    Plugins Not Compatible with SU2015-64bit
    73 Posts 21 Posters 11.6k Views 21 Watching
    • KrisidiousK Offline
      Krisidious
      while upgrading my installs to 2015 I reinstalled twilight. while it worked in the newer installs it broke 2013. I had to remove it to be able to open sketchup. Bugsplat. Beware when you install, where it installs. it will ask you to migrate settings when you open another version of SU.
      By: Kristoff Rand
        Krisidious
        Looks like Cabinet Tools and Bi-Fold Door by tomot are not compliant either. I've got an email into him to confirm.
        By: Kristoff Rand
        • jcharltoncarpJ Offline
          jcharltoncarp
          Scalp is causing my copy of SU2015 to crash on opening. I just tried installing a fresh copy from the plugin store and got the same results
          • BoxB Offline
            Try installing the version on the skalp website. It's possible the sketchucation store version is out of date.
            I just downloaded and installed the website version and if functions correctly.
            http://download.skalp4sketchup.com/downloads/latest/
              Krisidious
              Tomot is aware of the issue and says it will be a while before he can get to fixing it. Possibly January. He thinks all of his plugins might be broken, but I have Window and Door Tools installed and it seems to work ok. Book Shelf also seems to work fine.
              By: Kristoff Rand
                Krisidious
                Marginal UV Editor seems to be not working in 2015 64bit.
                By: Kristoff Rand
                • john2J Offline
                  john2
                  Can't we have a collaborative online cloud type document listing all the incompatible plugins? This is a discussion thread and the first post can have a link to a collaborative document which only SCF members can edit and report incompatible plugins.
                  That would be the most organized system to get things in our control. I guess the administrators can design some webby thing or somewhat like that. What say? πŸ˜„
                  Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                  • PixeroP Offline
                    Pixero
                    I get this when trying to start SU2015,64bit with Julia Eneroths Texture positioning plugin installed:
                    Error Loading File ene_texturepositioning.rb
                    Error; C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;47; invalid multibyte char (UTF-8)
                    C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;47; syntax error, unexpected tIDENTIFIER, expecting keyword_end
                    ...given edge Rotate 90Β° clockwise or counter clockwise in one ...
                    C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;47; syntax error, unexpected keyword_in, expecting keyword_end
                    ...ockwise or counter clockwise in one click. Rotate in custom ...
                    ...ockwise in one click. Rotate in custom angle. Get rid of pat...
                    C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;47; syntax error, unexpected tSTRING_BEG, expecting '('
                    ...patterns formed between faces."
                    C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;48; syntax error, unexpected tFLOAT, expecting keyword_end
                    ex.version = "1.0.1"
                    C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;48; no .<digit> floating literal anymore; put 0 before dot
                    C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;49; syntax error, unexpected tCONSTANT, expecting keyword_end
                    ex.copyright = "Julia Christina (eneroth3) Eneroth 2013"
                    C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;50; syntax error, unexpected tCONSTANT, expecting keyword_end
                    ex.creator = "Julia Christina (eneroth3) Eneroth"
                    C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;50; unterminated string meets end of file
                    C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;50; syntax error, unexpected end-of-input, expecting keyword_end
                    end#module
                    It's soo good. Please fix. πŸŽ‰
                      Krisidious
                      I don't think many things will stay broken long enough to need it... Maybe just a couple. I'll take everything from the thread that doesn't work still and compile it at the front.
                      It might have been a good idea to do something like that from the beginning of the roll out... But having a version compatibility variable in the plugin store would probably be more efficient.
                      By: Kristoff Rand
                        driven
                        It's soo good. Please fix. :bounce:
                        version = "1.0.3" from EW warehouse works...
                        • tt_suT Offline
                          tt_su
                          That looks to be related to Ruby 2.0 - meaning SU2014. What version do you have?
                          • PixeroP Offline
                            Pixero
                            What version of what?
                            I have both 2014 32 bit and 2015 64 bit latest versions.
                            Edit. Do you mean her script?
                            I downloaded with Sketchucation tool I believe.
                            Will check version tomorrow.
                              driven
                              the version is in the error
                              sorry, I wasn't clearer, that's why I pointed to the EW version, which is 2 versions higher 1.0.3
                              • PixeroP Offline
                                Pixero
                                Now I've removed the old version and reinstalled 1.0.3 and the error message is gone.
                                Still nothing happens when I try to use it.
                                Not even errors in the console. πŸ˜•
                                I have it installed in: C:\ProgramData\SketchUp\SketchUp 2015\SketchUp\Plugins
                                • BoxB Offline
                                  Why did you install it there?
                                  The default location is "C:\Users\YourUserName\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins"
                                  If you use the Install button on the Extension Warehouse from within SU it install to the correct folder and works in 2015.
