    Divide face
    12 Posts 6 Posters 2.4k Views 6 Watching
      sexypox69
      Is there a plugin which allows me to divide a selected face into multiple faces inputting a require size. For example, I have plain surface 5'x5' and want to divide half of it into 4"x4" tile pattern and the other half into 1"x1" tile pattern. I came across the protude.rb but it doesn't allow you to control the size of the new faces.
      My reason for this is to pass over to CAD afterward so i can't just paint a tile pattern on. Its basically creating tiles but on a flat surface for 2d export
        sexypox69
        This I did manually by move/copying lines.....But my project is more complicated in design and of various sizes....move/copying I see already will take me an eternity
          Did you use the array function of Move/Copy?
            If your surface is a quadrangle you have Split Up by TIG! πŸ˜‰
            (or a quadrangle with a hole)
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/SplitUP_001.jpg
            • BoxB Online
              One of the simplest ways for uniform tile grids is the sandbox tool, from scratch.
                Maybe also the SLICER BY TIG (works in volume! ) πŸ€“
                  A tricky one is the Floor Generator by Sdmitch! πŸ˜‰
                  Works with any form of surfaces! β˜€
                  Just adjust your dimensions if fit wanted ! πŸ€“
                  • PixeroP Offline
                    Pixero
                    Whats FFD(nxn)?
                      Whats FFD(nxn)?
                      Surely this one πŸ˜‰
                      http://sketchucation.com/pluginstore?pln=SketchyFFD
                      and more explicitly this one!
                      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=25801
                        sexypox69
                        Thank you Pilou for the floor generator suggestion....It work out to be the best solution....what would make this plugin even better, is the possibility of having more option in the grid origin selection box....such as top right corner, bottom right corner, etc
                        • sdmitchS Offline
                          sdmitch
                          If Corner origin is selected, the corner closest to the pick point is used. So if you want top right, just pick a point near it.
                          http://sdmitch.blogspot.com/
                            sexypox69
                            Thanks sdmitch. I love this sketchucation forum
