W Offline
                        willeykj
                        I shared emails with Chris the other day and he and I both agree its time to get the original source code for the libraries out into the community. (Chris really did all the work and created SP, I just did the port to OS X).
                        Despite our best intentions, we will never pick up the threads and get SP going as fast as Anton and you (the rest of the passionate SP community) are doing.
                        What is the preferred method you'd like for getting the source code into the hands of the community?
                        For those that are confused by this - I'm not talking about the Ruby code. I'm referring to the C code in the extension libraries that hook the SP ruby code into the Newton physics library and other assorted Ruby C Extensions that access OS specific functionality and other libraries (like SDL, Midi support, etc...).
                          deskpilot
                          Thankyou very much Anton, it's all there now. I'll play with it a bit later (only just got up). As you been discussing, this needs to put out there for the wider community.
                            Anton_S
                            Very well!
                            I think GitHub is the best way to share source to the community.
                            • gillesG Offline
                              gilles
                              Is there a way to make control panel pop up elsewhere than in the middle of the screen?
                              • BoxB Offline
                                Could you look at changing the opening state of the toolbars.
                                If you have it loaded they will always open on startup whether you closed them last time or not.
                                @Gilles Might be different on the Mac, but I moved it aside and it now always opens where I moved it.
                                • gillesG Offline
                                  gilles
                                  This does not work on my mac 😠
                                    RTLMII
                                    Any Idea when a Sketchup 2015 X64 Sketchyphysics version will be available?
                                      Anton_S
                                      It won't be available until people owning C++ source of SketchyPhysics decide to release 64bit compatible libraries that are used by SketchyPhysics.
                                        TANER TAN
                                        Hello! Very useful plugin! We expect the SketchUp 2015 64-bit compatible version. Thanks.
                                        • N Offline
                                          N Lindenthal
                                          http://sketchucation.com/forums/download/file.php?id=126705
                                          Please excuse me, if I did not lern my English very well.
                                          SketchyPhysics gives wings.
                                          Above is my sample file. My question is: How can I stabilize the joints so that they don't tremble so strong?
                                          Maybe someone can set the parameters in the pattern file or give little hints.
                                          Many greetings
                                          Norbert Lindenthal
                                            Anton_S
                                            It says I'm not authorized to download the file. Looks like you have to upload the attachment the other way, in the Upload attachment tab when you post a reply.
                                            Meanwhile, to reduce joint flexibility, both bodies the parent and child have to have an identical mass. That is easy to set.
                                            1. Select parent body, open control panel, and enable the scripted checkbox.
                                            2. In the scripted field write,
                                            onStart {
                                              this.setMass(1.0)
                                            1. Do same for the child body.
                                            You can change the 1.0 to any desired value. As long the values of parent and child bodies are not way off, the joint should remain strong.
                                            Here is the video demonstration:
                                            https://www.youtube.com/watch?v=qw2C9goxbNk%26amp;list=UUFRTk8PFA2D36yHxwYrulIw
                                            Move timestep to 1:20 for visual instruction on how to set identical mass.
                                            • 11
                                            • 9 / 11