                                  • FrederikF Offline
                                    Frederik
                                    3skeng piping plugin doesn't work with SU2015
                                    Edit: I've been in contact with the 3skeng Team and I've received an update of the 3skeng piping plugin, which - so far - works perfect with SU2015 64-bit... πŸ˜„
                                    Cheers
                                    Kim Frederik
                                    • PixeroP Offline
                                      Pixero
                                      Why is there two locations to install Plugins then if they are not the same?
                                      In Sketchucation Plugin Store you can choose between the two.
                                      (Even three if you count the preinstalled ones from Trimble.)
                                      • BoxB Offline
                                        Do you have twilight?, that is one plugin I know of that creates that folder.
                                        • FrederikF Offline
                                          Frederik
                                          From the Installed 2015. No Plugins folder??? thread...
                                          @dave r said:
                                          The only Plugins folder you should be putting plugin files into is the one under User/AppData. The reason it is where it is has to do with Windows applying security settings to folders in Program Files which prevented users from installing files. This caused users all sorts of trouble because many didn't know about the security settings or how to change them. You can see evidence of that by looking through some of the longer threads in the Plugins folder. An endless run of questions about how to install plugins and claims that the plugins didn't work in this version or that. In most cases, the problem was found to be the security setting for the Plugins folder.
                                          Now, the folder is not secured by the operating system. Also, between Preferences>Extensions>Install Extension, The Extension Warehouse and the Sketchucation Plugin Store, there's no need to directly access the Plugins folder under AppData. Those three tools will auto-install plugins at the click of a button.
                                          In order for plugins to be installed by these tools, they need to be packaged as .rbz files. And plugins you download from the Extension Warehouse or the Plugin Store will come as .RBZ files. For files you might get from elsewhere such as Smustard, you can package them yourself so Install Extension will handle them. If you download a .rb file, use a zipping application such as 7Zip to create a zip file. Then change the extension from .zip to .rbz. If the file you've downloaded is already a zip file, just change the extension. It's easy and you don't have to go hunting for the folder.
                                          And further...
                                          @tig said:
                                          DaveR just posted before me, and said much of this...
                                          But as I had justed typed this I'll still post it anyway πŸ˜•
                                          You only place you actually need to install Plugins is in your default AppData User's Plugins folder, which is pre-made by SketchUp.
                                          To find its path copy/paste+<enter> this in the Ruby Console:
                                          Sketchup.find_support_file('Plugins')
                                          BUT why do you need to look in it ?
                                          The EWH auto-installer, Preferences > Extensions > Install... button and/or the SketchUcation PluginStore dialog's AutoInstall button, all extract the contents of the RBZ files into there...
                                          When SketchUp starts all RB/RBS files in there are auto-loaded.
                                          Only you, logged in as your User-name loads those.
                                          Do NOT make a Plugins folder in the ProgramData path UNLESS you want to share plugins with other users on the same PC, as if that Plugins folder exists any RB/RBS files in there are also auto-loaded as SketchUp starts, this time for any user logged into that PC.
                                          You cannot use the native Installer with that folder, however the SketchUcation PluginStore AutoInstall and Archive-Installer submenu item does see and offer it as an alternative 'custom-plugins-folder' destination.
                                          It's pointless having the extra folder unless you want to share...
                                          There are a couple of other folders that you should NOT add files to, these are reserved for SketchUp's use: they often have little security permissions of mere Users [even Admins].
                                          They are 'Tools', which contain some 'system' ruby stuff, and 'ShippedExtensions' - which, as its name suggests, contains some extension files [aka plugins] that come with SketchUp's installer - like Sandbox and DC stuff...
                                          In passing, you can also install your Plugins in any folder you like [provided you have security clearance], and link it into SketchUp's $:, so that its contents auto-load with SketchUp.
                                          You need to install a tool into the default Plugins folder, like Fredo's AdditionalPluginsFolder, which does this for you... Read up on it if you feel you really need this level of sophistication...
                                          It is usually unwise to copy your plugin files from one SketchUp version's Plugins folder to another.
                                          Many were updated to be compatible with v2014, and a few more recently for v2015.
                                          So it's best to get fresh copies of all extensions/plugins whenever possible.
                                          Also you need to ensure all related files and subfolders of files are copied - a mega-balls-up is waiting in the wings...
                                          It may be that copying some over will do no harm, but if you subsequently get initial loading errors or just missing tools, then that's a sign of an issue, and time for an updated version...
                                          If you have the SketchUcation Toolset then the PluginStore's dialog had a MySetup page which includes 'Bundles' - a tool which lets you let you duplicate/manipulate sets [aka Bundles] of plugins from an earlier SketchUp version and then make a bulk auto-installation of all of those into your newer SketchUp version's Plugins folder...
                                          Cheers
                                          Kim Frederik
                                          • PixeroP Offline
                                            Pixero
                                            OK. Got it, then I think the Sketchucation Plugin store should make it much clearer what to choose and why since now there are just two options. In 2014 I used the one in AppData. Now in 2015 I just clicked the other one without knowing that was not the best choice.
                                            • 3 / 4
